Old January 5th, 2018, 04:24   #16
travis45
travis45's Avatar
Xjay, I appreciate your comments. I'm to the point where I need to eliminate any possible variables.
It must interact on some level as it can do things like mirror dip etc. I have heard that they can go bad and leave you stranded. Also, if the tune was flashed via the ODB port, it's through that device. Could it affect? I don't know? I'm out of ideas except to remove it, recheck all connections and reflash my tune.
Respectfully,
Travis
Again, just want to eliminate any possible variables.
14 Sportwagen GTB2260vklr Turbo, Rawtek turbo back exhaust, Malone custom tune, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS, Darkside intercooler and piping, Wavetrac LSD. Soon to install Colt billet stage 3 cams w/upgraded springs, ARP Headstuds.
travis45 is offline   Reply With Quote
Old January 5th, 2018, 05:13   #17
Kevinski4
Kevinski4's Avatar
Originally Posted by xjay1337 View Post
The Polar FIS can't cause an impact.
All the Polar FIS is, is a way to interact with the onboard systems and display data.
In exactly the same way that VCDS works (that's why if you have a Polar FIS you cannot have the display pages open when you are using VCDS).
Just because you don't get rail p issues in one log doesn't mean the tune is OK.
It could be a hardware or software issue, but I can guarantee the Polar FIS is not causing an issue.
Saturating the CANBUS can certainly cause some wonky stuff. I've seen it on other applications before where so much data was being requested by the CAN logger that it totally screwed up how the engine ran.
This would not be the first time I've personally seen a Polar FIS cause a serious problem.
I am a Malone Tuning dealer in Eastern WI, including Common Rails and DSG, Sprinter, and BMW! Visit our website: www.facebook.com/wisconsindiesel
Forget Clean Air, It's a Power and Money Grab
Kevinski4 is online now   Reply With Quote
Old January 5th, 2018, 07:17   #18
travis45
travis45's Avatar
Didn't get a chance to pull the PolarFIS, but I turned it off (switched to MFI screen) on the way into work today and the car ran without the oscillation.
Not sure if it would have an impact on rail pressure, but since I've installed the first CP3, I've always had the rail pressure displayed on the PolarFIS.
Oh, I hope this is the answer... When running properly and driven hard, it's a one tire fire. Wavetrac is in the mail!
Old January 5th, 2018, 07:43   #19
xjay1337
As I said, I have had no issues with Polar FIS. I've had mine installed for 3 years from stock right through to my level of tune now.
When we first installed the CP3 on my car we also had large rail pressure variations (similar to what OP has logged and shown).
Once tuned suitably my rail pressure is very stable and it does not impact whether I have the Polar FIS enabled, disabled or up my butt
It's exactly like running the car with VCDS connected.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 395hp 660nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old January 5th, 2018, 14:33   #20
travis45
travis45's Avatar
Been driving with the PolarFIS turned off and seems to be doing good.
Hard to identify unless I'm driving the car hard and that can make for an interesting ride to work.
Going to pull the PolarFIS, drive more, log and restore my tune to full fuelling early next week.
More info to come in the next few days.
I don't want to jinx it, but all the anecdotal evidence is all pointing to the PolarFIS. It's really too bad, because it is a neat gadget. I think I heard that you can update the firmware. Not sure if that would make a difference or not. Either way, I don't want to use a device that could potentially restrict or interrupt communication amongst the components.
Respectfully,
Travis
Old January 5th, 2018, 15:15   #21
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Told you polar fis was giving me issues, so i took it down.
VCDS connected to the car also did not work ok with polarfis, communication issues, . I will put it back after i am done, maybe.
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old January 5th, 2018, 16:01   #22
xjay1337
Mac, Polar FIS and VCDS will not work simultaneously.
All you need to do is tab off the Polar screen on the MFD.
It's like accessing databases .... only so many connections allowed.
You can update the Firmware yes. If you haven't done so I'd probably try that.
If it is giving you issues then it's due to a FAULTY unit.
Old January 5th, 2018, 22:52   #23
Macradiators.com
Good to know, i will try to update it although i got it 1 year ago, maybe not that old FW.
CP3 Upgrade
Old January 6th, 2018, 11:49   #24
travis45
travis45's Avatar
Well, back to the drawing board...
Removed PolarFIS this morning and went for a ride. Here is a snip from the log..
The oscillation was there just about every time, but I did capture one pull without the oscillation. Then after I stopped the log, and turned off VCDS, I did have one nice smooth pull.
PolarFIS has been ruled out. I did unplug the metering valve and it appears okay. When in installed the new plug I may have the wires crossed? Could that create an issue? You wouldn't think it would be intermittent though...
Must be a bad connection or broken wire?
Damn this is infuriating... any thoughts appreciated.
Travis
Old January 9th, 2018, 05:12   #25
HamBam
TDI(s): All
I had the same problem with that pump. I installed a new! valve (Bosch) on that pump and from this point i had no more oscillations.
HamBam is offline   Reply With Quote
Old January 9th, 2018, 06:45   #26
travis45
travis45's Avatar
I've literally tried 3 different genuine Bosch metering valves. Two used and one brand new.
Thing that gets me is that sometimes it works perfectly. Mostly it does not.
HamBam, were your oscillations only at wide open throttle like mine or was it in a greater range?
Thank you for your comments.
Travis
Old January 9th, 2018, 07:04   #27
xjay1337
Do I need to suggest the tune again?
I had an issue on a test tune on my stock CP4 pump
Pushing big IQ to see how far the stock pump would go.
If I drove normally, it was fine, and flat out -
If I drove at a steady 2000rpm for a few seconds, in 2nd gear and then accelerated, I would get low rail P.
If I avoided doing that particular "thing" it would be fine.
I suspect you have an issue in your tune, but the particular parameters that are required for it to fail are not being achieved every time.
This is where simply asking on a Forum for help is not a good idea. You need to work with a trusted tuner if possible.
If Malone did your tune and they are not in a location that you can drop the car off they should be asking you to log using VCDS, and give them data.
Old January 9th, 2018, 07:15   #28
travis45
travis45's Avatar
Yes, tune is next. Malone has been assisting and we will be de-tuning to stock w/deletes to verify tune is not the issue.
But Xjay, if tune is the issue, then why does everyone else with the same hardware and identical tune have no issues?
I have been logging and sending them my logs. Mostly group 21. Can you suggest any other groups to log that would explain the situation better?
Respectfully,
Travis
Old January 9th, 2018, 08:31   #29
xjay1337
Respectfully,
Travis
If you dig a little deeper, there are many people with various CP3 kits running into issues, especially if they are tuned. I know personally of 4 cars in Europe with rail pressure problems on cp3 kit.
And even so, every tune is (or should be) different. So there could be many things different between two tuned cars. Maybe some cars have minor nuances due to old hardware/injectors/lift pump that can cause slightly different results.
I think it's the tune. Malone can assist , I'm sure.
Old January 9th, 2018, 19:48   #30
travis45
travis45's Avatar
Took another log tonight which includes the control deviation from group 19. Not sure if it sheds any light on how to pinpoint the tuning tweeks or not. But it is some more data. It looks to me like the over pressurization of the rail occurs first, and then there is an overcompensation which leads to the oscillation...
CP3 fuel pump upgrade thread YukonLT VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 344 October 17th, 2018 15:17
01 ALH stage 4 no tune not burning fuel carsaremytoys VW MKIV-A4 TDIs (VE and PD) 4 November 6th, 2017 02:00
fueling problems a few months after stage 2 and CP3 upgrade skycrane VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 February 18th, 2017 11:25
How much strain on the engine is it if I tow with a stage 1 or stage 2 tune? andruxin TDI Power Enhancements 16 May 14th, 2012 12:59
FS: NIB 2.0 TDI fuel pump (Bosch common rail CP4S1) 16v dubber Private TDI Items for Sale/Wanted 2 January 20th, 2012 12:44
Page generated in 0.19793 seconds with 10 queries
[Output: 137.16 Kb. compressed to 115.08 Kb. by saving 22.08 Kb. (16.09%)]
