Old January 18th, 2018, 09:05   #1
DieselQ5
TDI(s): 2014
Default 2014 Q5 post-fix impression
I had my '14 Q5 fixed on Monday 1/15. I could not tell one difference in my car's performance after the fix. I took it on the highway and saw no difference driving 70-80mph. I saw no difference when leaving stoplights and no difference when passing, braking or anywhere else I can think to mention. An updated fuel economy sheet was left on my passenger seat and now rates the car at 26 HWY 23 City. For the $9,500 I got from the scandal I can live with that.
DieselQ5 is offline   Reply With Quote
Old January 18th, 2018, 09:11   #2
psd1
Fuel Economy: See Fuelly link
Wow, only 26 for the new highway MPG, what was it before?
psd1 is offline   Reply With Quote
Old January 18th, 2018, 11:03   #3
Q5TDI
TDI(s): Q5
For Premium Plus:
24 city / 31 highway
Q5TDI is offline   Reply With Quote
Old January 18th, 2018, 11:15   #4
psd1
Originally Posted by Q5TDI View Post
For Premium Plus:
I'm pretty certain there isn't an MPG difference between sub models.
Still curious on the OP's claim that 26 is the (new) Hwy MPG.
Old January 18th, 2018, 11:19   #5
BarryT82
26 was combined I think.
BarryT82 is offline   Reply With Quote
Old January 18th, 2018, 11:40   #6
DennisMitchell
Per EPA site revised Q5 TDI MPG are 23 City, 30 Highway and 26 Combined.
https://www.fueleconomy.gov/feg/Powe...Q5&srchtyp=ymm
DennisMitchell is offline   Reply With Quote
Old January 18th, 2018, 14:45   #7
Q5TDI
TDI(s): Q5
Down 1 mpg seems like no big deal.
Old January 18th, 2018, 15:09   #8
psd1
For sure, unless a guy was getting +2 or 3 MPG before...
Old January 18th, 2018, 15:47   #9
Gumbus1514
TDI(s): 2014 Q5
Just got my 14 Q5 back Tuesday. Engine seems fine but the transmission sucks. ~3 mile drive out of the neighborhood. 30ish mph was 1000-1200 rpm. Same speed is now 1900 rpm with lots of extra noise. Pedestrians, cyclists, and the greens keeping crew are all looking at me like I am some kind of deviant. I have even tried to manually take the higher gear but it is locked out. This is probably not something that is going to resolve itself through the adaptive logic. They let the politicians, beauracrats, lawyers, and the other slime wreck our cars.
Gumbus1514 is offline   Reply With Quote
Old January 18th, 2018, 17:52   #10
RebelTDI
The higher rpms are to get the emissions components up to temp quicker. Question is, once it's up to normal operating temp, are the rpms back down to 1200?
RebelTDI is offline   Reply With Quote
Old January 18th, 2018, 19:18   #11
DieselQ5
TDI(s): 2014
My mistake, you are correct. 26 combined, 30 hwy and 23 city
Old January 18th, 2018, 19:25   #12
DieselQ5
TDI(s): 2014
I've read other people experiencing your issues and that is why I shared mine. Seems like a split between yours and my results. I have always driven my car pretty hard, I just love the torque. Maybe my driving style kept the car more aggressive. I have no other way to explain that my car has not changed its behavior at all.
Old January 19th, 2018, 02:03   #13
Q5TDI
TDI(s): Q5
What is your altitude where you are at in Arizona?
Read something in the booklet that engine performance may depend on altitude. We travel quite a bit to Sedona, where it is about 4500. The other guy is in Florida. The highest altitude in Florida is 345 feet. However, that does not seem to make sense, because the rpms should be higher at a "high" altitude, whatever that means.
Here is what the booklet says:
Engine sound may differ somewhat from your vehicle's prior
operation. There might be a difference in combustion noise from
the engine that may be noticeable during vehicle warm-up. The
potential change in sound will not result in any noticeable
changes to the driving characteristics of your vehicle.
Shift Patterns - The shifting behavior has been adapted to run
with slightly higher engine speeds during vehicle warm-up and
when driving at high altitudes.
Old January 19th, 2018, 08:40   #14
DieselQ5
TDI(s): 2014
I am in Phoenix and we are at 1000' elevation. My car was warm when I picked it up so I don't have any experience with any extra noise during warmup. Thanks for pointing that out. If I notice any different noise the next time I drive it I will comment here.
Old January 19th, 2018, 09:35   #15
bhuizer
My Touareg does the same thing during warm-up. It's the most annoying part about the fix. However, once everything is up to temp after a few miles the shifting patterns go back to normal.
Also, just because your coolant temp gauge says 200 degrees, doesn't mean the exhaust components are at the correct temp. So the warm-up shifting pattern can occur anytime the exhaust components have cooled off. This is just what I've noticed in the below-zero Iowa temps the last few weeks. EGR needs high exhaust temps to do it's thing, idling or low load situations don't create much heat with these engines.
bhuizer is offline   Reply With Quote
2014 Q5 settlement info EchoHotel Dieselgate - VW Group Emission Scandal 0 November 28th, 2017 10:33
What should I do with my 2014 Audi Q5 TDI? sangshin87 Dieselgate - VW Group Emission Scandal 3 March 8th, 2017 06:31
Thinking about a 2014 Q5 TDI TDI_Brad Audi SUVs (Q7 & Q5) 13 February 17th, 2016 04:02
2014 Q5 TDI tuning KatchMeRacing Audi SUVs (Q7 & Q5) 4 June 12th, 2015 17:07
Tuning the 2014 Q5 TDI GTT Audi SUVs (Q7 & Q5) 0 October 28th, 2014 20:01
Page generated in 0.20053 seconds with 10 queries
[Output: 127.08 Kb. compressed to 106.37 Kb. by saving 20.72 Kb. (16.30%)]
