Old February 2nd, 2018, 10:51   #1
Garageman1965
Fuel Economy: 22 city
Default ‘05 tdi Glow plugs
I have an ‘05 passat tdi wagon and this morning it wouldn’t start. Air temperature was 4* F. No engine codes or lights on for check engine. But it cranked and tried to start. Bad glow plugs or relay. First time it’s been this cold so I’m not sure if they’ve ever worked since I purchased the car last summer. Just need a good starting point. Thanks.
Garageman1965 is offline   Reply With Quote
Old February 2nd, 2018, 11:04   #2
JB05
Fuel Economy: 43/41/40
How long does the glow plug light stay on. Should be 6 seconds below 40F; at least it's that way for the MKIV. In fact the pre glow is ~ 23 seconds if IIRC; meaning you can wait an extra 10 seconds or so after the gp light goes out before cranking. A faulty glow plug should turn on the check engine light. Is your fuel filter full or empty; in reference to the in-tank fuel pump? Should be full.
JB05 is offline   Reply With Quote
Old February 2nd, 2018, 11:17   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Search here for the BEW/BHW glow plug fiasco.
You need to find out which plugs your car has in it now, and which software version it has. You may need to update or change something.
oilhammer
www.cardocautomotive.com
Old February 2nd, 2018, 11:43   #4
Garageman1965
It glows for 2 or 3 seconds.
Old February 3rd, 2018, 10:20   #5
JB05
I wasn't sure if the OP's BHW was included in the GP recalls.
Old February 5th, 2018, 04:40   #6
oilhammer
oilhammer's Avatar
The BEW, BHW, and the BKW (the BKW is one of the V10s in the T'reg) are all under the same glow plug saga.
oilhammer
Glow plugs don't work, new plugs, new harness, new relay, good fuses Matthewsz TDI 101 19 February 9th, 2016 07:42
Glow Plugs here Glow Pugs there Glow Plugs every where tugman3461 VW MKIV-A4 TDIs (VE and PD) 17 December 3rd, 2010 19:38
Dealer: VW TDI's do not run Glow Plugs in after-glow mode-- start-up only SootFoot VW MKIV-A4 TDIs (VE and PD) 2 August 5th, 2009 18:25
05 Passat Wagon GLS TDI Glow Plugs ozpassatwagon05 VW B5 Passat TDIs 9 November 23rd, 2008 21:26
Please help -tdi glow plugs diablokicks VW MKIV-A4 TDIs (VE and PD) 5 December 24th, 2006 14:55
Page generated in 0.08407 seconds with 10 queries
[Output: 72.18 Kb. compressed to 63.10 Kb. by saving 9.08 Kb. (12.57%)]
