Old February 2nd, 2018, 04:20   #1
martin33100
TDI(s): VW T5 2.5
Default Tandem Pump pressure under load?
Hi guys, just wondered what kind of pressure a PD tandem pump should deliver under load, I have read somewhere it's around 7.5bar at 2000rpm.
I had my T5 2.5 dyno'd a week ago as I had fitted a new ex manifold and now the AFR is very lean.
At full load and higher RPM the fuel pressure drops to around 4bar but I never looked at it in detail when the AFR was fine so I don't know if this is low or not?.
One of my digital gauges picks up tandem pump fuel pressure but I may double check it with a gauge.
martin33100 is offline   Reply With Quote
Old February 2nd, 2018, 08:48   #2
[486]
TDI(s): 02 golf ALH
How is inlet pressure to the tandem pump? If it is going into vacuum you can't rightly blame the tandem pump itself. Might be time for a bigger in tank pump, filter and lines.
it should be around/above 100 psi rail pressure, yes. Otherwise you don't get good element filling and it stops making power.
[486] is offline   Reply With Quote
Old February 2nd, 2018, 23:13   #3
martin33100
TDI(s): VW T5 2.5
I will disconnect the tandem pump feed hose and force on the in tank lift pump via vagcom and measure what's comeing out.
I am guessing it should hold this pressure when under full load?, it holds 100psi when reved and when driving normally but it drops off when you are on full load.
I am going to put on a oil filled gauge to monitor the pressure, currently using one of the digital gauges on my dash but even though there is a snubber valve fitted the fuel pressure still changes very quickly.
Old February 3rd, 2018, 00:11   #4
Festa
TDI(s): Vw t5 van
What would you suggest? any recommendations?
The problem with this 5 pot engine is the restrictive nature of the port so they don't flow well It's also a fact that the single fitting of the injector to the head is a weak spot as the injector rocks in it's bore and so suffers from fuel in oil.
Have you sent away another oil sample for testing before looking else where Martin?
I know you have another tandum pump that you could try
Festa is offline   Reply With Quote
Old February 3rd, 2018, 02:24   #5
martin33100
TDI(s): VW T5 2.5
Yes I do have my original tandem pump but the current one that is fitted is the one I got from you.
The OE VW one is LUK but you can buy the Pierburg ones for around 270.
The fuel pressure under load may have always been slightly low but I honestly can't rember what it was, I only started looking at it recently after my van was dyno'd and had a very lean AFR, the only part that has been changed is a new ex manifold made of slightly thicker material.
Old February 3rd, 2018, 09:23   #6
[486]
TDI(s): 02 golf ALH
I'm talking out my ass, captain. Never worked on any PD motor.
Just trying to help along the diagnostic process, as the guy with his hands on the car's really the only one that can find his own issues.
I'd ditch the tandem pump and run an EFI pump in the tank from a gas motor golf/jetta run into a bosch 044 to bump the pressure up, like fords used to do.
External pressure regulator holding 100-150 psi in the rail, if one isn't already integrated into the return.
but that's my woefully uneducated solution to a problem he may well not even be having
Old February 3rd, 2018, 11:26   #7
martin33100
TDI(s): VW T5 2.5
I ran a Bosch 044 on my Westfield track car but the fuel pressure was only 4bar, also a tandem pump is required to run the vacuum system for the brake servo and turbo boost control.
Old February 3rd, 2018, 12:11   #8
martin33100
TDI(s): VW T5 2.5
Did a little video of the fuel pressure dropping when on full load.
https://m.youtube.com/watch?v=DBONOzso09Y
Old February 3rd, 2018, 23:53   #9
[486]
TDI(s): 02 golf ALH
My thought is feed the 044 with another pump in the tank.
All the 044 sees is inlet and outlet pressure, no atmospheric reference, so it's gotta just add that 4 bar or thereabouts atop what you feed it.
Electric vacuum pumps are easy to find in the junkyard. Heck, some mk4's even came with them mounted down by the steering rack.
Old February 5th, 2018, 01:02   #10
Rub87
sure but they are not meant for 100% duty cycle.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old February 5th, 2018, 05:51   #11
martin33100
TDI(s): VW T5 2.5
If the fuel system is working correctly then the Tandem pump should have no issues in supplying a good fuel pressure under load.
When my van was first mapped 15 months ago by Bobby the AFR was spot on, now it is very lean and all I have changed is my exhaust manifold for one made of thicker material but the ID may have gone up by 1mm.
I am sure my van held better fuel pressure under load before but I can't be sure what it was.
Old February 5th, 2018, 13:25   #12
Festa
TDI(s): Vw t5 van
When was the last time you changed the filter? the fuel isn't as good as it used to be it could just be blocking up and restricting flow
Old February 5th, 2018, 17:29   #13
martin33100
TDI(s): VW T5 2.5
The fuel filter was changed Jan 2017, I will check the flow over the next few days.
Old February 5th, 2018, 18:38   #14
[486]
TDI(s): 02 golf ALH
there you go, as said, you're the only one that can do the diag
stick a pressure gauge on the tandem pump inlet
go for a rip
no inlet pressure when loaded means supply issue (filter, the inlet sock in the tank, lift pump, gelled fuel, etc...)
small pressure drop when loaded means issue is elsewhere
Old February 8th, 2018, 04:21   #15
martin33100
TDI(s): VW T5 2.5
I have done a quick flow test before and after the filter and it looks like the filter could be causing the issue, the filter was replaced 13 or 14 months ago.
After filter:-
Before filter:-
https://m.youtube.com/watch?v=HWoSL6T7KqE
Tandem Pump has a pressure relief valve? cactus13 VW MKV-A5 Golf/Jettas 0 June 1st, 2016 12:55
Tandem Pump Supply Pressure andymk4 VW MKIV-A4 TDIs (VE and PD) 2 April 24th, 2013 07:05
Fuel pressure pre-tandem pump timbomfg TDI Power Enhancements 4 February 27th, 2013 10:48
Tandem pump pressure findings Bobby Singh TDI Power Enhancements 9 April 26th, 2011 14:08
Checking Tandem Pump Pressure? 20vK VW MKIV-A4 TDIs (VE and PD) 2 January 14th, 2008 01:16
Page generated in 0.17062 seconds with 10 queries
[Output: 130.60 Kb. compressed to 109.87 Kb. by saving 20.73 Kb. (15.88%)]
