Old February 5th, 2018, 09:23   #1
Mawcus
Fuel Economy: 41 mpg
Default Will plugging in a new Camshaft Position Sensor fix a G40 No Signal Fault Code
Been troubleshooting a G40 Camshaft Position Sensor No Signal fault code. Wondering if just plugging in a brand new sensor as a quick test will make the fault code go away or does the CPS need to be completely installed and in place for the fault code to go away.
Mawcus is offline   Reply With Quote
Old February 5th, 2018, 11:25   #2
JB05
Fuel Economy: 43/41/40
Yes, it would have to be installed properly. It's a hall -effect type sensor according to the PDF that was linked here just yesterday. The ears on the cam sprocket is what triggers the signal.
JB05 is offline   Reply With Quote
Old February 5th, 2018, 21:45   #3
Franko6
First, make sure you aren't out of range. The cam positioner will go '0', no read if that is the case. Also, BEW's are notorious for losing the ground from the cam position sensor to the ECU. It's the brown wire.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
TB Change No Start and VCDS Code P3008 19464 - Camshaft Position Sensor (G40) armyschus VW MKIV-A4 TDIs (VE and PD) 2 July 15th, 2017 18:18
Camshaft Position Sensor (G40): Signal Out of Range arron9999 VW B5 Passat TDIs 5 December 28th, 2016 18:37
16725 - Camshaft Position Sensor (G40) P0341 - 000 - Implausible Signal lirunaway VW MKIV-A4 TDIs (VE and PD) 0 June 2nd, 2012 21:50
Camshaft Position Sensor (G40): No Signal lirunaway VW MKIV-A4 TDIs (VE and PD) 1 August 11th, 2011 18:55
19464 - Camshaft Position Sensor (G40): Signal Out of Range P3008 - 000 coalminer16 TDI 101 3 August 2nd, 2010 22:24
Page generated in 0.11272 seconds with 10 queries
[Output: 56.93 Kb. compressed to 51.67 Kb. by saving 5.27 Kb. (9.25%)]
