Old January 30th, 2018, 06:27   #1
lthomsen
Default Skoda Fabia mk2 1.9TDI High Revs
Hi.
Car: Skoda Fabia Mk2 (5J)
Engine Code: BSW
I am currently having some problems with high revs on start up and hope that someone might be able to help.
Previously the engine would start at 2000rpm and go very unsteady when cold – tapping the throttle once would stable the revs around 900rpm. I replaced the coolant temperature sensor and haven’t seen this exact issue since.
Now when I start the engine the revs sometimes go to 1000-1400rpm and sometimes is starts in “normal” condition around 900rpm. The high revs seem to be random i.e. it doesn’t depend on the ambient temperature or engine temperature. It doesn’t help to turn off the engine and turn it on again.
I’m not sure if this could be related to the previously “cold start (2000rpm) problem”. Also I’m almost certain that the “random rpm problem” have been present all along, but have gone unnoticed because of the “cold start problem”.
I have been scouting the internet for a solution and among other possible solutions I read that the fuel shut-off solenoid on the injection pump could cause something like this. Not sure if this could be related to the issue.
Any help is appreciated.
lthomsen is offline   Reply With Quote
Old January 31st, 2018, 01:37   #2
UhOh
UhOh's Avatar
Codes?
Old January 31st, 2018, 04:33   #3
lthomsen
Originally Posted by UhOh View Post
Codes?
Hi.
Sorry for not clarifying this.
Its a Skoda Fabia mk2 (5J) from 2007. Motor code: BWS
Old January 31st, 2018, 08:58   #4
JB05
Fuel Economy: 43/41/40
He's referring to DTC's(digital trouble codes). Does your CEL(check engine light) turn on when this occurs? Any unusual oil consumption?
JB05 is offline   Reply With Quote
Old February 1st, 2018, 02:31   #5
lthomsen
Ooh, my bad .
I haven't done a diagnostic read out yet -- I ordered a OBD2 but haven't received it yet.
No engine or indication light's.
I did check on the oil level in December and no unusual consumption.
I will check again to verify.
Old February 28th, 2018, 13:14   #6
lthomsen
Update (just in case anyone is experiencing something similar).
Did a DTC readout and got a "P2100 – Throttle actuator control (TAC) motor – open circuit" code.
Going to remove the EGR valve and intake manifold for a cleaning.
Also, I think the high and uneven rpm at startup during freezing temperatures is due to a faulty glow plug. So I will be replacing those.
Old February 28th, 2018, 13:21   #7
Carlos_TJ
Sounds like your accelerator pedal is erratic at best and the ECU doing what is supposed to do when there is no accel pedal signal: increase rpms so you can get home (albeit slowly)
Carlos_TJ is offline   Reply With Quote
Old March 1st, 2018, 05:33   #8
Mongler98
If you clean your intake when you take it OFF the car, make sure you also get all the excess oil out of the intercooler. Trust me on this one.
Old March 7th, 2018, 02:16   #9
UhOh
UhOh's Avatar
As Carlos mentioned, it's almost certainly your accel pedal (and what a coincidence, that's a part that the DTC is complaining about!).
Clogged intake and EGR aren't likely going to cause high revs. I'm guessing this is a PD engine, in which case such clogging is even less likely (compared to VE engines).
Old March 27th, 2018, 09:42   #10
lthomsen
Sorry for not responding sooner. Apparently the email notification's from tdiclub went somewhere else than my inbox.
Thank you for your replies. I will look into the APPS.
The reason why i did not check this before were due to the P2100 symptoms list from "www.yourmechanic.com", which were different from what I was experiencing.
I did remove the EGR valve, Throttle valve, and Intake manifold for a cleaning. But everything were almost clean, so i just used a bit of EGR cleaner and mounted everything back into place. Also did a 750ml turbo + DPF clean-out -- lots of smoke.
The engine ran more silent and smoother after the clean-out, but the idle revs were the same.
I have been checking a lot of different stuff trying to solve this problem, but may not be relevant if it turns out to be the APPS.
Any advice regarding the APPS replacement is greatly appreciated.
Old March 27th, 2018, 10:19   #11
JB05
Try the ross-tech wiki site for DTC interpretations. You will see that this listing has more to do with our TDI's.
Old April 5th, 2018, 00:17   #12
lthomsen
Thank you for the link. I did already look at ross-tech, but I can't find any information on the P2100/Throttle fault.
Old April 5th, 2018, 00:32   #13
lthomsen
UPDATE:
I removed the gas pedal and took it apart.
Everything looked new and working. I used a bit of contact cleaner on the resistor PCB and the connectors. I also had a look at the spring and gave it some grease.
When I took it apart I noticed that the plastic housing around the throttle arm can be adjusted a bit. Adjusting the plastic housing from the inner position to the outer position will adjust the idle revs from approx 850rpm to 1500rpm.
I wonder if over time the screws and plastic have loosened and resulted in higher revs after some driving.
I tightened the plastic housing in the 850rpm idle position and put the gas pedal back in place. It's now 3 days ago and I haven't seen the idle revs going to 1100-1200rmp since.
However, when i cleaned the connectors from the throttle arm to the resistor pcb, some of the very very very small connector-arms got rotated . I tried to but them back into place, but for me it was impossible. The gas response feel a bit weird, slow and lacking power. When i log the throttle position from OBD2 with Torque i get max 80%.
I'm not going to use more time fixing the old gas pedal, so I ordered a new(used) one.
Old April 5th, 2018, 04:35   #14
JB05
Thank you for the update. I would leave the glow plugs alone since there is no related fault codes.
Old April 6th, 2018, 07:51   #15
lthomsen
Alright. I haven't replaced the glow plugs yet. The very high and uneven idle revs stopped after the increase in outside temperature, so i guess it will be forgotten until next winter .
Yesterday I went for a drive to check the throttle position. I compared full gas pedal throttle to increasing the cruise control in 5th gear and using the cruise control gave the highest acceleration/torque.
So I definitely think that adjusting the throttle arm reduced the max throttle position. But since the adjustment I haven't seen the high idle problem, so I'm positive that the throttle position sensor is the problem.
Initially I thought the error code were pointing to the throttle body, which was why i started out by cleaning that, the EGR and the intake.
Skoda Fabia on track devonutopia TDI Power Enhancements 8 May 5th, 2010 15:07
Skoda Fabia 1.9TDI (PD) failure of injector cable tree in cylider head meldrew Other VW Group TD(I)s 0 January 12th, 2008 13:55
Skoda Fabia vRS AMGvRS Other TDI/Diesel Picture Gallery 1 January 2nd, 2007 10:48
skoda fabia tdi chrisray Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 October 31st, 2005 07:49
310Nm on Skoda Fabia! GolfComfort VW MKIV-A4 TDIs (VE and PD) 3 March 6th, 2001 11:26
Page generated in 0.18990 seconds with 10 queries
[Output: 124.34 Kb. compressed to 103.92 Kb. by saving 20.42 Kb. (16.42%)]
