Old December 29th, 2017, 10:59   #1
leon10tagg
leon10tagg's Avatar
Default C Sensor wiring diagram
Would anyone have a wiring diagram for the 3 bar MAP C Sensor. I'm looking to compare it to a 3.5bar sensor to fool the ecu into providing a little bit more boost.
01 Golf Tdi, FMIC, CR1756 turbo, PD intake, Newman cam, EGR delete, BV, modified intake, 80mm MAF, turbo back 2.5" Milltek, 11mm IP, R520s, 3bar MAP, TD tuning box, PD130 O/C,Spax adj's, Eibach A/R bars, powerflex bushings, 312mm discs, top and bottom strut braces
05 & 04 Passat AWX, 98 Impreza turbo, 97 A4 1.8T sport
http://forums.tdiclub.com/showthread.php?t=298788
leon10tagg is offline   Reply With Quote
Wiring diagram for 02 sensor 00013cave VW MKVI-A6 Jetta Sedan (~ 2011+) 0 March 1st, 2017 17:13
Need wiring diagram borjawil VW MKV-A5 Golf/Jettas 1 October 13th, 2015 04:43
wiring diagram Kjames VW MKIV-A4 TDIs (VE and PD) 0 February 2nd, 2011 20:33
wiring diagram juve82 TDI 101 2 November 23rd, 2005 05:34
I need the wiring diagram for the MAF sensor racingteddybear TDI Power Enhancements 9 September 8th, 2000 14:04
Page generated in 0.10854 seconds with 10 queries
[Output: 47.00 Kb. compressed to 44.19 Kb. by saving 2.81 Kb. (5.99%)]
