Old March 1st, 2018, 08:44   #61
steve6
Originally Posted by Twitch View Post
URGENT! Driving to work this morning my car would not accelerate in 5th gear at all and any slight incline it would drasticlly drop speed. when i got to work i did a first gear 4k-4.2k shift to try and maybe blow anything clogged up out i did not hear or feel the turbo. i already drove the car to work and it was slower then normal when cars are flying up on you doing 90+ it gets scary. would i be safe to drive the car to my shop (50ish miles) or am i safer to get my dad to pick me up with a trailer? what could possibly be wrong with the car no check engine lights and cluster looked normal while driving. HELP!
if you're ok after a restart definitely limp mode, I saw your post on the FB group, I am sure it gave you 100000 ideas, but if you scan with a tool you probably have a over boost code. Start it and take it for a drive if its ok definitely limp mode. You can cycle the key while driving to get around this.
steve6 is offline   Reply With Quote
Old March 2nd, 2018, 04:41   #62
Twitch
Didnt want to create multiple threads. I was able to get the car towed and out to my shop. I hooked up a vacuum pump to the turbo actuator and put about 20-23lbs of vacuum to it, it moved very very little maybe 1/8th in to 1/4 in and was very stiff i have read and been told its suppose to have lots of movement and and move freely specially by hand. Guess my big service got pushed ahead and plan on doing a big overhaul timing belt front end clean intake manifold egr delete clean turbo or if i have to replace turbo will look into the vnt17 on idparts. If i am able to clean and save the turbo can i just put a new actuator on the stock turbo? How are the vnt15 turbos on ebay for 350 or stay far away from those thanks for all the help in advance!
Twitch is offline   Reply With Quote
Old March 2nd, 2018, 05:23   #63
Genesis
Fuel Economy: 53/48/42
Yeah you're in limp mode -- the turbo vanes may be stuck, and it's frequently possible to clean them out (see the various threads here.)
Don't even THINK ABOUT one of the eBAY turbos. When a turbo fails there is a non-zero risk of causing an oil-fed hydrolock which will do severe damage to the engine. While a turbo failure is never a good thing to invite one with that trash is just plain foolish.
Genesis is online now   Reply With Quote
Old March 2nd, 2018, 10:17   #64
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Definetly rule out everything else before you purchase a turbo. Actuator failrure is real common, but it could be the vanes are cruddy.
Limp mode is our most popular ask. Unfortunately there are multiple solutions, but most involve engine controls.
Definitely sort out the issue with the actuator not moving, there are videos to show what it should do.
Try searching here for more ideas-Google Custom Search
Old March 8th, 2018, 08:49   #65
Twitch
Okay i so far removed the egr bought a egr delete pipe from wolfburg with the egr cooler delete hose waiting for it to be shipped. I removed the intake and been busy with work and got hit with the nor eastern i am soaking and letting the intake soak in oven cleaner and using a pressure washer to clean it out. I wouldn't even want to spend 150-200 dollars on a Chinese turbo just seems to cheap. If i can not buy a turbo that would be great cause my truck just broke too 6.7 cumnins and the stealer is saying its either the ecu or injection pump so costly repair right there. I plan on removing the turbo and removing the cold and hot side housing and cleaning out any soot i can out of there. Is brake clean safe to use on the turbo? Also would it be a good idea to remove the intercooler and run a hose through it to clean out any oil that could be in the intercooler? Thanks for all the help in advance once again
Old March 8th, 2018, 19:39   #66
wonneber
I cleaned my intercooler in a parts cleaning tank to get the oil out then rinsed it with water.
Let it dry good.
I may be cleaning my turbo in the near future.
I'm planning only to clean the exhaust side.
wonneber is online now   Reply With Quote
FS: ALH engine $450, 3rd injector, 2002 ALH ECU, 4-wire ALH glow plug harness 1chrisapple Private TDI Items for Sale/Wanted 12 February 8th, 2015 10:22
ALH block......ALH turbo......ALH intake w/cooler....... hvacr9e Private TDI Items for Sale/Wanted 2 October 30th, 2013 04:41
FS: 1Z long block, 1 ALH short block, 1 ALH block, couple of ALH cranks rjr311 Private TDI Items for Sale/Wanted 0 August 18th, 2012 11:23
fs: alh 10mm injection pump with 85k on it, alh steel pan ruck Private TDI Items for Sale/Wanted 4 May 7th, 2012 07:42
Difference between 03 ALH Jetta Wagon and 01 ALH Golf Mileage ss04vv TDI Fuel Economy 22 December 30th, 2011 18:32
Page generated in 0.15847 seconds with 10 queries
[Output: 76.79 Kb. compressed to 67.85 Kb. by saving 8.94 Kb. (11.64%)]
