Old January 21st, 2018, 14:12   #1
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
Default Audi A4 3.0TDI 505hp 980nm
Well guys managed to hit my target of 500hp
So what’s changed? As you know my s200v has been put up for sale to make way for unique turbo.
EFR7670 with S300v housing its a watercooled roller bearing turbo with really nice wheels -
CW:76/57
TW: 70/61, gamma-Ti alloy, lower density (and thus inertia) than conventional Inconel alloys
Thanks to Ruben for all his work on the turbo top job.
I've been driving for approx a month tuning it and trying to get it right for a power run. Its been task to balance spool Vs surge - for example more spool is possible but then get surge so the short term workaround is to run less boost. Long term would be to leak off some air via ECU controlled valve.
So yes it does have lag but it still have same torque as a stock 3.0tdi @ 2.2k in its current form.
Dyno
We turned up on a BMW day
Smoke test Video:
https://youtu.be/kX7h95M7adI
(captured by Jay)
The turbo is really a monster and still has more scope, but I'm out of fuel. I guess with larger injectors 550hp would be on the cards.
EGT's - 900deg
Stock engine (apart from valvesprings)
Stock exhaust apart from downpipe
Stock gearbox
No smoke
Cheers
Bobby
BSR
Audi A4 3.0TDI B8 - 505hp/980nm...
3.0TDI S200v hybrid (470hp) kit for sale
http://forums.tdiclub.com/showthread.php?t=492614
Bobby Singh is offline   Reply With Quote
Old January 21st, 2018, 17:59   #2
[486]
TDI(s): 02 golf ALH
Nice!
Love how clean it's running.
Very interested to see how the alloy turbine does in the oxidizing exhaust stream.
Also interested in using compressor bleed air to avoid surge. Works on big aircraft engine compressors, no reason it wouldn't on these compressors.
[486] is offline   Reply With Quote
Old January 21st, 2018, 23:07   #3
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Great result! Congrats! Good to know the tiptronic is holding the torque.
Any remap to it, or just the normal service filter and oil?
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old January 21st, 2018, 23:42   #4
iModAMD
Very nice!
iModAMD is offline   Reply With Quote
Old January 22nd, 2018, 01:19   #5
raffshore
great result bobby !!
raffshore is offline   Reply With Quote
Old January 22nd, 2018, 03:33   #6
ryanp
ryanp's Avatar
Good going, these V6's must have much better porting than the 2.0's!
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old January 22nd, 2018, 04:54   #7
Bobby Singh
Originally Posted by [486] View Post
Nice!
Thanks - yep I actually hate smoke and its my everyday ride so needs to be road friendly.
Mac - the 6hp 28 is really strong - stock sw. Only thing I was service it maybe 20k ago.
Originally Posted by iModAMD View Post
Very nice!
Cheers Raf
Thanks Ryan - yes goes very well. Regarding head I suspect they are same but I have no flow data to confirm.
But I wouldn't like to try this on stock valve springs.
BSR
Old January 22nd, 2018, 04:58   #8
ryanp
ryanp's Avatar
your sig needs an update!
Old January 22nd, 2018, 05:52   #9
Jetmugg
TDI(s): None
Congratulations!
Jetmugg is offline   Reply With Quote
Old January 22nd, 2018, 06:00   #10
eddie_1
eddie_1's Avatar
Congrats! Great Autobahn car. Probably give a stock RS6 a good run and go up to like 333kmh. How far are you pushing it in RPM? Plot stops at ~4600rpm.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old January 22nd, 2018, 06:11   #11
TDIfreak
Congrats! I see rpm sensor on the turbo, care to share the figures you see?
TDIfreak is offline   Reply With Quote
Old January 22nd, 2018, 06:12   #12
Turbo Z
Nice work Bobby
May I ask what boost and rail pressure you are running now, still a cp3-110 pump?
Turbo Z is offline   Reply With Quote
Old January 22nd, 2018, 06:55   #13
Bobby Singh
Thanks guys - power is flat, but in S I can change just at 5k
Turbo speed voltage needs confirmation as the reading is too low at the moment.
CP3 R90 hpfp
BSR
Old January 22nd, 2018, 12:32   #14
1.4TDI PD
really nice build and a lot of power for the A4 it"s a great sleeper.
1.4TDI PD is offline   Reply With Quote
Old January 22nd, 2018, 19:07   #15
andy2
andy2's Avatar
I really like the thought that the "off the shelf" s300v with similar inducer was not quite good enough.
Ground breaking work done here and thank you for sharing !
andy2 is offline   Reply With Quote
Audi A4 3.0TDI B7 Quattro A430TDI TDI Power Enhancements 15 January 3rd, 2015 03:30
Audi A4 3.0tdi in Ontario 2.2TDI Other VW Group TD(I)s 0 September 29th, 2013 17:08
Gtx2263vk in audi a4 2.0tdi prodrive TDI Power Enhancements 7 June 21st, 2013 11:56
buying a 2005.5 Audi A4 2.0TDI 140bhp Carl2k7 TDI 101 12 December 8th, 2010 15:14
My Audi A4 S-Line 2.0TDI Captain_Chaos Other TDI/Diesel Picture Gallery 8 March 12th, 2005 14:16
Page generated in 0.17400 seconds with 10 queries
[Output: 130.44 Kb. compressed to 108.69 Kb. by saving 21.74 Kb. (16.67%)]
