Old January 2nd, 2018, 13:18   #1
BeatJumper
Default TDI to SDI conversion?
My brother bought a pd115 AJM Audi A4 with a blown turbo because he needed a cheap runaround. he got to my house and no oil on the dipstick as well as smoke out the back. We take off the inlet and stuff and the compressor wheel can rub against the housing!
Now what we'll ideally do is remove the turbocharger and replace the cartridge and the feed line i broke
Considering the unknown history, high mileage, and my brothers budget i was wondering if we could block the oil line and direct the air from the filter to the intake manifold? I could also give it a little remap.
'm also having trouble removing the turbo; if i try remove the manifold i think it'll hit the cars frame and won't come off the studs. If i try removing the 3 turbo-to-manifold nuts the 12mm slips. Anyone got any advice?
BeatJumper is offline   Reply With Quote
Old January 3rd, 2018, 05:44   #2
JB05
Fuel Economy: 43/41/40
Can you pull the intake manifold? That is what is suggested for the MKIV's we have here to pull the turbo.
JB05 is offline   Reply With Quote
Old January 3rd, 2018, 08:32   #3
luke.weiser
Fuel Economy: 47.5
Someone on here did it to a Golf. He blocked the oil feed at the source by removing the bung and threading in a fitted bolt. Did 0-60 in 40-60 seconds, depending on outdoor temperature I assume.
luke.weiser is offline   Reply With Quote
Old January 3rd, 2018, 09:57   #4
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Here's the thread:
http://forums.tdiclub.com/showthread.php?t=479608
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old January 3rd, 2018, 11:51   #5
BeatJumper
Thanks for the thread link, It seems like a good option.
I've pulled the intake manifold and undone all the exhaust manifold + downpipe bolts. I'll have another go at removing the turbo on the weekend. Engine is longitudinally mounted.
sdi to tdi PD conversion the slob TDI Conversions 0 May 31st, 2010 13:14
SDI - TDI conversion paulukbristol TDI Conversions 5 October 26th, 2005 16:02
sdi to tdi conversion johnbu19 TDI Power Enhancements 3 February 5th, 2004 00:42
SDI TO TDI CONVERSION johnbu19 TDI 101 6 February 3rd, 2004 22:43
SDI TO TDI CONVERSION johnbu19 TDI 101 0 January 31st, 2004 10:38
Page generated in 0.12931 seconds with 10 queries
[Output: 67.20 Kb. compressed to 59.51 Kb. by saving 7.70 Kb. (11.46%)]
