Old December 29th, 2017, 21:40   #1
artschnell70
TDI(s): 2001
Default lights sticking on when doors are locked
Have a 2001 Jetta TDI that required several clicks of the key or unlock button to get lights off. Now I'm unable to lock doors either by key or remote because lights stay on, wearing down battery. Only way to get them off is to disconnect battery. I'd be happy to disable security system and lock car manually. I'm sure someone must have experienced this problem. Any ideas? Thanks so much!
artschnell70 is offline   Reply With Quote
Old December 29th, 2017, 21:48   #2
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
forums.tdiclub.com/showthread.php?t=77648&page=2
Try that. Common issue. If you have VCDS you can see which door is electrically open but physically closed
Dannyboy is offline   Reply With Quote
Old December 30th, 2017, 05:54   #3
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Which lights? Sound like it could be a bad CCM.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old December 30th, 2017, 08:13   #4
JB05
Fuel Economy: 43/41/40
I'm having the same problem, though intermittently during this extreme cold weather. VCDS points to the driver's front door lock.
JB05 is offline   Reply With Quote
My car locked the doors on its own. Ed ke6bnl VW MKIV-A4 TDIs (VE and PD) 13 June 24th, 2016 15:54
Battery flat/Doors locked patrickmorris VW MKIV-A4 TDIs (VE and PD) 5 May 11th, 2014 17:56
Battery drain only when doors locked BCKCX2 VW MKIV-A4 TDIs (VE and PD) 6 December 21st, 2012 17:33
Relay chatter when doors locked cada VW MKV-A5 Golf/Jettas 0 October 29th, 2012 10:40
Horn No Longer Beeps When Doors Are Locked PDJetta VW MKIV-A4 TDIs (VE and PD) 6 September 19th, 2005 04:14
Page generated in 0.12304 seconds with 10 queries
[Output: 62.76 Kb. compressed to 56.22 Kb. by saving 6.54 Kb. (10.42%)]
