Old December 31st, 2017, 12:27   #1
Sayewhat
TDI(s): JSW
Default 01179 - Incorrect Key Programming 000 - - Problem
I bought a 2009 JSW and it came with one key. I ordered a new one from a very reputable non-dealership. I took the key to the dealer to get it programed to the car. They were able to get the key programed, but not program the locks. I called the company I bought it from and talked to them about it. They were very helpful and sent me out two more chipsets and the VAG-COM cable to program it myself. I have attempted several times following the directions exactly. I have un-programmed my original key and programmed it back, so I know its correct. The problem is that I cannot get it programmed either nor with the other chipsets. Any ideas on where to start?
The main faults are: 2 Faults Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 193729 km
Time Indication: 0
Date: 2000.00.00
Time: 11:08:07
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 5
Reset counter: 103
Mileage: 0 km
Time Indication: 0
__________________________________________________ _________
Wednesday,27,December,2017,21:22:00:42304
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(VMWare)
VCDS Version 17.8.1.0 (x64)
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: 3VWTZ71K39M306841 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 4F 52 56 62 65 72
VIN: 3VWTZ71K39M306841 Mileage: 193760km-120396miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 M HW: 07K 906 055 M
Component: 2,5l R5/4V G 9971
Revision: G6H02--- Serial number: VWX7Z0HN24L06P
Coding: 0000075
Shop #: WSC 14250 002 1048576
VCID: 387F40F54BF6CB8669-806D
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
Component: AQ 250 6F 1377
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 00066 000 00000
VCID: 7DF191E124542EAEFA-8029
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 113B400D49220000881302E8921A00413000
VCID: 74E7B4C5D71E6FE685-8021
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 78FF80F50B760B86A9-802D
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000001136266
Coding: 148D8F2340041000070000001C000000000873075C00012000 0000000000
VCID: 326B72DDAD8A21D657-8067
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 251108 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0479380
Coding: 0000100
VCID: 336577D9529028DE5C-8067
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 26
Reset counter: 49
Mileage: 192417 km
Time Indication: 0
Date: 2000.00.00
Time: 07:11:56
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 78 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M085B9W
Coding: 0014136
VCID: 6CD7ACA54F2EB7265D-8039
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME41332D412
Subsystem 3 - Serial number: 6342MSME42712F29E
Subsystem 4 - Serial number: 6351HSME190D0D35B
Subsystem 5 - Serial number: 6361HSME190D172DE
Subsystem 6 - Serial number: 63727SME19434D4A8
Subsystem 7 - Serial number: 63827SME19606366+
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 052 0111
Coding: 0001032
VCID: 020BE21D5DAA515687-8057
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0HN24L06P
Coding: 0007203
Shop #: WSC 12345 067 57207
VCID: 3C775CE57FCEE7A68D-8069
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 R HW: 1K0 907 951
Component: J533 Gateway H06 5063
Revision: H06 01 Serial number: 191108F2000116
Coding: ED807F070003032002
VCID: 36634ECD41E23DF67B-8063
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 1222
Shop #: WSC 58770 001 1048576
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000769389106
Coding: 0001205
VCID: 6FEDBBA97E384C3E78-803B
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5B6ABD855A6916EF-807F
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139007885283281B0904058FB0880F0488DCA0
VCID: 0407E40547BE5F66B5-8051
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 103
Mileage: 193729 km
Time Indication: 0
Date: 2000.00.00
Time: 11:08:07
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 103
Mileage: 0 km
Time Indication: 0
Address 4F: Centr. Electr. II (J533) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 050B0500
VCID: 66C3DE8D91C28D760B-8033
Subsystem 1 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J394EE16SKB10 H01 0180
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08081618263701
Coding: 0001204
VCID: 70EFB8D5630653C661-8025
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2256643
Coding: 0010400
VCID: 295995B1805C620EE6-807D
3 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
01044 - Control Module Incorrectly Coded
000 - -
00003 - Control Module
014 - Defective
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003668396
Coding: 0001168
VCID: 76E38ECD01627DF6BB-8023
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003636253
Coding: 0001168
VCID: 77FD83C9066804FEA0-8023
End-------------------------(Elapsed Time: 02:09)--------------------------
Sayewhat is offline   Reply With Quote
Old December 31st, 2017, 13:37   #2
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Make sure the doors are locked when programming. You might be able to do it the non-VCDS way with good key in the ignition and the other in the door.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old January 2nd, 2018, 08:42   #3
Sayewhat
TDI(s): JSW
thanks. I've tried with the doors unlocked and the non-VCDS way also. I'm kind of baffled at why its not working.
Old January 2nd, 2018, 09:04   #4
jokila
jokila's Avatar
Sounds like you need to investigate the key fob part. Have you compared the code on it to the working key?
Old January 2nd, 2018, 13:53   #5
Sayewhat
TDI(s): JSW
I haven't. Not sure how to do that one.
Old January 3rd, 2018, 07:05   #6
jokila
jokila's Avatar
Separate the key halves by pulling them apart. There are numbers on the end of the remote control part of the FOB that need to match. See pic:
Old January 3rd, 2018, 10:31   #7
Sayewhat
TDI(s): JSW
Here are the chips. The one with the single and part of the FOB are the original working ones.
Old January 3rd, 2018, 15:52   #8
jokila
jokila's Avatar
I never meant for you to strip it down to the chip board. Look at the code in the pic I posted. It's probably not going to match your keys, but that style long code should ideally match on each of the keys. You are displaying one of the codes in your pic.
Old January 3rd, 2018, 16:13   #9
Sayewhat
TDI(s): JSW
lol. I've gotten used to taking them apart lately. I've swapped all the chips out trying to get one to work. The other one (replacement) doesn't have any markings on it like the original has.
Old January 3rd, 2018, 16:24   #10
P2B
P2B's Avatar
I think the OP means the vendor he is working with sent him replacement PCBs only, if so looking at the numbers on the fob housing is not going to help.
OP, do the numbers on any of the black surface mount chips match those on the working one? If not, that's probably an issue.
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Old January 3rd, 2018, 16:30   #11
Sayewhat
TDI(s): JSW
None of the new chip numbers match the original, however they are the same chipset if that makes sense. The original chip doesn't match anything engraved on the original FOB either.
2001 TDI Key Programming Problem + Instrument Cluster failure! Freddy B TDI 101 8 November 22nd, 2016 05:53
VCDS BEW Implausible Passenger Lock Module + Incorrect Key Programing jettasetta OBD Scanners 3 October 18th, 2014 18:39
01179 - Incorrect Key Programming 2000 Jetta Please HELP ndamico TDI 101 11 October 2nd, 2009 15:32
Incorrect Key Programming code a problem? TurboSlug TDI 101 5 October 3rd, 2008 21:31
Incorrect Key Programming? festivenuts OBD Scanners 9 March 26th, 2006 18:45
Page generated in 0.15868 seconds with 10 queries
[Output: 114.86 Kb. compressed to 99.15 Kb. by saving 15.71 Kb. (13.68%)]
