Old February 6th, 2018, 14:35   #16
fouillard13
ive done the big 3 already.
my clutch oil has to get changed, guaranteed.
fouillard13 is offline   Reply With Quote
Old February 6th, 2018, 15:05   #17
Cptcrnch
Originally Posted by fouillard13 View Post
the lower EGR pipe has been fully blocked off.
plus, if that tube was broke, which mind had been, wouldnt you lost all boost/turbo, like mine did when it broke?
Whoops. It's been a long day at work lol. Mine was only cracked. Enough where it would leak some exhaust smell but not where I was losing power. I only detected it by the high pitched whistle sound that it made.
Cptcrnch is offline   Reply With Quote
Old February 6th, 2018, 18:15   #18
maxmoo
I find that the most common places for these exhausts to start leaking are:
1) downpipe breaks right behind the cat
2) the flex joint on the downpipe
3) one of the hanger welds rusts through the pipe and breaks off leaving a hole.
maxmoo is offline   Reply With Quote
Old February 6th, 2018, 18:25   #19
PB_NB
PB_NB's Avatar
Mine has an EGR delete and a race pipe. The smell I get is coming out the tail pipe.
Probably needs a few adjustments to clean up the smell of the exhaust. Maybe the last batch of diesel I got isn't that great.
If I leave the fan off, I don't notice it in the car but the exhaust travels around the neighbourhood.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old February 6th, 2018, 20:43   #20
Fahrvegnugen
The exhaust will always have a strong odor. I had missing body plugs in spare wheel. Replaced them and that really helped. Also helps to scrape windows in the fresh subzero air, and start it after! wait for the 5 second shutter to smooth out, then drive it. Within 5 minutes of driving it blows warm air. The interstate Amg battery has been working great.
Fahrvegnugen is offline   Reply With Quote
Old February 7th, 2018, 10:56   #21
UhOh
UhOh's Avatar
Originally Posted by oilhammer View Post
Interstate seems to have suffered in longevity in the last few years, and their prices just kept going up. So we switched our batteries around a bit. Most VAG products get OEM or the AC-Delco branded whatever-it-is (they just put their sticker on them).
Sigh, just picked up a new battery from VW: blue Golf's battery was crapping out- 84 month battery and it's now 96 months old; put it in the wife's car and put her battery in the blue Golf. Parts guy said they're Interstates.
fouillard13, make sure your injectors aren't leaking. My car has had a couple of injectors loosen up (noisier AND smelly).
Old February 8th, 2018, 04:21   #22
JB05
Fuel Economy: 43/41/40
I'll sometimes let my Golf idle for a few minutes mostly for the sake of the ATF. 4 to 5 upshift is smoother when I do. I'll also let it idle while clearing snow or frost for a couple of minutes.
JB05 is offline   Reply With Quote
Old February 8th, 2018, 04:35   #23
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
No they aren't. Not really. Interstate is JCI's retail brand. JCI also makes or carries other brands, like Varta and Enertec and even some Energizer stuff. They are likely dropped off at the dealer by an Interstate truck, just the same as at Toyota and MB dealers (and others). JCI is the largest distributor of batteries in the US.
oilhammer
www.cardocautomotive.com
Old February 8th, 2018, 08:49   #24
UhOh
UhOh's Avatar
Thanks, Brian.
Old February 8th, 2018, 22:01   #25
crawdaddy
crawdaddy's Avatar
I had the same problem, when ever I was stopped at a light, with fan running, I would get a diesel exhaust fumes smell.
Less than $60CAN to DIY repair.
So check the down pipe, that's most likely place where it's leaking.
crawdaddy is offline   Reply With Quote
Old February 9th, 2018, 08:22   #26
UhOh
UhOh's Avatar
^^^ Yeah, odds are that this is it. Mine was leaking (I got a new down pipe, though) AND at the same time I had one of my injectors loosen up; the added noise from the injector I'd thought to be a worsening of the down pipe leak. Moral of story: sometimes a problem can be due to multiple issues.
Strong diesel fumes in the cabin sschnath VW B5 Passat TDIs 28 February 27th, 2013 07:00
My Car Stinks. Cabin Odor TomatoPie TDI 101 1 November 14th, 2011 05:35
diesel fumes in cabin gsea TDI 101 11 July 26th, 2010 14:54
Diesel Fumes In Cabin Part 2 Kato TDI 101 25 January 6th, 2009 16:02
Diesel Fumes in Cabin? yatzee Ontario 16 December 22nd, 2008 21:13
Page generated in 0.16499 seconds with 10 queries
[Output: 106.42 Kb. compressed to 90.34 Kb. by saving 16.08 Kb. (15.11%)]
