Old February 7th, 2018, 01:53   #1
Dutchie
TDI(s): A4 B5 1.8t
Default Audi A4 B5 Quattro awx/avf swap...
Bonjour, good day to all.
I was wondering if a 1.9tdi awx/avf fits in My car.
I already know i have to convert My car to drive by wire, and that i Will need a diesel Quattro gearbox.
But whatever about the rest.
Is het harness plug and play, pr do i need a different diesel loom.
Will a b6 gearbox fit My car. Will the B5 diesel Quattro box bolt up to the awx.
I hope to fond soms anders with the help of u Guys!!!
Thanks in advance,
Dutchie
Dutchie is offline   Reply With Quote
Old February 9th, 2018, 12:54   #2
K1Cowboy
K1Cowboy's Avatar
Fuel Economy: 40+ MPG
Your B5 is most likely not a can bus wiring system and your gauges and things are gonna be a challenge to do with an AWX/AVF. The AFN is more of what you would want to use, as it came in the A4 overseas and is not can bus. The AFN even shares the same block as the 1.8T.
K1Cowboy is offline   Reply With Quote
Old February 9th, 2018, 16:12   #3
2many diesels
Being here in the states I am not familiar with the motors your looking at. I just finished an A4 quattro with an ALH. (b5 2001) Except for not being able to work straight through without interruptions, It was a piece of cake...now for tune and injectors.
2many diesels is offline   Reply With Quote
Old February 10th, 2018, 09:55   #4
Dutchie
TDI(s): A4 B5 1.8t
But the afn isnt a pd engine right?
Is it possible to het 250hp with this engine?
Preferably i want to swap to a pd engine.
Old February 10th, 2018, 09:57   #5
Dutchie
TDI(s): A4 B5 1.8t
2001 is a fl right?
So u have canbus then
What power did you het from it?
Old February 10th, 2018, 10:16   #6
2many diesels
Not sure what fl is. There is can buss in this ecu, but it is minimal. When tuned should be around 170 hp 300 tq.
My son is swapping a b5 with a bhw...2 liter pump duese....has more can buss, so we'll see how that goes.
Old February 10th, 2018, 10:36   #7
Dutchie
TDI(s): A4 B5 1.8t
Fl is facelift
The car i have is a pre facelift without canbus.
Does your son have a thread on tdiclub? I Will look in to it
Old February 10th, 2018, 14:38   #8
2many diesels
Ok, yes mine is a facelift, his is not. No thread on the club for either. Done a lot of swaps. Time to document them is just not there
Old February 10th, 2018, 16:27   #9
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
I also have a pre-facelift A4 Avant TDI quattro with AFN engine. Any engine will theoretically go in there, the easiest will be those already found in the A4 / 3B Passat. CANBUS is not an issue to swap if you have the complete wiring harness from a donor car and you have some skills and lots of patience. Good engine for your car could be a BGW/BHW 2.0 PD TDI from the 3BG Passat.
Nevertheless, 250 HP is not too difficult to achieve in an AFN. Someone has posted in the Performance section with 290 HP.
Old February 11th, 2018, 13:21   #10
Dutchie
TDI(s): A4 B5 1.8t
Thanks for the quick reply. The 2.0 TDI engines are pretty scarse even here.
BTW i Just asumed the pd engines are all lots better than conventional TDI engines. Is this treu or not.
And what gearbox is best for it. The 5 speed in My car is way to short, do a diesel gearbox nerds to be swapped as well. But what fits and what abuse can it handle. And is there a easy way to look up the gearbox and Final Gear of My car?
Old February 11th, 2018, 15:34   #11
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
6 speed 01E. Those fitted to the V6 TDI will have tallest ratios, eg GBB.
http://workshop-manuals.com/audi/a4_...os_capacities/
Old February 13th, 2018, 22:09   #12
strangersfaces
Dutchie,
You might consider reaching out to member Frans, a Vendor here at TDI Club, also from The Netherlands:
http://forums.tdiclub.com/showthread.php?t=434593
http://dutchautoparts.com
Many here have purchased their TDI conversion parts (along with many other components) from Frans, with good results. He knows what is needed for successful conversions.
Just a thought...
Lance
strangersfaces is offline   Reply With Quote
Old March 4th, 2018, 23:51   #13
K1Cowboy
K1Cowboy's Avatar
I second that to talk to Frans, he sold me my complete conversion and he is very knowledgeable. I used an O1E from a V6 TDI because it had a taller 6th gear. It works great with a tune that can power the car. The AFN is a VE motor. In my opinion it is more reliable and does not require a lift pump. It's older technology but you can still get a lot of power out of it and parts are cheap and plentiful.
Old March 11th, 2018, 13:50   #14
Dutchie
TDI(s): A4 B5 1.8t
Thanks for the replies about Frans, Will government hun a call tomorrow.
In other light, another question. My car doesnt have canbus. But of i take a canbus engine, Will it run? OR do i need to delete the canbus part...and of i take a canbus engine how far can i go? For example: van i Just take any engine from An A4 b7 OR A6 C6?
AWX or AVF in my 2000 B5 A4? Eivind TDI Power Enhancements 20 June 23rd, 2016 09:23
help audi a4 b7 avf 1.9tdi swap a4b7tdi TDI Conversions 6 December 18th, 2015 23:08
audi a4 2.8 quattro b5 eliasuk98 TDI Conversions 0 December 31st, 2010 03:47
B5.5, 1.9TDI-PD - swap from AVF to AWX, is it wrong? Keisim VW B5 Passat TDIs 3 May 10th, 2010 15:52
Audi a4 1.9Tdi Quattro AVF pd or not? TTQ-A4Q VW MKIV-A4 TDIs (VE and PD) 1 August 17th, 2009 12:15
Page generated in 0.16182 seconds with 10 queries
[Output: 118.84 Kb. compressed to 99.55 Kb. by saving 19.29 Kb. (16.23%)]
