Old February 5th, 2018, 11:38   #1
Homebrew01
Default help decode air bag light codes
pulled the following codes off my beetle. I was hoping it would say this is your issue but not the case. Any help is appreciated.
65535 internal control module memory error
00532 supply voltage B+ 07-10 signal too low- intermittent
01299 diagnostic interface for data bus (j533) 49-10 no communications
Homebrew01 is offline   Reply With Quote
Old February 5th, 2018, 11:55   #2
jettawreck
jettawreck's Avatar
What tool did you use to pull/read the codes?
First thing is to clear them and see which ones come back (or not).
2004 Cadillac SLS (wife's)
Old February 5th, 2018, 11:57   #3
Homebrew01
vcds. cleared and came right back
Old February 5th, 2018, 12:08   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Start here with diagnosis, look for some common stuff.
Ross-Tech Wiki
At first glance it looks like some wiring issues.
Old February 5th, 2018, 12:09   #5
Vince Waldon
Vince Waldon's Avatar
Can you clarify what you mean by this, and what symptoms the car is exhibiting? Dunno that those are air-bag codes?
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old February 5th, 2018, 12:15   #6
Homebrew01
the air bag light is always on.
Old February 5th, 2018, 12:47   #7
BobnOH
not-a-mechanic
Did a bag deploy or did you replace any components?
Code seems pretty straight forward, it's either the wiring or the module. The air bag system is finicky.
Old February 5th, 2018, 14:32   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
J533 is the CAN Gateway (in the Cluster) on that car. You may just have a bricked SRS module.
Check the CAN Gateway and see if it has a communication DTC for the SRS alone, or anything else.
oilhammer
www.cardocautomotive.com
Old February 6th, 2018, 04:36   #9
JB05
Fuel Economy: 43/41/40
Several years ago I had to change the clock spring on my Golf. The air bag light was on and the horn did not work. I don't recall the DTC's.
JB05 is offline   Reply With Quote
Old February 7th, 2018, 09:16   #10
Homebrew01
the car has a clean title. No air bag deployment that I know of and the horn works so that should rule out the clock spring right? I googled the codes and the big one, said it is for the air bag control module. Is it common for the modules to crap out?
Battery light flashing, air bag light on, after alternator pulley change thirdgenracer86 TDI 101 3 February 11th, 2012 21:16
Seat belt light stays on, no air bag light. cjharris02892 TDI 101 1 August 30th, 2010 16:11
Air Bag Codes Translation Mass. Wine Guy VW MKIV-A4 TDIs (VE and PD) 0 April 29th, 2008 08:23
B5 Audi Air Bag and other codes ptempel General Automotive 0 March 27th, 2007 06:36
decode the secret codes? PaJames VW MKIII-A3/B4 TDIs 0 August 20th, 2006 11:40
Page generated in 0.14990 seconds with 10 queries
[Output: 96.04 Kb. compressed to 81.52 Kb. by saving 14.52 Kb. (15.12%)]
