mariokordi94
forgive me for a bad english, but you'll wonder what the car problem is hello here I come from Croatia so I advised my colleagues to log in to this forum that here are great fans tdi and recently i bought the passat b5 1.9 tdi 66kw aha motor but i have the next problem car at low temperatures -1 to -10 super start off on the tooth but it happens that at a temperature of 0 to 7.8 degrees turns longer than 10 seconds, even if not then it starts to think that throws gray smoke a bit and falls below -1 no smoke just heater I was warming up the trap and when it is warmed up, the engine starts without a break, can try the temperature sensor in the morning and then some people mention that the sensor and the ECU give a small amount of start-up fuel, and when it gets a bit more startup, the throttle throws a gray smoke engine when it raises the temperature for quiet The fastest speed is 170,175 km / h tested
