Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old December 30th, 2017, 06:46   #1
cbman18j
cbman18j's Avatar
Fuel Economy: 43mpg
Default Fuel Economy Loss after Wheel and Tire Swap
So I have been using the Montereys with Continental True Contact for ~70,000 miles. My mileage has averaged 40-48 mpg roughly through 69,000 miles of highway driving depending if my indicated speed was 70 or higher. I switched to 17" Long Beachs with Continental Pure Contacts and it took me to 36-38 mpg on my normal trip. When I had the Arriettas installed with Extreme Contact DWS I average 39-42mpg on the same trip. Maybe it has something to do with possible winter diesel but I am not sure how far South winter diesel is this year do to the colder temperatures. I may swap back to the Arriettas eventually to see the larger than expected loss is do to the Long Beaches or something else.
99.5 VW Jetta TDI 5speed Stage 2 Malone, EGR Delete (sold to close friends daughter)
2000 VW Golf TDI 5speed Frank06 Stage 2 Cam
2003 VW Jetta TDI 5speed w/ 11mm IP, Skid Plate, CAT Filter, HID Retrofit, RMT 100, .658 5th gear, Long Beach
2007 Chevrolet Avalanche
cbman18j is offline   Reply With Quote
Old December 30th, 2017, 07:09   #2
jayb79
Are the tires outside diameters the same? What are the tire sizes?
01Golf(370k), 2013 Mustang V6 28-30 summer mpg, 2016 F150 RCSB 2WD 2.7L ecoboost.
jayb79 is offline   Reply With Quote
Old December 30th, 2017, 15:12   #3
cbman18j
cbman18j's Avatar
Fuel Economy: 43mpg
Both the Long Beach and the Arriettas are being run with 225/45/17s; the arriettas had extreme dws in that size
Old December 30th, 2017, 18:40   #4
jayb79
The width of that tire is considerably larger(assuming you were running stock size b4???), more contact area is more rolling resistance. That would explain some of your loss.
Old January 9th, 2018, 06:17   #5
jettawreck
jettawreck's Avatar
Tread depth also causes mileage change, new/deeper tread causes more resistance. Also larger overall diameter decreases the indicated miles, which doesn't change your "real life" mpg much, but does change the calculation results since it tallies up fewer miles on the odometer. Slight changes seem to multiply the results more than expected.
New tires have always returned less mpg than the worn out ones when I have replaced.
Heavier wheels are also supposedly a bit worse for mileage, especially for those doing more stop/go driving.
2004 Cadillac SLS (wife's)
Old January 10th, 2018, 05:03   #6
cbman18j
cbman18j's Avatar
Fuel Economy: 43mpg
Yeah I was expecting some loss from switch from the Avus but compared to the artist has I was surprised by the loss
Old January 10th, 2018, 05:07   #7
cbman18j
cbman18j's Avatar
Fuel Economy: 43mpg
That makes sense because when I ran the arriettas the tires were not new, they were probably about 25-50% life left in them.
Best Wheel and Tire Size/type for Fuel Economy? ives TDI 101 9 March 16th, 2010 06:28
Best Tire for fuel economy Knoxville TDI Fuel Economy 31 February 8th, 2008 00:49
Wheel/tire (16") weights and fuel economy?? david_594 TDI Fuel Economy 25 July 11th, 2005 06:22
Best Tire for Fuel Economy PunchBug TDI Fuel Economy 6 August 22nd, 2001 21:00
Using tire/wheel upgrades for economy? BRUSSELS BELGIAN TDI Fuel Economy 12 February 19th, 2000 07:34
Page generated in 0.09592 seconds with 10 queries
[Output: 83.00 Kb. compressed to 72.01 Kb. by saving 10.99 Kb. (13.24%)]
