Old February 7th, 2018, 12:50   #1
Aato
Default Passat B6 3rd gear problem
Hey guys, recently I've noticed when I'm accelerating and go to shift from 2nd to 3rd gear its hard to get it to engage or I end up missing it and putting it into 1st gear or 5th gear. I've noticed this problem only occurs when under acceleration as it's perfectly smooth as with all the other gears when not accelerating. What could be the problem? Usually what happens is I accelerate go to change from 2nd to 3rd it doesn't engage right away so it takes me a couple seconds of fiddling with it and then it goes in....This doesn't happen at all when I'm driving normally without hard acceleration.
Aato is offline   Reply With Quote
Old February 15th, 2018, 13:26   #2
Aato
Anyone? Thinking of changing gear oil first to see if that solves it.
Old February 17th, 2018, 12:51   #3
Aato
So after researching for a bit I came across a thread on here that suggested to realign the shifter linkages, has anyone done this before or how hard is it to do?
Old February 17th, 2018, 14:43   #4
narongc73
There are videos on youtube for shifter linkage adjustments. Changing the oil wouldn't hurt.
narongc73 is offline   Reply With Quote
Transmission Problem: No 3rd Gear gtmorgan89 VW MKIV-A4 TDIs (VE and PD) 1 July 18th, 2013 09:34
3rd and 4th Gear Missing, problem solved killerjetta VW MKIV-A4 TDIs (VE and PD) 6 July 27th, 2009 11:02
3rd gear problem CountryGuy VW MKIV-A4 TDIs (VE and PD) 21 May 3rd, 2007 13:40
Transmission Problem-- Stuck in 3rd gear!!! tdi_lamb VW MKIII-A3/B4 TDIs 6 June 30th, 2005 21:46
Problem with getting 3rd gear. *UPDATE* jasonTDI VW MKIV-A4 TDIs (VE and PD) 41 September 10th, 2004 13:17
Page generated in 0.13675 seconds with 10 queries
[Output: 61.25 Kb. compressed to 54.73 Kb. by saving 6.52 Kb. (10.65%)]
