Old January 1st, 2018, 11:47   #1
Beerbaron666
TDI(s): 2000 Jetta
Exclamation Stumped on my no heat
Hi there, I've been lurking on here since I got my TDI just over a year ago and found a lot of useful info from the members here. I come across a problem that I just can't seem to figure out and was hoping someone could give me an idea that I haven't tried yet. I have a 2005 Jetta with no heat and since the Canadian winter is kicking in it's getting pretty damn cold lol. I just replaced the timing belt and water pump, new thermostat and housing, I've checked the blend doors and they are moving and the foam is still good, I've flushed the heater core and water flows through it fine , I've pulled off various hoses and flushed them and everything seems to flow fine. The car gets up up to operating temp and holds fine but I just can't seem to get any heat at all, I'm stumped here I've done everything I can think of and hoping someone here can point me in a direction I haven't thought of yet. Thanks in advance for any help.
Beerbaron666 is offline   Reply With Quote
Old January 1st, 2018, 11:59   #2
turbobrick240
turbobrick240's Avatar
Maybe air locked? I'd try parking the car on a very steep uphill incline to encourage any trapped air to find its way out. Temporarily disconnecting the hose to the expansion tank (with the front end raised) might also help to evacuate any air.
Old January 1st, 2018, 12:09   #3
Beerbaron666
TDI(s): 2000 Jetta
Thanks I'll give it a go and see what happens , should I see coolant recirculating when the engine is cold or (I'm guessing) hot?
Old January 1st, 2018, 12:12   #4
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
Why 2 threads?? http://www.forums.tdiclub.com/showthread.php?t=485141
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old January 1st, 2018, 12:16   #5
Beerbaron666
TDI(s): 2000 Jetta
Originally Posted by JDSwan87 View Post
Ya that's my bad , I posted the other thread first but didn't see it show up anywhere I thought I screwed it up.
Old January 1st, 2018, 14:44   #6
scooperhsd
#1 - The earlier TDIs don't warm much - if you want interior heat, observe the following
A - unless you're using the defrost, turn on the Recirc
B - DON'T turn the fan above 2-3 - you can literally cool off the engine in winter doing this
C - this is one time the automatics have an advantage over the manuals - the same coolant also cools the transmission
D - two words (if you car has them) -"Electric seats" - don't set them too high or you can burn your backside. But they help greatly
E - If you're one of those people who take your coat off in the car, expecting it to keep you warm - get out of that habit.
F - TDIs can actually COOL OFF at stop signs / lights
G - TDIs don't warm very well unless you're working them - the harder the better. A good suburban / highway helps a great deal. Corollary to this - they don't warm up very much at idle. It will stop running rough like a truck after a minute or so, but not much beyond that. starting in cold weather, an experianced TDI driver will start his car, get belted in / other things prior to moving, then take off at a moderate pace.
H - Consider warmer clothing for the driver and blankets for the back seats / FS passenger
Hope this post helps.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old January 1st, 2018, 15:56   #7
maxmoo
1) make sure that your thermostat is working.
2) Install pipe insulation foam in all your grill slots.
How to block your front grill with pipe insulation....
http://forums.tdiclub.com/showthread.php?t=160835
maxmoo is offline   Reply With Quote
Old January 1st, 2018, 16:09   #8
alame
TDI(s): 2005 Passat
how much water is in the rad and can you see it circulating when the engine is running ((hot) meaning the thermostat is open ?
alame is offline   Reply With Quote
Old January 1st, 2018, 16:48   #9
Beerbaron666
TDI(s): 2000 Jetta
I havent really looked to closely at the flow, but the upper rad hose gets hot and the lower is cold so to me i would guess the thermostat would be working. the system pressurizes all the hoses get warm or hot except the one heater core hose only gets slightly warm.
Old January 1st, 2018, 16:59   #10
UhOh
UhOh's Avatar
Have you ever gotten heat output from your cabin heater (heater core)?
There are two heater core hoses. You cay that one gets only slightly warm, but what about the other one? If one is hot and the other not I suppose it's possible that the heater core is plugged up.
Old January 1st, 2018, 17:35   #11
Beerbaron666
TDI(s): 2000 Jetta
The heater worked fine when i got the car just over a year ago, the one hose that goes to the hard line that runs back for the oil cooler and back to the block get warm but the other that comes off the side of the engine is warm close to the engine but is cold closer to the heater core. I just took the car for a drive to get it as warm as i could and pulled off a couple of the smaller hoses and they seem to "pulse" they dont seem to have a steady flow. the warmest i could get the car was 87 (188.7) those are the numbers from VCDS, the car has a 190 thermostat, could it be not opening fully at that temp and limit the flow?
Old January 1st, 2018, 18:04   #12
turbobrick240
Yeah, that sounds like classic air locking. I forgot to mention that you should let the car idle for about 20 minutes while parked on the uphill slope with the expansion hose unhooked.
Old January 1st, 2018, 18:39   #13
joetdi
Do you carry passengers in front much?
joetdi is offline   Reply With Quote
Old January 1st, 2018, 19:44   #14
Beerbaron666
TDI(s): 2000 Jetta
I'm going to give it a try tomorrow and see how it goes, thanks for the help
Old January 1st, 2018, 19:47   #15
Beerbaron666
TDI(s): 2000 Jetta
I do yes , not so much now that's it's cold out and I have no heat Driving our Jeep is starting to kill me on fuel lol
Stumped on my no heat Beerbaron666 VW MKIV-A4 TDIs (VE and PD) 3 January 1st, 2018 12:11
need heat CV joint heat shield & bolts '03 almus Private TDI Items for Sale/Wanted 4 July 18th, 2011 08:01
Oil Leak Passenger Side Exhaust Manifold Heat Shield (I'm stumped) honesttussey TDI 101 9 October 16th, 2008 19:24
Heat Box Replacement - Low Heat Output Tom_Phillip VW MKIII-A3/B4 TDIs 8 May 9th, 2007 03:22
Heat from defrost but no heat from vents on dash barney5116 TDI 101 0 January 25th, 2006 19:27
Page generated in 0.18406 seconds with 10 queries
[Output: 126.50 Kb. compressed to 105.78 Kb. by saving 20.72 Kb. (16.38%)]
