Old January 26th, 2018, 15:03   #1
mwmclelland15
Default 2006 MKV Jetta TDI - jumps from 2100 to 3500 rpm without pulling
Hi there,
This past summer I deleted my EGR and put a Malone 1.5 stage tune into my Jetta.
Recently in 3rd, 4th, and 5th gear the revs jump from about 2100 rpm to 3500 rpm when I accelerate more aggressively. However, it does not pull any different, it continues to pull as if I was gradually accelerating.
There is no reason that I can see for it to immediately jump 1000 or more rpm other than an issue with my clutch.
Any help or ideas would be great thanks.
Mark
2006 Jetta TDI EGR Delete Malone 1.5 Stage
mwmclelland15 is offline   Reply With Quote
Old January 26th, 2018, 16:34   #2
Owain@malonetuning
Sounds like the clutch is slipping.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is online now   Reply With Quote
Old January 26th, 2018, 20:08   #3
Mongler98
clutch 100%
change it to a lighter flywheel and a stage 2 clutch or the most street drivable clutch you can put in it and never look back.
Old January 28th, 2018, 17:03   #4
mwmclelland15
Thanks for the replies. That's what I assumed just needed someone else's opinion. Will look at clutches now!
Old January 29th, 2018, 17:43   #5
mwmclelland15
Owain,
Would you recommend OEM clutch with 1.5 stage?
Thanks.
Old January 30th, 2018, 13:20   #6
Owain@malonetuning
I would never recommend a dual mass flywheel system on one of these, but they work. VR6/G60 single mass at minimum, south bend stage 2 endurance or similar if you want something more heavy duty.
Old January 30th, 2018, 14:19   #7
Cptcrnch
I've been having the same issue with my 2004 JSW with the 1.5 tune as the clutch is still the stock DMF setup (and knew full well that it could happen so not trying to blame Malone Tuning lol). If I need aggressive acceleration I'll just downshift to fourth. It's still plenty drivable right now so unless it either starts slipping on the regular I'm probably just going to wait until the next timing belt in 58k miles. I'm eying the ID Parts quiet clutch setup. SMF setup, rated for mildly tuned cars, and cheaper then the name brand competition.
Cptcrnch is offline   Reply With Quote
2006 pd jetta sometimes jumps to 1000 rpm? Scobi-wan TDI 101 3 August 15th, 2016 14:48
PD TDI Vibration @2000 rpm and 3500 rpm+ eparker202 VW MKIV-A4 TDIs (VE and PD) 8 December 10th, 2012 20:33
99 TDI Jetta- engine quits pulling about 2600 rpm gt VW MKIV-A4 TDIs (VE and PD) 4 February 24th, 2004 22:01
Jetta TDI Power Lag at 3300-3500 RPM troutguy General VW Discussion 4 September 2nd, 2003 21:18
TDI Engine gets loud at 2100 RPM John Beyer VW MKIV-A4 TDIs (VE and PD) 3 May 16th, 2000 08:38
Page generated in 0.12253 seconds with 10 queries
[Output: 79.04 Kb. compressed to 68.59 Kb. by saving 10.45 Kb. (13.22%)]
