Old February 7th, 2018, 04:32   #1
Nugget3816
Default Puzzled with my Beetle
Okay gentleman here's the question I've got a 2002 Volkswagen New Beetle 1.9 TDI and I don't know if it's a vacuum issue or what it is but I've replaced the actuator and if I disconnect the vacuum line to the actuator the car has no problem revving but when I hook the actuator up I can go to about 3800 RPMs and that's where it'll stop. Now if I leave the actuator disconnected and drive it down the road 1st gear 2nd gear no problem as soon as it hits third it falls on its face if I shut the car off break the vacuum start it back up no problem until I hit 3rd gear and then it falls on its face again can somebody give me an idea what to look for.
Nugget3816 is offline   Reply With Quote
Old February 7th, 2018, 04:38   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
What is your actual vs. requested boost?
Why did you replace the actuator (I assume you mean the VNT actuator)?
Did you adjust it correctly?
oilhammer
www.cardocautomotive.com
Old February 7th, 2018, 05:05   #3
maxmoo
When you disconect the vacuum line you are overboosting so when your ecu senses this it goes into "limp mode" in order to protect your engine from damage. Turning off the ignition resets limp mode.
Research "limp mode alh tdi" ..... volumes have been written, here and elswhere.
I would start by doing a scan for any codes stored, clearing them, driving the car and then rescanning.
And then report back.
maxmoo is offline   Reply With Quote
Old February 7th, 2018, 05:16   #4
Nugget3816
I've been working on this thing now for approximately two weeks. The reason I change the actuator is because the old one was all rusted and it was not moving there for it also seized up the actual wastegate. I have drove the car many times and every time the light comes on it's overboost and the mass air flow sensor I have taken the mass airflow sensor off, cleaned it with the mass air flow cleaner, put it back on and it still gives me the same code. The wastegate now moves freely and I have adjusted the actuator both ways and no matter what it's still overboosts every time. I guess my big concern is why is it that first and second gear it will run like a raped ape but as soon as it hits third it goes into limp mode/ falls on his face.
Old February 7th, 2018, 05:18   #5
oilhammer
oilhammer's Avatar
Sounds to me like you need a new turbocharger.
oilhammer
Old February 7th, 2018, 05:38   #6
maxmoo
I just answered your question above!
MAF's often don't respond to a cleaning on these things...try a new quality one or at least a known good one.....that may well be the cause of your limited rpm.
Old February 17th, 2018, 07:56   #7
Nugget3816
Okay change the maf sensor and I still have the exact same problem now it's showing over boost on the turbo so I really haven't changed anything after changing the MAF sensor.
Old February 17th, 2018, 07:59   #8
Nugget3816
Okay let me rephrase that I still have my overboosting problem but that's only if I disconnect the vacuum hose if I leave everything hooked up it does not climb over 4000 RPM and it still falls on its face after 3rd gear
Old February 17th, 2018, 08:15   #9
flee
Fuel Economy: 40-ish
Time to get back to basics. See: Diagnosing and Fixing Limp mode for A4 1.9TDI by Canadian_Grizzly
Read through this and follow the information methodically.
With luck you will find the component(s) that are causing limp mode and fix it.
The likely candidates are:
Non-Bosch MAF,
Clogged snow screen,
Plugged intake and/or EGR,
Leaking vacuum pump fitting,
Leaking vacuum hose(s),
Leaking brake booster hose,
Failed or plugged N75 valve,
Improperly adjusted actuator,
Failed or misconnected check valve(s), etc.
You need a vacuum gauge to check most of these.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old February 17th, 2018, 08:19   #10
JB05
Fuel Economy: 43/41/40
Could be that the N75 sucked in the residue from the rusted VNT actuator. You can try cleaning it or better yet test it with a vacuum pump. Mine had a lot of contamination from the actuator; so I just replaced that along with the actuator.
JB05 is offline   Reply With Quote
Old February 17th, 2018, 08:50   #11
Nugget3816
Changed the N75 still same issue
Old February 17th, 2018, 17:37   #12
maxmoo
Non-Bosch MAF,
http://forums.tdiclub.com/showthread.php?t=179589
Old February 17th, 2018, 18:47   #13
AndyBees
AndyBees's Avatar
Are you using anything to monitor Turbo Boost? .... VCDS or Scan Gauge! It would be interesting to see the maximum boost.
Also, have you confirmed that the vacuum hose from the Actuator to the N-75 doesn't have a hole in it ... losing vacuum?
At idle, there is full vacuum on the Actuator. Do you know for sure that the Arm on the Turbo is fully down on the set screw when the engine is at idle?
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old February 19th, 2018, 11:16   #14
Nugget3816
The arm isn't fully down on the set screw, if I get it to go fully down then it maybe moves about 1/8 of an inch if it's lucky.
Old February 19th, 2018, 16:30   #15
maxmoo
These vids may help you, if you haven't already seen them....
https://www.youtube.com/watch?v=A476plY-sjo
https://www.youtube.com/watch?v=K6-dXv8IrZY
https://www.youtube.com/watch?v=gYkNMOzsk14
https://www.youtube.com/watch?v=o1Hvt2b7PL0
Odd noise has me puzzled oldpoopie TDI 101 24 March 13th, 2016 20:55
Puzzled (Serpentine Question). kopeck VW MKIV-A4 TDIs (VE and PD) 8 April 8th, 2014 04:57
confused and puzzled!! tdiward TDI 101 7 January 25th, 2011 16:31
Non TDI but puzzled-help appreciated CalibreTDI Ontario 7 February 24th, 2008 07:54
Help Needed! Very Puzzled OmegaRenegade Ontario 10 August 10th, 2006 13:56
Page generated in 0.18922 seconds with 10 queries
[Output: 124.25 Kb. compressed to 103.48 Kb. by saving 20.78 Kb. (16.72%)]
