Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old January 23rd, 2018, 16:32   #1
Ottrwagen
Ottrwagen's Avatar
Fuel Economy: 56.2 mpg steady LA to Palm Springs
Default Is 56mpg normal on freeway?? 🦊
Hi yíall! I bought a 2015 new this past May after they were freed from jail/quarantine...the car had 6 miles when I took delivery and Now has 17,500. Needless to say, i consistently get 56 mpg from Palm Springs to LA on the 10 freeway. Is this possible? I generally get my diesel from 76 and or Chevron (my favs) and sometimes itís quite a bit higher if thereís a slight downhill for a good stretch.
If Iím getting this consistently and the carís software has been adjusted so itís California compliant, why would VW need to do anything to the car as happened with the scandal? This mileage on the freeway and the car being relatively ďcleanĒ is amazing! Thots? Ottr
Ottrwagen is offline   Reply With Quote
Old January 23rd, 2018, 17:31   #2
narongc73
Imposibru!
narongc73 is offline   Reply With Quote
Old January 23rd, 2018, 18:43   #3
Tdijarhead
56mpg is possible with these little cars, however you don’t say if you’re doing a consistent fill and figuring mileage via pen and paper or relying on that misinformed computer on your dashboard. I guess we need a bit more info.
Tdijarhead is offline   Reply With Quote
Old January 23rd, 2018, 21:01   #4
Nevada_TDI
Ottrwagen, The only way to really check the FE is to drive-and-fill, drive-and-fill and do the math. It is possible you are getting that amazing FE on the freeway, but as soon as you get into town driving your FE will usually take a giant hit. My Torque Pro says I get 50 MPG at 75 MPH, and I believe it mostly true as the tune I am currently running used to get 52 MPG at 75 MPH with the old nozzles. Here's the catch: my drive-and-fill calculations leave me at 35 MPG combined as most of my driving is done in town.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old January 24th, 2018, 08:36   #5
ModdedMach
I would say for the 2.0 cars all hwy that is a bit optimistic but not impossible. I say that because hwy speed isnt actually the "best" driving for fuel economy due to the big increase in wind resistance at higher speeds, if you were able to keep your speeds in the low 50mph range and drain most of your tank without stopping that would be ideal. A friend of mine has a 2015 sport wagon and drove across the country all hwy and got 48-49.
As others have said, manually calculating fuel consumption by filling the tank to the brim is best. You can also use GPS/mapping to help measure the accuracy of your odometer.
EDIT: if your tire pressure is still at the factory recommended pressure then I would say that 56 is really optimistic.
ModdedMach is offline   Reply With Quote
Old January 24th, 2018, 09:07   #6
My recollection is that from Palm Springs to LA you can have a pretty strong tail wind. How's it do in the other direction?
Old January 24th, 2018, 09:32   #7
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
There are times when I am getting 80 Mpg plus. But I'm going downhill with my foot off the go pedal.
DO NOT believe the MFD readout. As has been mentioned, the only way to know your mileage is by religiously filling to the top and recording distance driven and fuel used over several fill-ups. Then do the math!
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old January 24th, 2018, 13:28   #8
Lightflyer1
Lightflyer1's Avatar
At approx 110 miles between those 2 cities you can't be doing full tanks. Short trips like this can show inflated mileage. Tank averages are more consistent with everyday driving. Use a site such as Fuelly to record and compare your economy. These cars shine on extended trips on the highway. I once drove one of mine for 806 miles all Interstate, and it got in the low 50's. But over time in normal driving city/highway 36-42 mpg was more normal. Tell us what the next three tank averages are calculated by hand. I can get over 200 mpg for 3 miles.
Old January 24th, 2018, 19:47   #9
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
I'm averaging almost 56 mpg lifetime, so yes. Absolutely possible. I've seen 50 mile legs in the mid 70s with a tailwind in mine.
2015 GSW TDI S DSG - FrostHeater
2011 BMW 335d - JR 2.8 tuned (~400hp/600tq)
Blue_Hen_TDI is offline   Reply With Quote
Old January 29th, 2018, 14:11   #10
Jetta_Pilot
On each and everyone of your cars?
Old January 29th, 2018, 14:52   #11
Blue_Hen_TDI
Nope, just the GSW.
Old January 29th, 2018, 18:52   #12
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Ottrwagen's claimed 56 mpg(us) is on the high side of a bell curve, but not impossible. A lot depends on just how fast the car is being driven on the freeway. Trundling along at 55 in the slow lane minding your own business and avoiding brake and accelerator movement? 56 mpg is absolutely plausible. Driving at 70+ mpg? I call BS on the 56 mpg.
Svante Arrhenius 1896
Old January 29th, 2018, 20:24   #13
tdi54
I believe one of the contributing factor is that you lose probably more than 850 feet in elevation heading to LA. What's your mileage from LA to Palm Spring?
tdi54 is offline   Reply With Quote
Old January 30th, 2018, 04:34   #14
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Exclamation 81.17 MPG ~~ before the fix
Of course it is possible
https://www.carscoops.com/2015/07/20...s-8117-mpg-at/
2015vwgolfdiesel is offline   Reply With Quote
Old January 30th, 2018, 09:46   #15
Jetta_Pilot
Originally Posted by 2015vwgolfdiesel View Post
First off I can't seem to get the video! So can't see their tips! But
I'll bet you the car was probably not driven at higher than 45 Mph speeds. It was driven as if there was a raw egg between the foot and the pedals, ie no fast starts and no braking if at all possible. Anticipating red traffic lights and not coming to a stop. Also anytime a stop was necessary, these stops and braking manoeuvres were very gradual, probably slowing down only using the brakes at the very last to come to a full stop.
Yes it can be done but not driving normally. If you drive like a raped ape you will never get these results.
My Car Is Getting 56MPG But Shouldnt??? Braga_Dub TDI Fuel Economy 44 July 3rd, 2012 14:58
smoke on the freeway? Nurumkin TDI 101 4 August 19th, 2009 15:25
Smoke under light (normal) driving???? Normal or not TDIFanatic1.9 TDI 101 2 June 14th, 2007 23:55
My 03 got 56mpg on a 818 mile stretch G60ING TDI Fuel Economy 4 January 8th, 2004 05:44
35% to 50% EGR duty on freeway normal? lesd VW MKIV-A4 TDIs (VE and PD) 3 January 11th, 2003 01:07
Page generated in 0.11665 seconds with 10 queries
[Output: 128.26 Kb. compressed to 106.70 Kb. by saving 21.56 Kb. (16.81%)]
