Old January 31st, 2018, 05:14   #1
Kerma_tuned
Fuel Economy: 51
Default Modified kerma 02 jetta
kerma tdi 02 jetta
List of modifications:
Vnt17plus(doka version)
Stage 2 clutch
Race520 injectors
3"turbo back exhaust
Turbo and EGT gauges
Arp head studs
3 bar map sensor
Kerma custom tdi tune
Maintainence:
Intake cleaned
Oil change every 10k
New headgasket
EGR deleted
It all started with kermas' qloader. I was more
than satisfied with the custom tune they sent
me for my 02 jetta. My jetta has the Alh engine
in it equiped with a mahle 15 turbo and stock everything.
It's a close race between it and v6 mustangs and cummins
turbo diesels but now i want to step it up. All the modifications ive listed have yet to be installed brand new from kerma tdi and then it will get a completely new tune as well! What i am really wondering is there an upgrade im missing? What is a safe power range for this setup?
I have no idea what to expect. I would like to keep the engine in good shape(214k km) and still going strong.
Kerma_tuned is offline   Reply With Quote
Old January 31st, 2018, 07:42   #2
Franko6
Wear that name proudly. Be sure to let us know how it goes.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old January 31st, 2018, 07:44   #3
h4vok
h4vok's Avatar
The race520s will not be the best choice if you dont have a 11mm pump from the auto installed. I would look at the DLC1019 or pp764 if you have the 10mm. Could expect around 150whp and 275wtq I would guess if you are ok with a little smoke. The engines over seas came with the vnt17 and DLC520 size nozzles if I am not mistaken so you are basically just making it euro spec with a tune. You could try and find a 17/22 hybrid or similar if you want a further upgrade from the stock turbo.
DLC520, Mufflerectomy, tuned, more linked below
My car thread
h4vok is online now   Reply With Quote
Old January 31st, 2018, 07:56   #4
Kerma_tuned
Fuel Economy: 51
I have their new one vnt17plus hybrid(17/26) and cant wait to see how it stacks up against the mahle 15
Old January 31st, 2018, 08:33   #5
h4vok
h4vok's Avatar
Nice! 150whp should be easy to get too then. The only upgrades I see missing are an intercooler. With more boost you will need to cool the air. Fixmyvw has a nice side mount one that is much bigger if you want it in the stock location. There are front mounts too get one with the inlet and outlet on the same side so the plumbing can stay over on the passenger side. I would have it tuned to keep the smoke low personally to keep egt down and help everything last since that is a concern of yours.
My car thread
Old January 31st, 2018, 09:01   #6
PB_NB
PB_NB's Avatar
Sounds pretty similar to my setup but you may more fuelling with those nozzles and tune.
I have a larger than stock intercooler and got rid of the pancake pipe restriction.
Here is my dyno sheet right after doing that work. I use the car for towing and it does a great job with ~2000 lbs attached to it.
Forgot to mention that the lower numbers are with a few modifications and Malone stage 3 tune.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old January 31st, 2018, 10:19   #7
Kerma_tuned
Fuel Economy: 51
Thanks for the response!Im looking at running 24-25psi of boost through it so ill do the intercooler as well then😉
Aside from head studs should i be worried about valves,camshaft,connecting rods, suspension, motor mounts,etc?Id rather do everything that i should while the engine is apart reather then doing it piece by piece. Also is the auto 11mm pump a direct replacement for the manual 10mm?
Old January 31st, 2018, 11:49   #8
25 PSI is right on the edge of what stock connecting rods can take. Cylinder pressures depend on three factors: fueling, boost, and revs. You're working on two of the three. I ran milder fueling than you and 26 PSI and eventually bent all 4 rods. But I was also running a 6000 RPM tune, and used it.
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old January 31st, 2018, 21:12   #9
Kerma_tuned
Fuel Economy: 51
I usually dont run much past 4000rpm unless im on a highway in 5th gear making a civic owner dissapointed😂 ive read that a chip tune, injectors, and aftermarket turbo are the only things you need to get to 180whp.......still would like to know if thats sustainable on stock internals....🤔 im always game to learn more then what im asking about and when i finally get everything installed and tuned i plan on making a nice summary for others looking to build their own alh powerhouse!
Old January 31st, 2018, 21:46   #10
Nevada_TDI
OP, you are a bit confused on the turbos... a vnt17 doka is a 17/52 aka 17/22, not a 17/56 aka 17/26, these are very different turbos. A standard 17/56 is a vnt-20 frame turbo and is not designed for low RPM grunt as it takes quite a bit of RPM and fuel to achieve spool. The doka turbo is technically a hybrid turbo, and hybrid turbos are well known in the TDI world. A "doka" 17/52 is a better spooling turbo than a standard 17/52 due to the lower A/R achieved by machining the vnt-17 cold side. My 17/56 is machined using a vnt-15 cold side and my intention was not to make a 200HP engine; I wanted an engine that would give instant spool even at the 4600' elevation I live at and not run out of breath at WOT. It does not ever run out of breath even at 8600' when I am up at Lake Tahoe.
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old February 1st, 2018, 02:27   #11
Kerma_tuned
Fuel Economy: 51
Its kermas 17/26 turbo built for an alh engine.......their replacement for the discontinued 17/22
Old February 1st, 2018, 03:25   #12
I would say that's not true, depending on the dyno. I made 185 HP on a very conservative dyno but my car had an 11mm pump, PP502 nozzles, PD150 intake manifold, airbox to turbo intake, MAF, airbox, and snorkel, a 2.5" exhaust, 17/22 turbo, in tank lift pump. Stock internals, but I did eventually bend the rods.
I think 150-160 HP and 260-280 torque is a safe limit for stock internals.
Old February 1st, 2018, 03:44   #13
Kerma_tuned
Fuel Economy: 51
Never read much about it but what happens when you bend a rod? Are you looking at a new engine?new pistons and connecting rods?
Old February 1st, 2018, 05:56   #14
If you just bend them you might not even notice. Compression will be lower, either evenly or unevenly, depending on how the rods bend. A compression test will show whether or not they're bent. Rods can break and hole the block, but that's pretty rare in these engines. You'll need a set of new rods if they're bent, and at that point you can decide whether or not you want to replace pistons or rings.
In my wagon a timing belt service at 265K miles showed excessive valve guide wear. When we pulled the head to refresh it we discovered the bent rods. Otherwise the car drove fine. Refreshed the head, replaced rods, honed cylinders, new pistons and rings. But the engine continued to consume oil. Tuned out the bores were ovaled, probably from the high rev running (I used the car for a lot of track days and typically would shift at 5400-5600 RPM). Ended up replacing the engine with a new factory long block, as it wasn't much more costly than machining the existing block.
These engines are pretty durable, but they have their limits. Right now I'm running a stock VNT-15, all the breathing mods mentioned above, PP357 injectors with the 11mm pump. Car makes about 145/260 at the wheels, which is plenty of power for the street. And I almost always get over 700 miles on a fill up. I'm happy with it.
Old February 1st, 2018, 09:57   #15
Nevada_TDI
OP, from Kerma's website:
The New!! Kerma 17plus for ALH and BEW engines. The 17plus comes with a new 52mm aerodynamically engineered billet wheel (doka version) that helps dramatically increase compressor burst resistance and allows higher shaft speeds.
-Kerma exclusive replacement for the popular (but now obsolete) 17/22.
I am not trying to be an a$$, I just don't want you to be confused about which turbo is which.
_______________
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
h4vok
Modified 2001 Jetta TDI TurboBenz Jetta/Bora/Vento TDI Picture Gallery 46 August 5th, 2013 12:18
Modified 1999.5 Jetta TDI gula47 TDI Cars for Sale/Wanted 3 June 30th, 2012 13:26
FS: modified 2002 Jetta dolde TDI Cars for Sale/Wanted 3 June 14th, 2012 21:01
2001 Modified Jetta Sootman TDI Cars for Sale/Wanted 9 July 25th, 2008 12:57
Page generated in 0.15531 seconds with 10 queries
[Output: 134.54 Kb. compressed to 113.33 Kb. by saving 21.21 Kb. (15.76%)]
