Old February 7th, 2018, 01:53   #46
BarryT82
My Q5 TDI is now averaging 22-23 mpg. Before the repair it was averaging 32 combined and almost 40 mpg highway.
BarryT82 is offline   Reply With Quote
Old February 7th, 2018, 05:01   #47
740GLE
Originally Posted by MacDonald View Post
2014 passat non reprogrammed 45 to 50 average mostly highway. Had a couple mid 60's trips with cruise set at 59 to 64, 2015 passat post dieselgate 26 to 28 average. Totally disappointed almost went with a gaser, totally ruined the tdis no point now that they stole the fuel mileage away. We went from seeing 750 to empty to 350 to empty. Driving the cars side by side the 14 smokes the 15 in every aspect. My Ram 2500 with a 6.7 cummins in it gets same mileage as the 15. I am ordering vag-com asap. My 05 jetta gets 48 with almost 300k on it.
How short of driving are you doing? Something is wrong if you cant do a 20 mile highway trip 60-75MPH and get mid 40's.
Old February 7th, 2018, 06:56   #48
KITEWAGON
KITEWAGON's Avatar
Wow. Our Treg only dropped from about 25 mpg to about 23.5 mpg based on the computer....no hand calcs. And some of that could be attributed to the winter conditions, winter fuel and letting the car idle more often to warm it up a little.
2014 Touareg TDI Executive, Canyon Grey, 130k
2014 JSW TDI, Platinum Grey, 43k
2005 Toyota Tundra Double Cab SR5 TRD 4x4, Silver, 165k
KITEWAGON is offline   Reply With Quote
Old February 7th, 2018, 07:20   #49
dunerking
dunerking's Avatar
TDI(s): 04 Jetta TDI
Wow...26-28 MPG out of a 6.7 Cummins? Must be deleted,2wd,and downhill all the time.
05 Dodge 3500 CTD,2.5 Carli suspension
13 Porsche Cayenne diesel
12 JSW OEM fog lights(sold back to VW)
04 Jetta-5 speed
dunerking is offline   Reply With Quote
Old February 7th, 2018, 08:48   #50
Mythdoc
Mythdoc's Avatar
That is messed up. Also, not what I have generally seen from reports post-fix. Open a ticket with AoA?
“Yeah, well, y’know, that’s just like, uh... your OPINION, man.” —The Dude
2015 Q5 TDI 25K Miles
2011 Touareg TDI 74K Miles (sold back to VW, May, 2018)
2015 Golf TDI 16K Miles (son’s)
Mythdoc is online now   Reply With Quote
Old February 8th, 2018, 03:18   #51
BarryT82
No I haven’t. I’m going to reinstall the stage 2 tune.
Old February 12th, 2018, 13:40   #52
brendaT
Before my emissions fix, I averaged around 31 to 34 MPG. Since the fix it's below 30, usually around 27 or so. It seems to perform about the same, maybe a little more noise. However, I was told I would only loose 1 at most 2 MPG. For me that sucks, I hate gas stations.
I want my old car back
brendaT is offline   Reply With Quote
Old February 12th, 2018, 14:01   #53
brendaT
Yes, this isn’t the best time to sell. If you really need to, I’d encourage you to look at the best available offer, mentally add the settlement amount, and tell yourself “it’s not so bad.” That said, I agree that your best chance to get highest return is through a private sale.
I found this website https://www.audiusa.com/trade-in-value
It gave me a pretty good quote for my high-mileage 2014 Q5 TDI. When I go to trade in, I will use this for leverage. Since you're not trading in, you could still use it at carmax, your Audi dealer, etc.
Old February 13th, 2018, 06:21   #54
Mythdoc
Mythdoc's Avatar
Tomorrow’s the fix day for me. I’ll post observations. Opinion has been so divided on the effects it has been strange to read. As one whose calculated mpg since buying stands at over 34, it will be interesting to see how the fix affects my fuel economy.
Old February 14th, 2018, 17:44   #55
Mythdoc
Mythdoc's Avatar
I just drove the 93 miles home from my dealer with a newly fixed Q5. Maybe I have been luckier than others, but I can’t tell much difference. The car did have higher shift points and more clatter until warm, but once warm, I found I could use my paddle shifters to upshift at the old shift points I was used to. My display showed a slightly *higher* mpg for this post fix trip (36.7) than it had for the prior tank.
Obviously, just a first take, and I’ll keep an eye on it. But I’m pleased so far, particularly since I get paid $4200 now. After I run a couple of tanks through, I’ll be reinstalling my Chipwerke to see what it does.
Old February 21st, 2018, 07:38   #56
brendaT
What does the Chipwerke do? And how is your mileage now? After driving mine for a few weeks now, it seems to have gotten better. I'm now averaging around 32 mpg with my 2014 Q5 TDI.
Old February 21st, 2018, 12:12   #57
flgman
Default Another data point on Q5 TDI
Just adding another data point. Had my 2014 Q5 TDI "fixed" last week. Same impressions as the others. It is revving noticeably higher when cold. Once fully warm, not much is different. Seems to hold on to the gears just a bit longer. Not enough mpg logged yet to compare to my previous average. I did notice that there is a bit more delay on startup when cold - ignition is paused just a bit and there is slight bit of vibration I never noticed before the modification. Question to all: are there good options out there to just reprogram our TDI's?
flgman is offline   Reply With Quote
Old February 21st, 2018, 13:43   #58
Mythdoc
Mythdoc's Avatar
So far, my new average mpg is down about 1 from the number you see in my signature. Around 33.5. Performance is much the same, except for the warm up everyone is noticing. The warm-up lasted 10 minutes today on a 70 degree day in Tennessee.
As for the Chipwerke, it is what is called a piggyback tuner. The performance gains and/or fuel efficiency are modest, maybe about 1mpg better and a little more oomph. I unhook mine whenever I go to the dealer so they don’t know I am using it. I haven’t reconnected it yet, because I wanted to run a couple of tanks through to get a new baseline. BarryT86 mentioned his wife is running the Chipwerke again and it helps with the performance.
Another option is an ECU tune. These reprogram your car’s computer to a performance spec you want. It could be original factory or it could be more performance than that. There are several companies that offer it, Malone, JR and others. These void your warranty if Audi catches you using one. You cannot simply unhook it like the Chipwerke and go undetected.
I drove about 30 miles today. I am quite happy with the fix, I must say. I particularly like how thick my wallet feels in my back pocket as I sit in the car, LOL
Old February 21st, 2018, 15:56   #59
flgman
Thank you for the added info on tunings.
Old February 21st, 2018, 18:27   #60
BarryT82
I had a JR Auto Tuning stage 2 tune installed before the fix. I sent the new file to them last week and haven’t heard back from them yet. Owain posted in another thread on here that Malone has been selling a lot of tunes for the 3.0 TDI’s post fix.
2014 Q5 settlement info EchoHotel Dieselgate - VW Group Emission Scandal 0 November 28th, 2017 10:33
What should I do with my 2014 Audi Q5 TDI? sangshin87 Dieselgate - VW Group Emission Scandal 3 March 8th, 2017 06:31
Thinking about a 2014 Q5 TDI TDI_Brad Audi SUVs (Q7 & Q5) 13 February 17th, 2016 04:02
2014 Q5 TDI tuning KatchMeRacing Audi SUVs (Q7 & Q5) 4 June 12th, 2015 17:07
Tuning the 2014 Q5 TDI GTT Audi SUVs (Q7 & Q5) 0 October 28th, 2014 20:01
Page generated in 0.17262 seconds with 10 queries
[Output: 132.00 Kb. compressed to 110.71 Kb. by saving 21.28 Kb. (16.12%)]
