Old February 3rd, 2018, 17:45   #1
Garageman1965
Fuel Economy: 22 city
Default Rear door handle
I replaced the actuator on the left rear door on my 05 passat tdi wagon and it worked fine for several days and today the cable from the actuator to the outside door handle popped out of the door handle. I put it back in and it popped out several more times. Any clues what might be my issue with it???
Garageman1965 is offline   Reply With Quote
Old February 3rd, 2018, 21:25   #2
Mongler98
did you replace that part or is it the same part was in there that is popping out, VW is notorious for bad windows strapping clamp and lines popping out like this in door cards. Sounds like its bent and or worn out. try bending the clip that holds it in place a bit to make it tighter, maybe a ziptie too, this usually does the trick for issues like this.
Old February 4th, 2018, 10:56   #3
Garageman1965
It’s not really a possibility it’s betw the actuator and outer door handle and it’s about 3” long fits into a groove on the door handle tried to post a picture but I don’t know how to On this forum
Old February 6th, 2018, 20:03   #4
muzy
TDI(s): 02 jetta TDI
Fuel Economy: in process
Instale with tension on the cable. Is your door handle secure or loose?
Cheers
muzy is offline   Reply With Quote
Replaced both rear door... need door handle gaskets JohnTso VW MKIII-A3/B4 TDIs 5 October 24th, 2014 05:15
Change rear door handle Audiman TDI 101 1 April 17th, 2013 05:04
rear door handle re&re redlinedave Ontario 8 July 11th, 2012 18:15
help! Rear door handle pulled out from doorframe ncsucarjock TDI 101 0 September 25th, 2006 06:02
Rear door handle problems kc5enu VW MKIV-A4 TDIs (VE and PD) 0 March 9th, 2006 15:16
Page generated in 0.12577 seconds with 10 queries
[Output: 61.07 Kb. compressed to 54.73 Kb. by saving 6.33 Kb. (10.37%)]
