Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old February 16th, 2018, 20:24   #16
Lightflyer1
Lightflyer1's Avatar
That sounds like a legitimate reason to use one. I wouldn't hesitate either if I was driving from Texas to the Great White North in winter conditions.
2015 Beetle TDI.
Old February 16th, 2018, 20:43   #17
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
I had a 16 mile freeway commute and that was not enough to keep the DPF happy. It's just a very badly engineered bad idea. All you can do is limp it along as long as possible until out of warranty then remedy it properly, IMO.
nicklockard is offline   Reply With Quote
Old February 16th, 2018, 21:06   #18
Lightflyer1
The only issue I see is there is no way to know its status. If they had provided some kind of display to tell the driver where it currently was in relation to dpf regen status and the ability to start a regen early or delay one for some short time, things would be much better. I track mine using the vagdpf app (no longer supported) and have had no issues so far. Without the app though it is hit or miss unless you pay very close attention. Torque app has made some headway in monitoring the regens as well. We will see. The process works well you just don't have a clue about anything and it is kind of critical you do unless you are 70% highway or more.
2015 Beetle TDI.
Old February 17th, 2018, 15:17   #19
nicklockard
Torque Dorque
Yep, basically someone decided that diesels with DPF are "for highway use only" and engineered the DPF's accordingly. So utterly stupid--and such a simple thing, you wonder how they overlooked plain common sense. They should have an interactive that lets you know something like: "I need 15 uninterrupted minutes for regen soon, please authorize when you are ready." Then the driver could defer it, but the "xx" minute time would just grow. It would decrease DPF early deaths more than any other thing, IMO.
Old February 18th, 2018, 15:53   #20
tikal
Fuel Economy: 37 MPG (~ 45% city)
For those interested in the view from the other side of the Atlantic you might want to look at site (in English) such as this one where there is much bigger and experienced pool of CR owners with DPF and SCR (as compared to North America):
http://www.ukpassats.co.uk/phpbb/index.php
For the OP might want to research also the experience of TDI owners in Europe with DPF/SCR using ashless two stroke oil.
tikal is offline   Reply With Quote
Old February 18th, 2018, 17:15   #21
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
I picked up my Ram 1500 Ecodiesel yesterday. According to the owners manual, it will tell me when I need a regen and also when the truck is in the process. I put about 20 miles on it for the test drive and then 100 coming home. So I’m sitting at about 135. Too soon for a regen.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old February 21st, 2018, 16:35   #22
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Search here and in Google using keywords "cerium dpf" and "eolys". These are additives that reduce the activation temperature for the DPF. Note however that VW doesn't sanction the use of any such additives, and there are questions and concerns about heavy rare earth metal - which Ce is - mining and accumulation in the environment.
Edit: When all is said, there's nothing better than proper maintenance and driving schedule that allows the DPF regeneration always to complete. Driving short distances is death for Diesels, even pre-DPF ones. Sorry to say, but choosing a right car for the job is a good principle to follow, and if your usage habits are biased toward short trips, it would be better just to get non-Diesel car.
Old February 22nd, 2018, 09:36   #23
BleachedBora
BleachedBora's Avatar
+1 Meister
No additives needed with any type of fuel purchased in California, though Propel is the best stuff you can get!
KJclow - nice truck! You need to add it to your list of Cars/TDI's
BleachedBora is offline   Reply With Quote
Old February 25th, 2018, 19:08   #24
tikal
Thanks for the reminder about Cerium. I realize that I posted on this topic a while back with some more background information and usage in Europe:
http://forums.tdiclub.com/showthread.php?t=456424
Perhaps the fact that products such as this one are not available in the US is because they contain Cerium and are not allowed by the EPA.
Old March 8th, 2018, 05:07   #25
clacker
You don't need a highway run, just an app with your smart phone and a plug in obd bluetooth dongle telling you when the regens happen and let it finish before shutting down. City driving is fine, it just takes longer as each deceleration lowers the temps, constant driving is better but speed has nothing to do with it, just constant driving at any speed. The event happens every 500ish miles or depending on soot load (there are other factors but the distance and loading ones are the prime factors). I find on rural roads it takes a good 12 miles to run through a regen-a good 15 minutes of driving in those roads. It starts off within a half mile of driving in warmer temps...
clacker is offline   Reply With Quote
Old March 8th, 2018, 08:45   #26
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Is Propel HPR acceptable under VW's warranty restrictions regarding biodiesel?
-George Bernard Shaw
Old March 8th, 2018, 12:45   #27
tomo366
TDI Lifer
tomo366's Avatar
As of today I will be using Hot Shots Secret EDT and Diesel Extreme in my BMW
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
Old March 9th, 2018, 07:17   #28
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
Power Service Diesel Fuel Supplement (aka the white bottle) is the O negative of diesel fuel additives. You can find it anywhere and it works fine in any application any time of the year. If you don't want to think or hunt or pay an exotic price, just use PS white.
Blue_Hen_TDI is offline   Reply With Quote
Old March 9th, 2018, 08:16   #29
tomo366
TDI Lifer
tomo366's Avatar
This coming from the gut that keeps jumping back and forth.....cant keep a TDI for more than a year or so.......
Old March 9th, 2018, 09:22   #30
Lightflyer1
Show me proof that these additives (any of them) do substantially any more to reduce regens. Regen management is the real key here not additives. Of the two you mentioned only Diesel Extreme mentions "up to" 50% reduction in regens, and then nothing more mentioned in the literature available on its page. It talks all around about cleaning and detergents, but how dirty can a 2015 with 5k miles be? I doubt there is much help there to be found. Their other claim is improving the fuel, but the OP is in California with supposedly some of the best mandated diesel fuel in the US. Fuel additives can only improve so much especially if the fuel is already top notch. I find little to be gained here either.
I have nothing against additives where and when needed but for this purpose/post they seem useless. Some people use them all the time and many others never use them at all. Both without issues for the most part. I have tried many kinds in the past and saw no benefit from them without scientific testing being done.
2015 Beetle TDI.
Dpf clogging? vwman2 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 23 October 3rd, 2014 05:12
Driving Tips to prevent intake clogging?? CristinaJetta TDI 101 16 March 7th, 2007 13:56
Lucas Fuel additive reduce EGR/Manifold clogging? SKM348 VW MKIV-A4 TDIs (VE and PD) 9 May 11th, 2005 05:11
Prevent Intake Clogging Poll snorksca TDI 101 15 October 29th, 2004 22:13
Do CCV Filters Prevent Intake Clogging? jddaigle VW MKIV-A4 TDIs (VE and PD) 36 October 9th, 2004 09:35
Page generated in 0.17920 seconds with 10 queries
[Output: 137.55 Kb. compressed to 115.56 Kb. by saving 21.99 Kb. (15.99%)]
