Old January 2nd, 2018, 11:50   #1
Czimmerman1991
TDI(s): 2006 Beetle
Default TDI starter won't crank
I have a 2006 VW Beetle TDI that will not start. The weather in indiana have been in the negatives. The car was cranking and it was very weak. I went and got the battery and it was bad so I replaced in and put a new battery in it. The new battery got installed and the car cranked and tried to start and the made a beeping sound from the dash. Now I turn the keys and all the lights come come on but when I turn the key nothing happens. Any help would be appreciated I am new to the tdi world.
Czimmerman1991 is offline   Reply With Quote
Old January 2nd, 2018, 12:13   #2
AndyBees
AndyBees's Avatar
Seems some vehicles have an audio signal that comes on after long continuous cranking without the engine starting.
I'd check the battery terminals to make sure there is good contact. Obviously by now the battery needs a charge to bring it back up to power.
Of course, there's always the possibly the Starter has given up the ghost.
For what it is worth, I've used a hair dryer to blow hot air into the Intake while cranking the engine. But, that was years ago on the old MK1 VW diesels that had the filter intake snorkel located front and center.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old January 2nd, 2018, 12:24   #3
Mongler98
make sure that the connections are tight and that all cables are hooked up right. Other than that it should not be an issue. do you have a volt meter?
Old January 2nd, 2018, 13:10   #4
Czimmerman1991
TDI(s): 2006 Beetle
I tried jumping the car and it did nothing. I have had starters go out before and this starter did none of those things. I do have a volt meter. Do I need to disconnect the battery, wait and hook it back up to reset something? I didn't crank on it for long at all so I feel like the starter shouldn't of gone out.
Old January 2nd, 2018, 16:17   #5
AndyBees
AndyBees's Avatar
Czimmerman1991, there is nothing to "reset" to allow the Starter to operate when you turn the Ignition to Start.
Okay, just a couple of weeks ago, I purchased a nice Hard Back Bentley that covers your model. I've never looked at the Electrical Schematics of any TDI after the ALH engine.
So, what I am seeing, from the solenoid back >>> the current comes from a Power Supply Relay (J682) (#443 in the panel), ..........
Right now, it looks like Relay #443 get's it's cue from the Vehicle Electrical System Control Module (J519).
I'm having a hard time finding the Ignition schematic ....
I'll post more when I find it..
Old January 2nd, 2018, 16:37   #6
jettawreck
jettawreck's Avatar
Last year one of mine burnt the cable end off at the starter. It gave one grunt and then nothing. All the lights came on normally, just no click or engagement of the starter. It's fairly common as corrosion and age takes its toll. Then when you go to start and pull a heavier amp load than usual it lets go.
2004 Cadillac SLS (wife's)
Old January 2nd, 2018, 17:08   #7
AndyBees
AndyBees's Avatar
Well, all these Electrical Schematic terms are not going to mean much to the OP (or me).
But, it looks like the Ignition Switch (D) is part of the Steering Column Electronic Systems Control Module. That module is connected to the Vehicle Electrical Control Module via several small circuits (0.35 size) which has a 6.0 gauge wire for power. The next size down wire coming off the VECM is a 2.0 which goes to Relay 443 then on to the Solenoid ....... nothing is fused in that circuit. The activation circuit for Relay 443 is a 0.5 wire with no Fuse on the ground side and the power comes out of the VECM with no Fuse.
So, if the VECM had no power there would be lots of other things not working, in my opinion.
So, unless there is a corrosion or bad connection issue at the battery, starter, etc., the only thing, besides a bad Ignition, it looks to be that power relay, 443 may be culprit. However, if you remove the Solenoid wire and get 12 or more volts with the Ignition in Start Position, it would seem that the relay is fine. Don't check voltage with it connected to the Solenoid.
Old January 3rd, 2018, 09:15   #8
Powder Hound
Powder Hound's Avatar
It could also be that the ignition switch itself gets persnickety when the temperatures drop below, oh, say, -5*F. As they get old and more used, particularly if there are multiple keys hanging from the key fob at all times, the switches can wear and become intermittent.
Question: if you turn the key to start, and the move the key around while it is turned, does the starter suddenly work in some positions?
PH
Old January 3rd, 2018, 09:32   #9
steve6
Check the trigger wire on the back of the starter for 12v when key is in 'crank' position. If a signal there, and power to the big terminal, your starter is bad. Its most likely the starter burned out.
steve6 is offline   Reply With Quote
Old January 3rd, 2018, 10:33   #10
dandywriter
What battery did you install? How many Amp-hours?
2006 Jetta TDI 5-sp, Bosal hitch, frostheater, evo skidplate, upgraded rear springs and front spring dist kit (1" lift), GIAC Stg 1 tune, USA Spec iPod adapter, SMF clutch, Coolant Heater Grill Outlet, winter front, LED backup and lic lights, VCDS
dandywriter is offline   Reply With Quote
Old January 3rd, 2018, 12:09   #11
Czimmerman1991
TDI(s): 2006 Beetle
Powder hound, the only have 2 other keys on my fob. I tried wiggling the key when I was trying to get it to start but had no luck. I put an exide 47-60 battery in the car I'm not sure what the amp hours is on it. I'm am starting to leat towards it is the starter but haven't had the chance to check the voltage going to it.
Won't start, won't crank, weird electrical symptoms reildawg TDI 101 5 September 15th, 2017 10:15
2011 TDI won't start on first crank? LostArk TDI 101 2 June 6th, 2017 23:14
99.5 ALH won't start, won't crank...? JettaTDlie VW MKIV-A4 TDIs (VE and PD) 26 June 3rd, 2016 00:21
2002 Jetta tdi won't crank akersanth VW MKIV-A4 TDIs (VE and PD) 4 June 22nd, 2013 11:34
1999.5 tdi long crank time to get started cold joelala Ontario 17 June 9th, 2010 03:17
Page generated in 0.15299 seconds with 10 queries
[Output: 103.41 Kb. compressed to 87.74 Kb. by saving 15.67 Kb. (15.15%)]
