Old January 1st, 2018, 13:34   #1
travis45
travis45's Avatar
Default Help! Fuel Rail Oscillation- CP3 pump/Stage 3 Tune
All,
I wanted to share my experience and am hoping someone can assist me in trouble shooting this situation. I installed a CP3 pump. Car runs well at low throttle/RPM. Step on it and I get this....
I've contacted Malone and they are reviewing. I've changed the fuel rail regulator, metering valve and now finally swapped the pump out. I'm at a loss of where to turn next. Malone has many cars with my setup and no problems.
Any suggestions on what to look at next are appreciated.
Respectfully,
Travis
14 Sportwagen TDI CR170 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD.
Last edited by travis45; January 1st, 2018 at 13:41. Reason: Added pictures more..
travis45 is offline   Reply With Quote
Old January 1st, 2018, 13:52   #2
turbobrick240
turbobrick240's Avatar
Did this problem emerge when cold weather hit? If so, your filters may be getting restricted with wax or ice.
Old January 1st, 2018, 13:57   #3
travis45
travis45's Avatar
It began when I first installed the CP3 pump. (The first one..). This was months ago. At the time we thought it was bouncing off the EGT limiter. I had my stage 3 tune defueled somewhat and the EGT's are good and there was no change to the rail pressure situation.
I'm out of ideas on where to turn next. I'm thinking about running a small container of diesel directly to the pump to eliminate any fuel starvation issues pre hpfp.
Old January 2nd, 2018, 05:53   #4
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
Well we know that there is no calibration in your software for the CP3 to run as it should.
Usually stage 1-2 goes ok without any calibration.
Bobby and Ruben may have different opinion on this, if they wanna share with us.
The pump you have is not regenerated or revised/tested in bosch center, so there is no warranty on it.
I will anyway change it at my own expense. Better to have a happy client.
Since then i only installed about 50 kits with revised pumps and all work flawlessly.
Anyway making the cp3 work as it should with high pressures and big IQ is not so easy. I dont think many tuners achieved that.
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Old January 2nd, 2018, 09:34   #5
xjay1337
I only know of one other big power Cp3 car that runs smoothly, other than mine.
Bobby Singh did my tuning.
Hybrid VKLR, BSR Ported Head, BSR Valve Springs, BSR CP3, 340hp 625nm Built and mapped by Bobby Singh , THS IC, Revo/Forge Custom Intake, Mocal Oil Cooler, 3 Eurojet TBE, AKS Quickshifter, Recaro Pole Positions, Schroth 4 point harnesses, Rear seat removal, R bumper, Carbon Fibre GT24 Bonnet, VWR Spoiler, OZ 18x9 Et43, AM DB9 front brakes, Audi S3 rears, Polar FIS, Hertz Audio
xjay1337 is offline   Reply With Quote
Old January 2nd, 2018, 10:21   #6
travis45
travis45's Avatar
Thanks for your responses. The thing is, I'm not running big power. I should only be around 200 horsepower with my setup.
Mac, while I appreciate the offer for a new pump and will gladly accept it, I don't believe changing the pump for a third time will make any difference unless there is something different about the Bosch reman.
Both pump 1 and pump 2 installed made pressure. It must be a controls or controls hardware issue.
Respectfully,
Travis
Old January 2nd, 2018, 10:59   #7
740GLE
Have malone give you a stage 2 tune, then you can see if it's the tune or the hardware.
Old January 2nd, 2018, 11:06   #8
turbobrick240
Have you tried pulling the supply hose off the filter and powering the in-tank pump? Maybe there is a restriction somewhere. I'd also make sure no fuel hoses are kinked. My stage 3 malone tune and CP3 work great together.
Old January 2nd, 2018, 11:24   #9
travis45
travis45's Avatar
Thanks. Going to check both. Tune and possible fuel restriction.
Old January 2nd, 2018, 11:45   #10
Macradiators.com
You tried 2 pumps on the car and all manifest the same problem? Then its not the pump but something else somewhere.
My runs perfectly smooth but there is room from improvement.
When i get maximum 50bars of +- arond 2200bar i will be happy. Right now is more like +80 -100
Maybe is time for Malone to test some calibrations on the pump.
CP3 Upgrade
Old January 2nd, 2018, 14:38   #11
Macradiators.com
A friend is saying that the original file i got from Mark Malone is different from european cars.
CP3 Upgrade
Old January 2nd, 2018, 17:38   #12
travis45
travis45's Avatar
Mac can you please explain further? What does that mean?
I would expect that the stock tune for North America would be somewhat different.
Respectfully,
Travis
Old January 4th, 2018, 00:46   #13
altz1
Looks to me you need to adjust PID map for PCV. I would test with disconnected FCA, then it has full fueling from pump side. If still its same, then PCV pid needs adjustment.
Ofc it would be nice to rule out feed problems, but i doubt there is the case.
Audi A8 4E 4.2TDI 522hp, 1100nm. - Sold
Audi Q7 4.2TDI 410hp, 900nm. - Sold
Audi 4.2TDI BVN quad turbo project 650hp/1200nm goal, no chassis jet.
altz1 is offline   Reply With Quote
Old January 4th, 2018, 19:24   #14
travis45
travis45's Avatar
Well, I think we can rule the tune out as the issue. Last night I took a log and the first pull had the oscillation and the rest just magically didn't. Took a log at lunch today and it is perfect.
I did a 3rd gear pull and it was a one tire fire all the way. Smooth acceleration.
I was so happy. But at the same time worried because the problem wasn't answered. Then on the ride home the oscillation returned. So at least this proves my hardware and software can work properly.
My next guess is to remove the PolarFIS and triple check all wiring connections. It has been brought to my attention that the PolarFIS could be interfering somehow. An easy check. Is anyone out there in TDI world running a common rail with a stage 3 tune and CP3 pump with a PolarFIS? How does it work?
This has been making me absolutely crazy. I will savor the triumph when this gremlin is finally defeated...
I want to thank everyone who has taken the time to help me sort this out. Owain from Malone, Andrew Dreossi, Macradiators, and my local tuner Kevinski.
I kind of feel like I've got the superfriends to help me. As somebody who is wading into uncharted territory, it's great to have the support of these folks.
Let's see what happens when I pull the FIS and pull on the wires...
Respectfully,
Travis
Old January 5th, 2018, 05:00   #15
xjay1337
The Polar FIS can't cause an impact.
All the Polar FIS is, is a way to interact with the onboard systems and display data.
In exactly the same way that VCDS works (that's why if you have a Polar FIS you cannot have the display pages open when you are using VCDS).
Just because you don't get rail p issues in one log doesn't mean the tune is OK.
It could be a hardware or software issue, but I can guarantee the Polar FIS is not causing an issue.
01 ALH stage 4 no tune not burning fuel carsaremytoys VW MKIV-A4 TDIs (VE and PD) 4 November 6th, 2017 03:00
CP3 fuel pump upgrade thread YukonLT VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 273 October 27th, 2017 12:39
fueling problems a few months after stage 2 and CP3 upgrade skycrane VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 February 18th, 2017 12:25
How much strain on the engine is it if I tow with a stage 1 or stage 2 tune? andruxin TDI Power Enhancements 16 May 14th, 2012 13:59
FS: NIB 2.0 TDI fuel pump (Bosch common rail CP4S1) 16v dubber Private TDI Items for Sale/Wanted 2 January 20th, 2012 13:44
Page generated in 0.13416 seconds with 10 queries
[Output: 130.76 Kb. compressed to 108.59 Kb. by saving 22.18 Kb. (16.96%)]
