Old January 2nd, 2018, 21:32   #31
need4speed
need4speed's Avatar
(It is true that the dash temp gauge can be way off. I've read 190 at the dash, and 210 from the ECU. . . the BMW guys have a way of re-mapping the dashboard gauge so it reads more accurately; I wonder if the folks at Ross-Tech have looked into that?)
2003 Jetta 4dr TDI.
G60/VR6 flywheel/clutch. VNT 17 retrofit.
Never. Trust. Dealers.
need4speed is offline   Reply With Quote
Old January 3rd, 2018, 09:11   #32
Powder Hound
Powder Hound's Avatar
Ross-tech will not reprogram the ECU by agreement with VW. They promised they'd never do that in return for some other things, probably some intellectual property access (just a conjecture on my part).
There are others that can do it, however. At the very least, you'd need some kind of programming tool. VCDS is NOT it.
I think there is at least 1 thread on this site somewhere that tells about doing it. Search might do what you need as far as finding your answer.
Cheers,
PH
Old January 3rd, 2018, 17:41   #33
Beerbaron666
TDI(s): 2000 Jetta
I plugged the car in and the temp guage wasn't that far off only a few degrees, but I still can't seem to get a steady flow from the return hose. I tried blowing air into the return line to try and push the fluid back hoping it would purrge the air bubble (if that is the problem) it tried a syphon pump to suck the fluid back through the return line and still seems to "burp" back into the tank. If I pull the return line off and put a little air into the sealed tank it will flow steady until I release the pressure but still won't flow steady when running
Beerbaron666 is offline   Reply With Quote
Stumped on my no heat Beerbaron666 VW MKIV-A4 TDIs (VE and PD) 3 January 1st, 2018 13:11
need heat CV joint heat shield & bolts '03 almus Private TDI Items for Sale/Wanted 4 July 18th, 2011 09:01
Oil Leak Passenger Side Exhaust Manifold Heat Shield (I'm stumped) honesttussey TDI 101 9 October 16th, 2008 20:24
Heat Box Replacement - Low Heat Output Tom_Phillip VW MKIII-A3/B4 TDIs 8 May 9th, 2007 04:22
Heat from defrost but no heat from vents on dash barney5116 TDI 101 0 January 25th, 2006 20:27
Page generated in 0.11550 seconds with 10 queries
[Output: 59.99 Kb. compressed to 54.53 Kb. by saving 5.46 Kb. (9.09%)]
