Old January 10th, 2018, 00:06   #31
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
check for restrictions in the return circuit too. If it's running a good level of control it should be easing the pressure back *before* it gets to setpoint and if it can't do this as fast as the program expects, there'll be an overshoot.
DPM is offline   Reply With Quote
Old January 10th, 2018, 06:23   #32
altz1
Im pretty sure its about tuning. If you check the logs, you see actual doesent reach specified when the problem occurs. Id like to see pcv duty also while on the same graph, then would be easy to find the real cause.
Do you get rp too low fault also? If supply is ok, and return is free then pcv itself can also be worn. If it would overshoot and undershoot while demand is steady, then it would be pid control fault.
Edit: red line is specified rp and what is greenline?
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Audi 4.2TDI project 650hp/1200nm goal.
altz1 is offline   Reply With Quote
Old January 10th, 2018, 09:26   #33
travis45
travis45's Avatar
altz1, on that graph I pulled values from group 18, 19 and 21. Yeah, that doesn't make sense, some of them are labeled the same but are displaying different data. I'll look into that.
I don't get any codes.
14 Sportwagen TDI CR170 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD.
travis45 is offline   Reply With Quote
Old January 16th, 2018, 15:18   #34
eddie_1
eddie_1's Avatar
Did you find out any more on this? Would be interested to hear any feedback. Have you tried adjusting some of the maps to potentially hit a different operating point? Since you said it was intermittent, maybe it is only partially unstable.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old January 16th, 2018, 20:54   #35
travis45
travis45's Avatar
Yes, experimenting with a new calibrated tune this week. Just got a flashzilla and need to get it set up. Should have more info in a few days.
Old January 20th, 2018, 20:38   #36
travis45
travis45's Avatar
Things are looking up... needs more testing..
[img]http://pics.tdiclub.com/data/500/thumbs/
url=http://pics.tdiclub.com/showphoto.php?photo=126338&title=screenshot-20180120-213359&cat=500]
Old January 21st, 2018, 13:34   #37
xjay1337
So it was the tune?
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 340hp 625nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old January 21st, 2018, 18:22   #38
travis45
travis45's Avatar
http://log.malonetuning.com/chart/22...fCjwAAAA%3D%3D
Tweeking the tune, it's seems to be getting better.
Old January 21st, 2018, 22:58   #39
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
I would say its much better than what you started with. Well done!
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old January 22nd, 2018, 06:08   #40
eddie_1
eddie_1's Avatar
Nice! Congrats! Any hints to where the issue was? I am thinking either how the rail pressure was ramped up or the timing/duration?
Old January 22nd, 2018, 19:43   #41
travis45
travis45's Avatar
Malone has done something, what exactly I don't know, but it is working.
Couple of bugs to work out yet, but the driveability is greatly improved with acceleration stabs smooth.
Only thing I'm worried about is that we are tuning around some other underlying issue.
At any rate, it's working and I am pleased.
Old January 22nd, 2018, 23:43   #42
altz1
Jep, seems it was the tune, as usually. Im sure he adjusted the pid maps of fca/pressure control valve. There might have been even some missed rail pressure limiter that made it to drop rapidly after hitting specified value. Good you got it sorted.
Old January 23rd, 2018, 05:17   #43
ryanp
ryanp's Avatar
You fitted a different pump and Malone tuned it to suit, no underlying issue.
Also bear in mind the people who helped out with this behind the scenes were nothing to do with the parts supply and did not charge anything to help. The people supplying your parts clearly just copied someones parts and does not understand how it all works!
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old January 23rd, 2018, 07:54   #44
Macradiators.com
Well Ryan if you wanna throw stones, you should know my kit is made in house from 0, not having copied anyone. Designed from 0 e tested on my own car because i was denied 1 kit for my own use.
It just pisses you off i know. Reaching 90 kits sold in Europe in 6 months, and all work just fine since i use bosch reconditioned pumps with warranty.
If you feel so generous please offer the CP3 calibrations for free for everybody to have as i am sure Ruben and Bobby are intelligent enough not to share them.
Till now for stage 1-2 no calibrations were needed. This is a first and its the tuners job to take care of it.
Without any calibrations it looks like this on stock software across Europe. Got a few graphs.
And car goes like this without any calibrations:
https://www.youtube.com/watch?v=0OgXNIdbuPc
CP3 Upgrade
Old January 23rd, 2018, 07:55   #45
ryanp
ryanp's Avatar
Lol, Never fitted one that does not need calibrating
CP3 fuel pump upgrade thread YukonLT VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 275 February 14th, 2018 19:07
01 ALH stage 4 no tune not burning fuel carsaremytoys VW MKIV-A4 TDIs (VE and PD) 4 November 6th, 2017 03:00
fueling problems a few months after stage 2 and CP3 upgrade skycrane VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 February 18th, 2017 12:25
How much strain on the engine is it if I tow with a stage 1 or stage 2 tune? andruxin TDI Power Enhancements 16 May 14th, 2012 13:59
FS: NIB 2.0 TDI fuel pump (Bosch common rail CP4S1) 16v dubber Private TDI Items for Sale/Wanted 2 January 20th, 2012 13:44
Page generated in 0.19066 seconds with 10 queries
[Output: 132.79 Kb. compressed to 110.72 Kb. by saving 22.07 Kb. (16.62%)]
