Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old February 4th, 2018, 10:43   #1
Andyinchville1
Default Optimal intake temps for fuel economy
HI All,
I was wondering what you all felt the optimal intake temp was for the best fuel economy.
I ran across a chart from Cummins with their recommended intake temps for their stationary engines in generator applications (wished I saved the link but could not find it now) and it is possible to have intake air temps too hot or too cold.
In the colder months I installed a grill block in front of the intercooler cold air intake so I can keep intake temps more or less in the 65 to 95 degree range (of course depending on outside temps and boost levels)....Im seeing that the engine warms up faster too when blocking the air flow to the intercooler
I had though about rigging a way to manually regulate the amount of air hitting the intercooler to optimize intake temps for fuel economy....I suppose a high tech automated system would be the best but may be hard to engineer).
In the summer (or warm months) I don't block the intake to the intercooler at all since ambient is not low enough to be too cold.
Any thoughts?
Andrew
Andyinchville1 is offline   Reply With Quote
Old February 5th, 2018, 19:44   #2
[486]
TDI(s): 02 golf ALH
I ran mine without water in the intercooler for a while (intercooler is welded up inside the intake manifold, and the exhaust manifold will radiate quite a bit of heat into it, couldn't rest your hand on it after city driving) and it'd smoke white once fully hot, no trouble with that once I got water flowing through it.
I haven't run into issue with cold intake air yet, other than an interesting aside noticed while datalogging.
If you let it overrun from 75mph to a stop in -10 deg F, downshifting to to keep the revs up, your coolant temp will drop by 10 deg C, with the heater blower motor turned off.
ETA: I'd bet on colder intake air being better for efficiency just about all the way down to below where your coolant would freeze. It's not like a gas motor where the fuel has to be vaporized.
Interested in the math of what the heat of compression does with cooler intake air, as there's more airmass in there, but it's got a lower starting temperature...
[486] is online now   Reply With Quote
Old February 6th, 2018, 00:55   #3
shakescreek
Good discussion of iat's here.
http://ecomodder.com/forum/showthrea...not-21502.html
shakescreek is offline   Reply With Quote
Old February 6th, 2018, 07:19   #4
turbobrick240
turbobrick240's Avatar
It's difficult to differentiate the IAT effects from ambient temp effects, since there is generally a pretty strong correlation. The ideal IAT(not ambient) for fuel efficiency will probably also vary quite a bit based on load. When both ambient temps and IAT are quite low, the real benefit should come from blocking the radiator, rather than the intercooler.
Old February 6th, 2018, 08:48   #5
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Exclamation Excellent thread
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
Old February 6th, 2018, 09:43   #6
whizznbyu
TDI(s): 2005 Variant
Fuel Economy: 44 mpg @ 70 MPH. 46 mpg @ 55 MPH
My B5 is happiest when the ambient temperature is between 75-85 degrees F. Fuel efficiency is down 10-15% with current temps just above freezing. I don't know how to tastefully put a shroud in front of the radiator to help bring engine temperatures up
whizznbyu is offline   Reply With Quote
Old February 7th, 2018, 04:57   #7
tedd
pipe insulation fitted tightly around each grill slat
tedd is offline   Reply With Quote
How much smoke is optimal for fuel economy? Sbeghan TDI Fuel Economy 26 February 17th, 2013 22:41
In a perfect world... optimal environmental conditions for economy? twigless TDI Fuel Economy 62 January 18th, 2008 20:15
what is optimal speed for good fuel economy ? duuudeman TDI Fuel Economy 9 June 27th, 2003 18:28
EGR adaptation + cold temps = what to fuel economy? dropFROG TDI Fuel Economy 2 January 22nd, 2003 08:43
fuel and air intake temps: were are they taken? Karl Roenick VW MKIV-A4 TDIs (VE and PD) 4 May 7th, 2001 11:53
Page generated in 0.14539 seconds with 10 queries
[Output: 80.17 Kb. compressed to 69.71 Kb. by saving 10.46 Kb. (13.05%)]
