Old January 11th, 2018, 11:37   #16
turbobrick240
turbobrick240's Avatar
FXDL, you are taking the criticism of Mr. Rat's "research" too personally. If ZDDP was such an ineffective anti wear additive, I don't see why the professional tribologists working in the industry - with real credentials, testing equipment, etc. would include it in motor oil formulations. I doubt it's all a conspiracy to enrich the zinc barons of the world. The protective film that ZDDP forms, grows exponentially with temperature and pressure- it seems Mr. Rat's testing conditions were not sufficiently harsh to give the zddp a chance to form the protective film that it does in real world usage.
Even if he was right about zddp, you have to admit that his writing style is more sociopath than scientist.
Old January 11th, 2018, 12:47   #17
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
snip/
/snip
This.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old January 11th, 2018, 15:52   #18
MichaelB
Fuel Economy: very good
Originally Posted by FXDL View Post
would, mite learn why he did and why. Now head back tobobtheoilguy as I believe he is using info from the 540 rat and posted on his site.
You believe......I don't see it..........show me
MichaelB is offline   Reply With Quote
Old January 11th, 2018, 20:44   #19
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
It's interesting that you picked up on it too. My first post said "it reads like a serial killer wrote it." which I edited to what it says now, thinking it too harsh.
But dang that affect. So righteous!
nicklockard is offline   Reply With Quote
Old January 11th, 2018, 21:41   #20
whitedog
Dang,Nick. Now I WANT to read it.
Ok. Here I go down the rabbit hole... Wish me luck.
Old January 26th, 2018, 10:53   #21
FXDL
Fuel Economy: 4.4 per 100KM's
He has done a lot of testing on different engine oils, some 200 or more, which has taken how much of his time to do, yet all the experts out here seem to think it is BS or what have you when in fact I don't see them posting or showing any testing they have done to prove him crazy, wrong, or what ever? Each their own, for opinions. I only put this read out for to learn from or not. There is for sure some useful info in his testing. Sure seems like a lot of people out here have negative input on it, but then again it seems always the same people no matter what someone posts. It was a learning too, so to maybe help one decide what oil to use or not in whatever have they. We sure have a lot of folks out here that tune in and pick apart, have a negative comment on pretty much everything out here. Well I did learn some things from his write up, he knows more then anyone else out here about engine oils.
FXDL is offline   Reply With Quote
Old January 26th, 2018, 11:59   #22
turbobrick240
I don't know man, the knowledgeable guys at BITOG and many other car forums aren't particularly impressed by rat540 either. And there are people here, like Tooslick, who have probably forgotten more about lubricants than rat540 will ever know. Thanks for posting up the info though.
Old January 26th, 2018, 12:05   #23
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
Mechanical Engineer = Fancy name for mechanic
U.S. Patent Holder (Mechanical device designed for Military Jet Aircraft)= invented a cup holder or coat hanger?
Member SAE (Society of Automotive Engineers) = I'm a member too.actually it's been years since I have been on the site.Certain licensed mechanics can be.Not difficult
Member ASME (American Society of Mechanical Engineers) = amerIcan version of above
Lifelong Gear Head, Mechanic, Hotrodder, Drag Racer, and Engine Builder = most Tdi life members aren't?
Sorry but this guy is all mouth, I'll trust the oil analysis I do to tell me me the oil I put in is doing it's job. Simples
Dannyboy is offline   Reply With Quote
Old January 26th, 2018, 14:02   #24
GoFaster
Moderator at Large
Just because you do a certain test on 200 different oils doesn't necessarily make that test relevant.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old January 26th, 2018, 16:02   #25
nicklockard
Torque Dorque
If I taste tested 200 engine oils and posted my observations, would that be relevant?
Old January 26th, 2018, 16:02   #26
GoFaster
Moderator at Large
Yeccch!
Brian P.
Old January 26th, 2018, 17:11   #27
MichaelB
Real world oil testing, good, better and best oils to fight wear. Some 209 oils tested. Very good site with real world testing of the oils. Check this site out if one hasn't already. There is oils for gas and oils for diesel tested. I have had this site for some time and thought I would share. Like it or not the oil we might be using, may not be all that good at fighting wear in our TDI's or gassers, motorcycles etc.. Oil company's, big and small say a lot on the bottle of oil we buy, but is it really true or as good as the we are are lead to believe, in some yes and many no. Very good info as when one looking for the best protection from their oil choice. https://540ratblog.wordpress.com/201...-test-ranking/
FXDL you believe everything you read.......try this http://xtremerevolution.net/expostin...est-data-blog/
What can I say. Now head back tobobtheoilguy as I believe he is using info from the 540 rat and posted on his site.
I did and this is what I found https://bobistheoilguy.com/forums/ub..._Rat_oil_tests
Old January 26th, 2018, 22:44   #28
Ol'Rattler
Ol'Rattler's Avatar
FXDL,
Make an appointment with your medical provider ASAP before your mental condition gets any worse. Once you get your Meds straightened out and are rational, we will be glad to debate any subject the forum allows.
I'm offering this from personal experience. Some of the poisons (Meds) that are prescribed to the public can have nasty side effects especially if the dosing is wrong or not followed.
Peace.....
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old February 6th, 2018, 05:52   #29
FXDL
First of all take your own meds and I can add a couple for you too. Second just because I posted for all to read and maybe learn from his testing doesn't mean I believe all he has claimed. Like the saying goes never believe what you hear and only half what you see. It was to learn from or not. One thing I have learn is the older I get the less I know and people around well I sometimes wonder.
Real-World Testing: Round 2 DubFamily Fuels & Lubricants 85 April 4th, 2015 22:48
Understanding Oil Specs in the Real World TDI_04_Driver Fuels & Lubricants 13 September 7th, 2011 00:43
Hydrogen Injection. Any scientific debunking or real world testing? Hvatum Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 12 May 19th, 2008 07:18
Need some real-world feedback MrMetal TDI Power Enhancements 1 March 15th, 2003 17:09
Page generated in 0.20248 seconds with 10 queries
[Output: 128.60 Kb. compressed to 107.80 Kb. by saving 20.80 Kb. (16.17%)]
