Old February 4th, 2018, 11:43   #1
odeanono
Default My fuses are confused?
I pulled out my owners manual on my '06 Jetta TDI BRM to find the fuse on my accessories power outlets. The spots they are supposed to be are empty but these had been working properly. The Fuse chart mostly, but not exactly matched mine. Is there another design for the fuse box? About a dozen of them are in different places or missing from where the chart puts them. A couple are different sizes. I have never seen this. There is no chart on the cover only in the manual and it is not accurate.
odeanono is offline   Reply With Quote
Old February 4th, 2018, 12:05   #2
jettawreck
jettawreck's Avatar
Diesels are a bit different than the gassers and depends sometimes on equipment level(s). The manual isn't specific to a certain vehicle, just sort of covers the typical.
I'm not sure about the Mk5 fuse list available here, but I've printed off the MklV fuse list to put in all my VWs.
2004 Cadillac SLS (wife's)
Old February 4th, 2018, 12:15   #3
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Having no fuse chart in the car's manual that accurately matches the actual circuitry in the car is what the manufacturer has given us purchasers. You have hit the nail squarely on the head.
The fuse panel door has a sticker with symbols on it that if you are able to figure out what the symbols represent, you will be close in determining what the fuse is for. But beware, some circuits have multiple fuses (case in point, A/C in a MKIV uses fuses 5, 16, 25 and a green fuse in a holder on the top of the battery).
So, one must buy a Bentley manual that *may* have the fuse wiring diagrams you need, or ask here and maybe you will get lucky.
Sorry I can't help you as I have no data to review. I just wanted to let you understand the situation.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old February 4th, 2018, 12:50   #4
odeanono
Yes, I figured there would be a sticker too. Nothing. I verified I have an 06/06 manufacture date and an 06 manual. I checked fuse box B under the hood and the same thing there! No sticker and the manual diagram is off enough to make it useless. Anyone have an alternate diagram?
Old February 4th, 2018, 12:52   #5
aja8888
aja8888's Avatar
Try Googling it (2006 MKV TDI) and look at the Google Images tab. I found one that way.
Old February 4th, 2018, 13:18   #6
JETaah
Fuel Economy: 53 max, 42 min, average 46
Just ran into this with a 06/06 production date BRM Jetta. The actual fuse layout is closer to the 2007 Bentley version wiring diagram for BRM. And even then there were fuses in alternative location where the diagram said that the space was " not used". That is where the one that I was looking for wound up being.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is online now   Reply With Quote
fuses jtskir222 VW Passat Family (NMS and B7) TDIs (2012+) 9 December 8th, 2016 11:54
fuses Cooleycorporation VW Touareg TDIs 1 May 30th, 2014 16:44
Fuses psaboic VW Passat Family (NMS and B7) TDIs (2012+) 6 September 1st, 2013 10:52
Where are the Fuses? jgilliam1955 TDI 101 2 April 21st, 2007 18:25
Fuses Blacky TDI 101 0 December 23rd, 2003 10:30
Page generated in 0.16126 seconds with 10 queries
[Output: 76.91 Kb. compressed to 67.49 Kb. by saving 9.42 Kb. (12.25%)]
