Old January 19th, 2018, 10:17   #1
raksike
TDI(s): 2.0TDI
Default Where is the DE 143 cam plate used??
In which pumps the DE 143 cam plate is used?
From somewhere I readed, that the pump with the code 038 130 107 J should have the DE 143 cam plate installed, is this information correct?
raksike is offline   Reply With Quote
Old January 19th, 2018, 20:05   #2
[486]
TDI(s): 02 golf ALH
ALH automatic transmission (it also has an 11mm pumping element)
Don't have a p/n for you, but you can easily google one up
[486] is offline   Reply With Quote
Old January 20th, 2018, 00:55   #3
Yucca
Yes that is correct!
Yucca is offline   Reply With Quote
Old February 4th, 2018, 22:54   #4
raksike
TDI(s): 2.0TDI
Is there any other pump except 038 130 107 J, what is using also the DE143 camplate?
Old February 5th, 2018, 01:41   #5
sam-
If it can help you, this is the BOSCH reference for a DE143 camplate but its like 150e through reseller : 2 466 110 143
I saw some cheap DE143 at starsdiesel.net (probably made in china) but i dont know if the quality is good enough or its like the chinese head who mostly fail.
sam- is offline   Reply With Quote
Old February 5th, 2018, 03:06   #6
raksike
TDI(s): 2.0TDI
Thanks for this info, but at first I still would try to find a pump more nearer with this cam plate. Nobody has not offered any pumb with the code 038 130 107 J.
There have came offers for 038 130 107 D and 038 130 107 B, but I do not know what cam plate is used there.
Old February 5th, 2018, 05:27   #7
senso
There is this ebay.de listing:
https://www.ebay.com/itm/038130107J-...MAAOSwDApad3Cf
Now, I dont know german, and I dont know how good is the google translate thingy..
But it seems like its a full fuel pump and not one of those ads for send your back to be repaired.
senso is offline   Reply With Quote
Old February 5th, 2018, 06:01   #8
Chrislupo
Hi,
Bitte beachten Sie: Verkauf erfolgt nur im Austausch.
100€ Kaution für ihr Altteil
At the moment on german ebay you get only exchange parts.
https://www.autoteile-markt.de/shop/...0993f8069458b1
Chrislupo is offline   Reply With Quote
Old February 5th, 2018, 07:22   #9
raksike
TDI(s): 2.0TDI
The idea is to buy it from some local used spare part dealer. But what codes are using it? Are 038 130 107 D and 038 130 107 B using the de143 cam plate?
Old February 5th, 2018, 07:51   #10
Yucca
No, only 038 130 107J uses that DE143 camplate. 038 130 107D camplate is DE110.
Old February 5th, 2018, 08:02   #11
raksike
TDI(s): 2.0TDI
How about the pumps which code ends with Jx, H or Hx?
Old February 5th, 2018, 12:19   #12
Yucca
JX use de143!
Old February 5th, 2018, 22:44   #13
raksike
TDI(s): 2.0TDI
Originally Posted by Yucca View Post
JX use de143!
What about H or Hx?
Old February 7th, 2018, 03:05   #14
Yucca
Old topic says that 038 130 107H, J and K are 11mm pumps.
Old February 7th, 2018, 05:17   #15
raksike
TDI(s): 2.0TDI
So basically all 11mm pumps are using it?
VE pump cam plate v8 coupe TDI Power Enhancements 2 May 5th, 2012 13:56
Anyone made their own cam locking plate??? TDIFanatic1.9 TDI 101 11 March 20th, 2007 10:36
skid plate de A4 fonctionnaire Quebec 22 October 21st, 2004 16:33
Pièces de A2 ? un 1.6D de 143 000 kilo ! Wingaman Quebec 26 December 28th, 2003 13:58
Cam Locking Plate Steve T VW MKIV-A4 TDIs (VE and PD) 2 July 23rd, 2001 10:42
Page generated in 0.15834 seconds with 10 queries
[Output: 117.38 Kb. compressed to 97.24 Kb. by saving 20.14 Kb. (17.16%)]
