Old February 6th, 2018, 12:48   #1
Lefty
Lefty's Avatar
Fuel Economy: 48.5 MPG
Default Quick question on Transmissions.
I have an 200 Jetta TDi Manual. I am looking at a 2002 TDI Automatic. If I was to buy the Automatic will the transmissions just swap out or is there a lot more to it? Just wondering how hard it is to do I guess. As always Thanks in Advance.
<===Lefty===
2000 GLS Jetta TDI 48.5 MPG 370k and Counting
Lefty is offline   Reply With Quote
Old February 6th, 2018, 12:52   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Swap what to what? Lots of people have done manual conversions on cars originally cursed with an automatic, yes.
oilhammer
www.cardocautomotive.com
Old February 6th, 2018, 13:00   #3
Lefty
Lefty's Avatar
I was thinking of buying the 2002 Automatic and swap my 2000 Standard into it. But only after my 2000 gets to the point of rebuild. Not sure when or if that will be but I can get the 2002 pretty cheap. And it has a lot lower miles than my 370k mile 2000.
<===Lefty===
Old February 6th, 2018, 13:35   #4
oilhammer
oilhammer's Avatar
Yes, you could do that. Is the 2002's transmission bad?
oilhammer
Old February 7th, 2018, 05:44   #5
Lefty
Lefty's Avatar
Well no it isn't bad at this point. I will most likely drive it as is until either my old 2000 Gives out or that tranny gives out. I really like the 2002 it is my favorite color. White........It isn't a GLS like my 2000 but My heated seats went out years ago on it. Almost burned up the car and it burned my wife's coat she was wearing. I just took out the fuse which is also the Cruise control which I never use anyway.
<===Lefty===
Old February 7th, 2018, 12:55   #6
UhOh
UhOh's Avatar
Search on "boertje 01m swap" and you'll get a document that will tell you everything that would be needed for a swap.
Old February 7th, 2018, 16:06   #7
Lefty
Lefty's Avatar
Thanks for the help guy's I went to look at the car today and passed on it. It had a new timing belt on it and sounded Ok but, It had like 1/3 rd the power of my other Diesel. Transmission seemed to shift pretty hard when down shifting also. The CEL was on,The Brake system light was on the Anti freeze bottle looked like the wrong stuff in it, the Seat belt light was on when it shouldn't have been and it also had 4 bald tires and started real hard in 40 Plus degrees out. Passing on it was my only choice.
<===Lefty===
Old February 7th, 2018, 19:25   #8
Ol'Rattler
Ol'Rattler's Avatar
Having a "new" T/B does not mean it was done correctly. With everything else you noted, it probably was done wrong and/or there is hidden valve damage.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Anybody here knowledgeable of automatic transmissions? (Interchangeability question) bherman13 VW MKIV-A4 TDIs (VE and PD) 25 September 17th, 2015 15:54
Question - Which Transmissions will work in ALH Combine17 VW MKIV-A4 TDIs (VE and PD) 2 October 30th, 2013 13:49
Quick coolant fill up question! Quick! Tybrad TDI 101 10 July 26th, 2007 10:13
question for members with auto transmissions gleep TDI 101 17 December 18th, 2004 18:31
Page generated in 0.15847 seconds with 10 queries
[Output: 87.31 Kb. compressed to 74.85 Kb. by saving 12.46 Kb. (14.27%)]
