Old February 4th, 2018, 15:03   #16
hmr_tym
TDI(s): '03 Golf
Battery that is in it now is out of my perfectly running bronco. Battery that was in it is most likely toast. I've already addressed that. The current battery is now turning over the motor, so original problem addressed. My issue is now the starter smoking and struggling.
hmr_tym is offline   Reply With Quote
Old February 4th, 2018, 15:04   #17
hmr_tym
TDI(s): '03 Golf
Originally Posted by Tdijarhead View Post
Cables good, swap starter again.
Will do
Old February 4th, 2018, 15:05   #18
Mongler98
Originally Posted by hmr_tym View Post
.alh.
water pump is on the timing belt. a typical failure is a siez up on the pump. Get the the timing belt, im sure you did this already to make sure it was at TDC on all the marks right? take the belt off, see if the pump is locked up. Maybe you did not check TDC and your hitting a bent valve as the timing belt might be trashed.
Point is you need to start at the timing belt, then the crank, and if everything looks 100% perfect on the main bearings then move on to try and getting it to crank. otherwise your wasting your time
Old February 4th, 2018, 15:07   #19
Mongler98
we just dont want you chasing after parts when the engine could be fubar. Sat for 2 years after running dry on oil is almost a sure sign of a future engine tear down and rebuild.
Old February 4th, 2018, 15:53   #20
hmr_tym
TDI(s): '03 Golf
put the old starter back in. Fired right up.
Old February 4th, 2018, 15:55   #21
Mongler98
sooooooo, wth? bad connection? dead battery? I highly suggest you go diagnose the internal condition of the engine before putting large miles on it.
Old February 4th, 2018, 15:55   #22
hmr_tym
TDI(s): '03 Golf
Looks like a battery/starter circuit issue the whole time. Thanks for your help. Just gotta throw the serp belt back on and start checking everything over.
Old February 4th, 2018, 16:40   #23
Tdijarhead
Good deal. Glad you got it.
Tdijarhead is offline   Reply With Quote
2006 tdi tachometer not working wont crank justinj229 TDI 101 3 April 18th, 2014 21:23
1999.5 Jetta TDI wont crank/start Tman56 TDI 101 12 November 19th, 2013 14:10
1998 Jeta tdi wont crank over no start 2nsane2005 VW MKIII-A3/B4 TDIs 16 April 24th, 2011 12:26
2005 tdi wont crank over phonse81 VW MKIV-A4 TDIs (VE and PD) 8 March 14th, 2011 17:44
Car Wont crank....help!!!!! ausTDIn VW MKIV-A4 TDIs (VE and PD) 12 January 19th, 2007 20:19
Page generated in 0.11843 seconds with 10 queries
[Output: 82.18 Kb. compressed to 70.85 Kb. by saving 11.33 Kb. (13.79%)]
