Old January 26th, 2018, 23:45   #16
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Still have to see one. I've seen 434 and 418hp on same dyno ,2.0 PD engines
and the numbers are to be taken ..as just numbers.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is online now   Reply With Quote
Old January 27th, 2018, 01:09   #17
altz1
TDI(s): Allroad, A8
Originally Posted by TDIMeister View Post
900 HP / 1300 Nm in a 4.2 V8 sounds really good, doesn't it? It can be done...
http://bit.ly/i40f2S
150mg@1.2ms will do the trick? This is my absolute fueling limit from new injectors. If yes, im all in.
Heck, even 650-700 would be plenty for me. I have all the parts, might aswell try.
Those running wmi has reported more smoke, why is that? Water slows burning and EOI gets late?
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
BVN 4.2TDI, 2x gtd2060vzk. - build
MB S450CDI - dd
altz1 is offline   Reply With Quote
Old January 27th, 2018, 04:14   #18
Rub87
1.2 msec is too long at 5000 rpm. Id aim for 650-750 microsec.
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
170ppd wont go higher then 1.6bar niko TDI Power Enhancements 25 December 19th, 2016 02:25
Using 3 bar map sensor on 2.5 bar map car devonutopia TDI Power Enhancements 36 October 5th, 2016 09:17
MAP 25 Sensor vs MAP 30 Sensor mhintlian TDI 101 0 May 28th, 2015 08:38
AFN - Upgrade Early ECU MAP Sensor to Later Sensor mike.s VW B5 Passat TDIs 0 March 16th, 2015 02:45
WTB: Thust sensor AKA. map sensor big67 Private TDI Items for Sale/Wanted 0 February 4th, 2010 11:27
Page generated in 0.13033 seconds with 10 queries
[Output: 60.22 Kb. compressed to 54.70 Kb. by saving 5.52 Kb. (9.17%)]
