Old January 21st, 2018, 18:03   #1
Maddawg
Fuel Economy: 800 kms per tank in summer
Default Lost 200kms per tank in cold southern Ontario
I'm losing 200 km per tank this winter I haven't changed my driving habits at all. I'm assuming it has to do with the cold. This is my first diesel
Maddawg is offline   Reply With Quote
Old January 21st, 2018, 19:36   #2
narongc73
if it's short trips, that's about right
narongc73 is offline   Reply With Quote
Old January 21st, 2018, 19:39   #3
Vince Waldon
Vince Waldon's Avatar
You can expect in the neighborhood of a 10-15% loss in the winter due to increased tire rolling resistance (especially if you use winter tires) thru snow, increased idling, greater electrical load on the engine (lights, heater fan, rear window defroster), cold temperature effects on grease, and in particular the fact that the fuel companies switch to an anti-gel diesel formulation that has less energy per liter.
That said, 200km sounds a bit on the edge...if it doesn't get better in the spring you may want to investigate further if you don't have time now.
A dragging emergency brake is a pretty common cause of a steep drop in fuel economy, for example. Timing that's off, air filter over-due for replacement... several other things to check.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old January 22nd, 2018, 04:09   #4
Tdijarhead
I loose 100 miles per tank during the winter. Around 750 to 650. I’ve come to the conclusion after running an ultragauge on my car during operation that it’s the cold. It doesn’t allow your vehicle to warm up as quick and keep the optimum operating temperature as consistently.
Tdijarhead is offline   Reply With Quote
Old January 22nd, 2018, 05:54   #5
vincej
Mine uses about an extra 1/2 liter per 100 kms in the winter. That number would surely be more if the car was parked outside or sustained temperatures would go below -20C.
vincej is offline   Reply With Quote
Old January 26th, 2018, 05:35   #6
UhOh
UhOh's Avatar
200km seems a little on the high side to blame only on temperatures and fuel.
E-brakes tend to become a bit troublesome in cold weather. Verify that your rear brakes aren't sticking.
Old January 26th, 2018, 06:35   #7
csstevej
Also verify that the coolant temp sensor and thermostat are working correctly. Those will rob you in fuel efficiency too.
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old January 26th, 2018, 06:36   #8
csstevej
Need to verify with at least a laser thermometer but better yet with VCDS.
Old January 28th, 2018, 06:51   #9
dandywriter
What tire pressure are you running? Checked recently?
http://www.nrcan.gc.ca/energy/effici...s/buying/16748
2006 Jetta TDI 5-sp, Bosal hitch, frostheater, evo skidplate, upgraded rear springs and front spring dist kit (1" lift), GIAC Stg 1 tune, USA Spec iPod adapter, SMF clutch, Coolant Heater Grill Outlet, winter front, LED backup and lic lights, VCDS
dandywriter is offline   Reply With Quote
Old January 29th, 2018, 10:57   #10
pedroYUL
pedroYUL's Avatar
Fuel Economy: ~17.5 km/L
Let me add to the laundry list: wheel bearings, some might not get noisy when failing and create extra friction that is worst when cold.
Is you car still on the original wheel bearings?
If changed, were they quality replacements?
Both my cars have now new wheel bearings in all 4 corners, some SKF, some Optimal...they roll like a dream now!
pedroYUL is offline   Reply With Quote
Old January 29th, 2018, 12:31   #11
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
My 2015 Golf TDi is down ... some ... But Tulsa is a long way from that much cold temps
2015vwgolfdiesel is offline   Reply With Quote
Old January 29th, 2018, 16:44   #12
fruitcakesa
Fuel Economy: 40's
My last tank was 37.1 and that was with extended parked time during the super cold snap and short duration minimal warmup runs with a few highway trips in between the rest of the time.
That is high for this car in cold temps. It would be higher yet with fewer local hauls and more highway time.
We used the Honda during the snap and it averaged only 30 mpg or lower down from 40.
Extreme cold is really tough on all ICE
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Old February 6th, 2018, 07:55   #13
2015vwgolfdiesel
I really never thought that much about this issue.
Good to know.
Do the fix, pocket $8,000-ish 6, 776 miles on the clock, Pristine condition
BB = $25,625, but VW is not paying for PRIME condition nor ULTRA low miles.
Net bases in my 2015 Golf = $12,495
NADA-KBB for older CPO Golf TDi 2014 = $18,250
Nozzles in southern ontario skydivebum Ontario 3 May 16th, 2012 06:09
Ontario GTG! - GTA, Southern/Central Ontario area papiot Ontario 127 April 10th, 2006 18:34
Ontario GTG!!!! - GTA, Southern/Central Ontario area papiot Events, Gatherings, Clubs 2 January 12th, 2006 15:57
Anyone hopmebrewing in southern ontario?? VDubbing Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 9 September 28th, 2004 19:54
Parts In Southern Ontario fxrguy TDI 101 1 May 24th, 2002 10:44
Page generated in 0.21104 seconds with 10 queries
[Output: 113.70 Kb. compressed to 95.42 Kb. by saving 18.28 Kb. (16.08%)]
