Old December 29th, 2017, 13:24   #1
Gokartnut
Default Turbo swap
Got a rebuilt turbo on a 2000 Jetta tdi will it fit a 2006 beetle tdi?
Gokartnut is offline   Reply With Quote
Old December 29th, 2017, 13:36   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Nope.
oilhammer
www.cardocautomotive.com
Old December 31st, 2017, 06:03   #3
jimbote
jimbote's Avatar
yes and no, vnt15 can be used on a BEW but needs retune to delete the vane position sensor also swapping the turbo outlet hose, drainback hose, and support bracket, the egr may need to be deleted as the pipes might be different .... turbo will bolt up fine, TIP will work, downpipe bolts right up, stock feed line fits
turbo swap rf2009 TDI 101 10 December 3rd, 2014 03:52
turbo swap gribur VW MKIII-A3/B4 TDIs 0 June 23rd, 2010 21:39
2 Jettas And A Turbo Swap moe03 TDI Power Enhancements 4 August 31st, 2009 16:20
Turbo installation kit needed for turbo swap? unseenthings TDI 101 1 June 3rd, 2009 22:28
Turbo swap. Rattler VW MKIV-A4 TDIs (VE and PD) 5 May 17th, 2000 16:06
Page generated in 0.12256 seconds with 10 queries
[Output: 57.31 Kb. compressed to 51.89 Kb. by saving 5.42 Kb. (9.45%)]
