Old February 8th, 2018, 08:24   #16
[486]
TDI(s): 02 golf ALH
broken link
https://www.youtube.com/watch?v=4OKRRAkmX3M
looks like it
[486] is offline   Reply With Quote
Old February 8th, 2018, 13:34   #17
martin33100
TDI(s): VW T5 2.5
Originally Posted by [486] View Post
That's the correct link for it after the filter, has about half the flow in comparison.
When I finnish my current shifts I will collect a new filter and retest the flow after the filter.
martin33100 is offline   Reply With Quote
Old February 12th, 2018, 13:55   #18
martin33100
TDI(s): VW T5 2.5
It may have been a faulty tandem pump leaking oil into the fuel return, cut the old filter open and it was full of oil.
Old February 12th, 2018, 19:52   #19
[486]
TDI(s): 02 golf ALH
fuel in video does not look oil contaminated, one would think it would be in the return fuel to the tank if it were in the fuel rail, not knowing the details of the fuel loop.
maybe algae in tank?
Old February 13th, 2018, 06:41   #20
martin33100
TDI(s): VW T5 2.5
It does look like oil and carbon in the filter, the fuel return from the cyl head runs back through the filter because it has an in built thermostat. This thermostat doesn't allow the fuel to return to tank when the fuels is cold in winter.
As it's been cold recently the fuel return would have been going back through the filter and back into the tandem pump hence the oil in the filter.
I had a spare tandem pump so swapped them yesterday.
I know a guy that owns a VW garage and he said it's actually quite common to get this problem with failing tandem pumps if the vehicle has a 4 connection fuel filter with built in thermostat.
Tandem Pump has a pressure relief valve? cactus13 VW MKV-A5 Golf/Jettas 0 June 1st, 2016 12:55
Tandem Pump Supply Pressure andymk4 VW MKIV-A4 TDIs (VE and PD) 2 April 24th, 2013 07:05
Fuel pressure pre-tandem pump timbomfg TDI Power Enhancements 4 February 27th, 2013 10:48
Tandem pump pressure findings Bobby Singh TDI Power Enhancements 9 April 26th, 2011 14:08
Checking Tandem Pump Pressure? 20vK VW MKIV-A4 TDIs (VE and PD) 2 January 14th, 2008 01:16
Page generated in 0.15127 seconds with 10 queries
[Output: 71.63 Kb. compressed to 63.61 Kb. by saving 8.02 Kb. (11.20%)]
