Old January 21st, 2018, 18:59   #1
MichaelB
Fuel Economy: very good
Default For what it's worth
There have been many observed fuel issues here during the last cold spell. Some of you might find this article interesting. Some things apply to our cars but it was written for truck fleet service. http://www.truckinginfo.com/channel/...iltration.aspx
MichaelB is offline   Reply With Quote
Old January 27th, 2018, 06:53   #2
Rico567
A fuel filter system I might install to protect the $40K engine in my Kenworth is a clear different thing than installing the same type of system to protect the engine in my TDI.
[URL=http://www.fuelly.com/driver/rico567/passat]
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old January 27th, 2018, 11:43   #3
MichaelB
I didn't take that away after reading, that I should install the kind of fuel filter system that is used on a 40K engine. What I did take away is that in cold temps water in the fuel is more problematic than gelling. So whatever you can do to minimize or protect your fuel system from water/icing is important.
Old February 2nd, 2018, 00:00   #4
reince
TDI(s): 2006 Beetle
That's a good read Micheal.
reince is offline   Reply With Quote
Old February 2nd, 2018, 05:04   #5
scooperhsd
Which is why using something like Powerservice White is often recomended on this forum for winter use.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is online now   Reply With Quote
Old February 2nd, 2018, 09:25   #6
Nevada_TDI
White Powerservice? Two thumbs up.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old February 2nd, 2018, 19:56   #7
OlyTDI
TDI(s): '04 Golf
Yeah, I've been using a 2 micron CAT filter for about a 100K miles. The first one I changed out after 60 or 65K miles just out of an abundance of caution -- there were no issues. The next one clogged at around 40K if I recall. It shows me that yes, if you've got a stable source of good fuel, these will probably last a couple of hundred K miles. But get into some less than pristine fuel, and you'll be changing out that uber filter right away. Even so, I like that fact that what's coming through the filter outlet is ultra-filtered. I think it matters over a long period of time.
The author warns about 2 micron filters possibly causing starvation (which I guess could occur in a very large volume fuel system demand) in some applications but on our (MkIV, at least) TDIs, you can go to 1 micron without issues, except for cost of course.
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old February 2nd, 2018, 20:31   #8
MichaelB
As one of the authors basically said don't blame the filter blame the fuel the filter is doing its intended job.
"If you’re not satisfied with the life of your fuel filters, it’s probably not the filter you need to investigate."
Old February 2nd, 2018, 20:53   #9
MichaelB
Originally Posted by scooperhsd View Post
Which is why using something like Powerservice White is often recommended on this forum for winter use.
DBW on this forum recommends PS white the year round not just winter as even if the water does not freeze free water in a common rail is destructive to both the HPFP and injectors.
Old February 3rd, 2018, 20:58   #10
OlyTDI
TDI(s): '04 Golf
"If youíre not satisfied with the life of your fuel filters, itís probably not the filter you need to investigate."
Yes -- I was giving an example of just that!
2004 Golf GL PD TDI
Old February 3rd, 2018, 21:32   #11
MichaelB
Yes and I'm glad you did. When people here expound on the long life of fuel filters it's not because the fuel filter is so great it is because the fuel was already very clean. I'm running the nicktane 1 micron and fear that one fill up with dirty fuel may leave me dead alongside the road with a rather difficult situation ( think about being 300 miles or more from home) to change and prime the replacement filter. I don't carry another filter nor do I carry a VCDS and laptop to prime it. I like you do like the idea of fuel polishing down to a 1 or 2-micron level so I guess I just go for it.
Old February 4th, 2018, 05:47   #12
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Exclamation Good post
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
2015vwgolfdiesel is offline   Reply With Quote
What's It Worth?? mcarlito VW MKIV-A4 TDIs (VE and PD) 20 March 27th, 2014 15:11
03 Jetta automatic wagon, what is it worth unfixed, what's it worth fixed? marshalldanielp TDI 101 4 September 9th, 2012 10:26
Is it worth it? Car needs $2000 worth of work nielsvanm VW MKIII-A3/B4 TDIs 16 March 21st, 2006 14:35
Are they really worth it Refiner VW MKIV-A4 TDIs (VE and PD) 10 March 23rd, 2003 22:45
Are they worth it Refiner VW MKIV-A4 TDIs (VE and PD) 9 March 13th, 2003 08:54
Page generated in 0.14287 seconds with 10 queries
[Output: 109.98 Kb. compressed to 92.77 Kb. by saving 17.21 Kb. (15.65%)]
