Old December 30th, 2017, 07:16   #1
JVT
JVT's Avatar
Default starter solenoid wire connection help
Anyone have a tip for a more secure solenoid wire connection? I run my tdi strictly off road and the starter wire slips off. It is steel and soldering may not work. It looks to small for a bolt.
This is my starter.
JVT is offline   Reply With Quote
Old December 30th, 2017, 08:50   #2
AndyBees
AndyBees's Avatar
You need to squeeze the spade style connector bits closer together so that it is really hard to push on.
Also, use a zip tie to secure the wire so there's no flopping when your off-road machine is bouncing around!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old December 30th, 2017, 09:16   #3
UhOh
UhOh's Avatar
I've read that some folks take a thick strip of copper, size and bend to fit, and drill out for the connections- no soldering or connectors needed! Of course, you need to put something like shrink-wrap on it for insulation.
Old December 30th, 2017, 11:20   #4
maxmoo
I don't know what year starter you've got there, but I believe my alh starters have a locking connector on the solenoid start wire.
maxmoo is offline   Reply With Quote
Old December 30th, 2017, 13:47   #5
JVT
JVT's Avatar
AVM 1.9
I almost had to walk 9 miles yesterday.so i want it fastened tight.
It is in a german snowcat. The wire slides over the connector at the end of the line. You see the edge of it behind the white wire.
Smoking starter solenoid wire while cranking wizard_of_koz VW MKIV-A4 TDIs (VE and PD) 11 July 17th, 2014 10:14
Starter/solenoid/braided wire issue Kawayanan TDI 101 7 January 29th, 2014 10:25
Help Identify Wire Connection! augie dog VW MKIII-A3/B4 TDIs 0 June 23rd, 2013 11:23
WTB: Starter for ALH or starter solenoid vwjettadsl Private TDI Items for Sale/Wanted 2 February 22nd, 2009 18:37
No start condition, starter solenoid wire halzg VW MKIV-A4 TDIs (VE and PD) 1 May 21st, 2008 12:35
Page generated in 0.10364 seconds with 10 queries
[Output: 69.82 Kb. compressed to 61.39 Kb. by saving 8.43 Kb. (12.07%)]
