Old December 29th, 2017, 16:34   #1
tread
Default orange light came on after steep climb,load on
Hello, today at noon temp. -17C with chill factor going down the highway -60??this morning early 7:a.m. -37C. hubby decided to use hurricane tape on front grill but didn't leave any area to get a bit of cold air in. temp. gauge stayed in one spot- toasty warm in car. On the way home towing a utlility trailer with steel in it, going up a lot of steep hills , our orange malfunction light for emmisions oops came on. When we stopped for coffee for about 20 min. under the hood hose was very hot to touch. Hubby says he should have not completely taped the grill it needs to breathe. So our 20 min. ride home still had light on even though he torn open some of the tape to get cold air into turbo. Home safely, light still on dash. Does anyone think maybe the coolant temp. sensor fault code? All new glow plugs last month put in. hopefully not too serious. malfunction light is not blinking, came on going up steep hill??
Any ideas please
tread
tread is offline   Reply With Quote
Old December 29th, 2017, 16:43   #2
flee
Fuel Economy: 40-ish
The obvious answer is to get the code read.
With any luck it is a one-time event and can just be reset.
That will eliminate most of the guesswork, at least.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old December 29th, 2017, 18:59   #3
whitedog
Your car needs a discussion with a mechanic. What the mechanic will ask your car is, "What's wrong with you?" and your car will be rather vague, but it will give the mechanic an idea of what is going on in the cars mind and why it feels the need to flash it's light at you.
In order to have a meaningful discussion, the mechanic needs to have some pretty good knowledge of the car and engine as well as have the right tools to get as much information from the car as possible. This means that the mechanic needs a proper scanner to dig deeper than a generic code reader.
Old December 30th, 2017, 06:32   #4
jettawreck
jettawreck's Avatar
As whitedog said, it needs to get the code(s) properly read and reset first.
Couple questions/suggestions. While covering the entire front (even the radiator directly) isn't a bad thing in extreme cold, I always monitor coolant temp (and many other data points) with a digital (ScanGauge) since the dash cluster gauge is very "vague". Especially if doing any utility/towing. Usually you can control coolant temps quite effectively with the cabin heat blower in these situations. Did the dummy cluster temp gauge ever move above "normal"? By the time it moves off 90/190* its on its way to overheating.
Airflow thru the grille really has no cooling effect on the turbo.
Consider purchase of a ScanGauge or UltraGauge to monitor conditions if you do some towing.
"Orange" warning light? I'm sure all my warning lights are either yellow or red, but maybe I see color differently. Can you identify which message light it is by turning on ignition w/o starting so they all test and light up? Assuming MIL (check engine light) but there are several others.
Scan/reset and report back.
2004 Cadillac SLS (wife's)
Old December 30th, 2017, 10:49   #5
maxmoo
...but if they block the lower right vent to the intercooler it might.
I never block that vent even when I block all others.
maxmoo is offline   Reply With Quote
Old December 30th, 2017, 12:14   #6
jettawreck
jettawreck's Avatar
Maybe. I've never covered the intercooler either, but it was actually recommended by Drivebywire years ago. Not exactly sure of the ambient temp point, but his recommendation was in extreme cold was to cover it up to keep intake air temps more efficient. If I recall the point of better thermal efficiency was if below -0*F it's better to cover it. Never experimented with going they the hassle in the cold.
Sort of interesting to watch the intake temps, ambient temps and coolant temps change as I drive.
Old January 3rd, 2018, 13:42   #7
otm646
Fuel Economy: 54/48.5/43
I've dealt with intercooler blockage due to snow build up. I can not recommend doing it on purpose. I was seeing intake air temps well over 120F with ambient being around 25-32F.
76 300d 475k
97 750IL V12 working SLS 187k!
98 Jetta AHU 330k! PD150 intake 2.5 SS straight pipe- Sold to Papa Validius
05 WRX 5 speed wagon 220k + flow mods ~270 HP
81 Lancia Beta Zagato
otm646 is offline   Reply With Quote
High elevation, hill climb, high load overheating? ChadS99SVT VW Passat Family (NMS and B7) TDIs (2012+) 196 June 4th, 2016 12:55
Airbag went crasy, orange light is on all time bigHUN TDI 101 2 October 28th, 2011 16:34
Side Orange Light Repair GregJettaTDI Eastern USA 2 March 20th, 2010 09:13
WTB: Orange Passenger Side Corner Light rv4srock Private TDI Items for Sale/Wanted 0 September 19th, 2008 14:21
Weird Orange Light Goes off on Jetta Docproteus TDI 101 4 September 20th, 2006 09:44
Page generated in 0.13298 seconds with 10 queries
[Output: 84.76 Kb. compressed to 73.98 Kb. by saving 10.78 Kb. (12.72%)]
