Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old January 22nd, 2018, 18:03   #1
nff405599
TDI(s): 2010 Jetta
Fuel Economy: 35 in town since mandated mod.
Default Cold Air Intakes
I am new and have been reading the K&M discussions. My question is - is there any intake filter system that will improve fuel mileage?
Thanks,
Butch
nff405599 is offline   Reply With Quote
Old January 22nd, 2018, 18:15   #2
MichaelB
Fuel Economy: very good
Thanks,
Butch
Simple answer NO. There is nothing restricting or wrong with the stock filter and intake box. there is no aftermarket intake or filter that will increase the fuel economy of your car. K&M is a joke and if you think not well, waste your money on their product and find out the only thing that happened was to make the money in your wallet go faster.
MichaelB is offline   Reply With Quote
Old January 22nd, 2018, 22:13   #3
JSWTDI09
JSWTDI09's Avatar
Long answer here: http://forums.tdiclub.com/showthread.php?t=485759
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old January 31st, 2018, 15:14   #4
Mongler98
short answer, no. the best fuel econ is with a clean stock air box that the ecu expects and making sure that the MAF stays clean. Check the sticky on cold air intakes please.
any aftermarket air intake other than a Swiss cheese mod on the stock airbox and a cat air filter check is a waste of money and is hurting your engine and you will suffer power loss and bad fuel econ and trash parts like the MAF, engine bearings ect.
http://forums.tdiclub.com/showthread.php?t=290373
Old January 31st, 2018, 15:15   #5
Mongler98
for what its worth, the stock air box can handle 250hp no problem
Old January 31st, 2018, 15:25   #6
PB_NB
PB_NB's Avatar
Not sure if the MK5's and 6's have snow screens upstream of the airbox but my Beetle had one mounted sort of inside the front portion of the drivers fender. It was hit and during the repairs we discovered that it was crushed restricting airflow so I took it out and made sure the air inlet is as high as possible.
I would check to see if the screen is plugged with crap and bugs. No need to improve beyond cleaning and making sure the filter is clean and clear.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old January 31st, 2018, 15:33   #7
hey_allen
On a related note, people talked about using a R32 intake snorkle with the stock filter housing, but they appear to be impossible to get now.
Is there any equivalent option if you're pushing performance and seeing intake restriction coming into the filter box?
hey_allen is offline   Reply With Quote
Old January 31st, 2018, 15:51   #8
PB_NB
PB_NB's Avatar
I was looking at HPA's website and they have some VR6 forced induction kits with a K&N cone. They took out the drivers side headlamp and ran the K&N cone just behind the opening. I guess the added air pressure helps when you are going fast!
This might generate a ticket or a vehicle inspection if used on the street!
Maybe a home made collector could be rigged up with piping to get to the airbox!
Old January 31st, 2018, 17:05   #9
MichaelB
Thanks,
Butch
Will that Rube Goldberg set up improve fuel economy.? No matter what you do unless you have a really big turbo it will never be starved of air pressure.
Old January 31st, 2018, 17:16   #10
turbobrick240
turbobrick240's Avatar
Sounds a little like the Dodge Demon CAI. A tdi with similar arrangement probably wouldn't be banned by the NHRA though .
Old January 31st, 2018, 17:18   #11
MichaelB
What does that have to do with fuel economy?
Old January 31st, 2018, 17:20   #12
turbobrick240
Didn't you know? The Dodge Demon is all about fuel economy!
Old January 31st, 2018, 17:39   #13
MichaelB
Sorry I forgot
Old January 31st, 2018, 23:23   #14
garreth5
TDI(s): jetta
CAI can improve throttle response and sound but not mpg.
garreth5 is offline   Reply With Quote
Old February 1st, 2018, 09:14   #15
Geobmx4life
Geobmx4life's Avatar
Fuel Economy: 2005Golf TDI 50mpg...best 60
I was witness to a stock air intake test at a tuning shop, and the stock intake is only %5 inefficient.....and the tuner was pretty impressed as it was the first Vw tdi he had done.
2005 Golf TDI, VNT 17, Malone stage 4, Spec stage 2 clutch, .658 5th gear, FMIC, Ventectomy, NewSouth gauges, BuzzKen 2.5 turbo back exhaust, Evolution Skidplate, Helix OEM Reps retrofitted with Morimoto Bixenon mini's, FK coils, 18in Serrons. Frostheater
Geobmx4life is offline   Reply With Quote
Cold Air Intakes Friar Ontario 14 January 22nd, 2018 18:31
cold air intakes. any suggestion? Patrick15 TDI 101 17 March 6th, 2017 14:24
Are Cold Air Intakes Worth it? buyingconstant7 TDI 101 59 January 26th, 2016 13:35
Cold Air Intakes, compatibilities and why not? dropFROG TDI Power Enhancements 22 June 2nd, 2003 17:55
Cold Air Intakes Xtremery VW MKIV-A4 TDIs (VE and PD) 6 September 28th, 2002 10:06
Page generated in 0.15212 seconds with 10 queries
[Output: 127.54 Kb. compressed to 106.63 Kb. by saving 20.91 Kb. (16.40%)]
