Old January 17th, 2018, 07:55   #1
BigTurboAlh
Fuel Economy: 35
Default 6bar map sensor
Anyone have a part number for a 6/7bar map sensor.
2000 ranger alh swap daily driven
dual valve springs, pistons flycut and decompressed, arp rod bolts main studs head studs, h beam rods, pnp, frank06 cam and oil pump, fueled, sb drag clutch, fass 150, hx30-hx40 compound, nx water meth kit, special injectors, 11mm pump, 3.5in downpipe to 4in rest of the way back.
BigTurboAlh is offline   Reply With Quote
Old January 17th, 2018, 07:58   #2
Tero P
6bar Bosch 0 281 002 420
Uncle Hank Fan Club
Tero P is offline   Reply With Quote
Old January 17th, 2018, 08:28   #3
BigTurboAlh
Fuel Economy: 35
Thanks damn compounds
Old January 25th, 2018, 12:06   #4
Votblindub
Votblindub's Avatar
Thumbs up
I have to come visit and take a look at this monster you're working on in person!
Sprint 520 Nozzles, 2.5 inch catless mufflerless BuzzKen exhaust, Malone stage 3 chip, 01M, Frostheater Full details
Full details
FB page for wagon lovers I have VAGCOM/VCDS
Votblindub is offline   Reply With Quote
Old January 25th, 2018, 12:47   #5
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
I calculated that developing 450 HP in a 2 L 4 cylinder TDI didn't need more than 4 bar absolute, so I'm curious of your plans to exploit a 6 bar MAP sensor....
Old January 25th, 2018, 13:25   #6
Turbo Z
Good to know, I need one too
Turbo Z is offline   Reply With Quote
Old January 25th, 2018, 14:40   #7
Rub87
maybe 40 bar mep isnt the horizon for some fellows
'99 Black Ibiza GT90: 2260v, ARL bottomend, rosten rods 81mm slugs, 17:1 CR, 35/38mm exh/in valves, 02M, 305mm discs with Brembo calipers, OZ Superturismo 16"x7.5J, .............
Dyno'd area, Old VNT20 setup dyno'd 192whp
Rub87 is offline   Reply With Quote
Old January 25th, 2018, 16:11   #8
m1ketdi
TDI(s): Leon BKD
Fuel Economy: 50+mpg
Maybe he wants 1000Nm from 1500rpm
m1ketdi is offline   Reply With Quote
Old January 25th, 2018, 16:48   #9
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Oh, very true, how careless of me.
Old January 25th, 2018, 18:03   #10
BigTurboAlh
Fuel Economy: 35
450hp on commonrail 16v at 4bar yeah but 8 valve I don’t see it vp. I don’t plan on needing anymore than 50psi with compounds. I paid $90 for my 4 bar. 6bar is $45 and I’ll never have to upgrade it again.
Old January 25th, 2018, 21:05   #11
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Me too, me too!!
Rod bearings are on the 10k mile service interval, right?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old January 25th, 2018, 23:16   #12
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
4bar sensor is cheap ..about 40€
CP3 Upgrade
100-200 Acceleration
Macradiators.com is online now   Reply With Quote
Old January 25th, 2018, 23:44   #13
altz1
TDI(s): Allroad, A8
27eur i paid for mine, bosch and new @ ebay.
4bar absolute (3bar boost) for 450hp cr? This is with some really good cams/head and 5k rpm?
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
BVN 4.2TDI, 2x gtd2060vzk. - build
MB S450CDI - dd
altz1 is offline   Reply With Quote
Old January 25th, 2018, 23:51   #14
Rub87
Aspecially nozzles if u want to be able to burn at a realistic lambda without melting parts
Old January 26th, 2018, 22:17   #15
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
900 HP / 1300 Nm in a 4.2 V8 sounds really good, doesn't it? It can be done...
http://bit.ly/i40f2S
170ppd wont go higher then 1.6bar niko TDI Power Enhancements 25 December 19th, 2016 02:25
Using 3 bar map sensor on 2.5 bar map car devonutopia TDI Power Enhancements 36 October 5th, 2016 09:17
MAP 25 Sensor vs MAP 30 Sensor mhintlian TDI 101 0 May 28th, 2015 08:38
AFN - Upgrade Early ECU MAP Sensor to Later Sensor mike.s VW B5 Passat TDIs 0 March 16th, 2015 02:45
WTB: Thust sensor AKA. map sensor big67 Private TDI Items for Sale/Wanted 0 February 4th, 2010 11:27
Page generated in 0.15601 seconds with 10 queries
[Output: 133.05 Kb. compressed to 111.32 Kb. by saving 21.73 Kb. (16.33%)]
