Old February 5th, 2018, 06:33   #16
maxmoo
Some valid points Jason but I don't think a 240watt oil pan heater, mounted on the outside of an oil pan, can "coke" any oil and certainly not the modern synthetic oils that are engineered to run at MUCH higher temps, in a turbo bearing for instance.
maxmoo is offline   Reply With Quote
Old February 5th, 2018, 08:04   #17
crawdaddy
crawdaddy's Avatar
Originally Posted by SilverGhost View Post
Biggest draw back of oil pan heaters was coked oil and, being on the bottom of the oil pan.
At what temp of the oil does it get coked or cooked?
crawdaddy is offline   Reply With Quote
Old February 6th, 2018, 08:47   #18
SilverGhost
SilverGhost's Avatar
I remember when VW used to sell those oil pan heaters. The few pans that I took off were pretty nasty in the bottom where the heater was attached.
Don't get me wrong, oil pan heaters have their place, but since most are not thermostatically controlled its up to the operator to use good judgement. Leaving it plugged in all night to keep the engine warm will not do good things to the oil.
And your correct - good modern synthetic shouldn't break down like the older Dino oil, but also reduces the need for the heater in the first place.
If I lived somewhere like Alaska or Yukon I would have pan heater on engine, trans, coolant heater like FrostHeater, and battery warmer.
Jason
SilverGhost is offline   Reply With Quote
Old February 8th, 2018, 11:54   #19
UhOh
UhOh's Avatar
Maybe control the pan heater using a temperature controller? I use these for various things (controlling an egg chiller- chest freezer, and turning on/off a heat lamp in my pump house):
http://cgproducts.johnsoncontrols.co...PDF/125188.PDF
Really handy.
Old February 8th, 2018, 12:39   #20
belome
Fuel Economy: 47'ish
This whole thread seems pretty absurd. A frostheater or equivalent will make your car start like it is the middle of the summer in Florida. The oil has to have some heat in it just from the coolant being hot so it isn't like molasses when you start your car. The battery barely works to roll the car over so adding battery blankets seems unnecessary.
Why try to fix what isn't broken... unless of course you live in the Yukon.
Heck, half the people around here talking about frostheaters see -0F and below about 3 times a year.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is online now   Reply With Quote
Old March 26th, 2018, 18:48   #21
DieselSport15
This is what I'm hoping to be a fix for my North Dakota cold starts! Wolverine pan heater, model 25 (250watts 6" x 2.5") I just cut out the plastic on the oil pan cover because I didn't want to risk it melting and I also cut out a portion of the insulation out of the splash guard. https://ibb.co/fPX9qS
DieselSport15 is offline   Reply With Quote
Old March 26th, 2018, 20:10   #22
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
Be careful of those oil pan heaters, I've seen several posts regarding them causing fires due to proximity to the plastic skid pans.
Installing my webasto this weekend. No more cold engine starts. Was looking at the new espar unit but got a webasto for next to nothing
Dannyboy is offline   Reply With Quote
Old March 26th, 2018, 21:35   #23
Camperbob
I'm thinking about an oil pan heater myself, my Jetta already has a coolant heater. I've always used both coolant and pan heaters here in Montana, and during my time in North Dakota.(as cold as the Yukon) ha.
I've also seen heating pads RTV'd to aircooled aircraft piston engines.(oil pan and top of case.)
Camperbob is offline   Reply With Quote
Old March 26th, 2018, 22:19   #24
Nevada_TDI
I am an new owner of a Frostheater, and I am glad I finally purchased one. We are having an exceptionally long and cold winter here in Northern Nevada; four hours seems to be the perfect amount of "preheat" and this morning I forgot to turn the heater on, big puffs of smoke and a "grumpy" engine as well.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old March 27th, 2018, 04:39   #25
Dannyboy
Dannyboy's Avatar
I'm not doubting they do a job, however they don't get hit by road debris such as ice chunks which knock/rip them off on aircraft. I removed mine because I bought a frostheater a while back and found it invaluable for cold morning winter starts for my mk4.
Old March 27th, 2018, 08:56   #26
DieselSport15
My pan heater is completely covered by the lower "splash guard" so no chance of it get hit by debris and ripping off. I am slightly concerned/cautious though about it somethow causing a fire. Thats why I made that cut out and removed some of the insulation in the splash guard.
Old March 27th, 2018, 12:09   #27
SilverGhost
The year or so I spent in Montana I used a Frostheater. That made for wonder full toasty starts even in -40F to -60F mornings. No pan heater needed, proper oil took care of the cold start lubrication. 163k miles before driver cut me off and totaled it, the car drove great and pulled camper and uhaul without wimper.
Jason
Old March 27th, 2018, 12:30   #28
belome
Those must include wind chill? I know it gets cold in Montana but how many -60F mornings did you see?
Interesting read:
http://montanakids.com/facts_and_fig...e_Extremes.htm
Old March 27th, 2018, 14:54   #29
Dannyboy
Dannyboy's Avatar
Ask the guys that buy panzer plates for their vehicles why they choose to spend $400 on a skid plate
Old March 27th, 2018, 17:31   #30
maxmoo
The reason that these oil pan heaters started fires was....
The pan heaters are peel and stick and come with a small tube of rtv which is only meant to seal around the edge of the heater to keep moisture out.
Some guys did not read the instructions and used the rtv to simply glue the heaters on to the pan. When the heater warmed up the paper peeled off and the heater fell down on the plastic skid pan.
I have used literally dozens of these pan heaters over 25 or more years and have never had one fall off or start a fire.
Jetta 2009 TDI Block Heater/Tank Heater carrot TDI 101 12 January 12th, 2016 18:42
Engine Pre-Heater / Block Heater Recall? stringbeanbowler VW Passat Family (NMS and B7) TDIs (2012+) 3 December 16th, 2015 13:32
ZeroStart Frost Heater/Block Heater $40 Purplecomputer226 Private TDI Items for Sale/Wanted 3 August 27th, 2011 08:04
zerostart heater 2250 watt NEW block heater JohnyRRR Private TDI Items for Sale/Wanted 14 October 28th, 2010 19:10
oil reservoir heater or engine block heater rmunsen VW MKIV-A4 TDIs (VE and PD) 4 November 7th, 2002 19:25
Page generated in 0.16461 seconds with 10 queries
[Output: 127.93 Kb. compressed to 106.98 Kb. by saving 20.95 Kb. (16.38%)]
