Old December 29th, 2017, 09:04   #1
matt.m
TDI(s): 2003 NB
Default Hard starting even when engine is warm
I got my car started this morning (about 2F). It started decently, drove down to the grocery store. The engine got up to operating temps. When I got back in the car to head home, the engine just turned over. It took 15 seconds of putting the accelerator to the floor and it finally started. Now, even if I stop the engine, let it sit for a minute, it will struggle to start when warm. I checked the EGR valve and it moves freely. No fault code. Any ideas?
matt.m is offline   Reply With Quote
Old December 29th, 2017, 10:11   #2
UhOh
UhOh's Avatar
Pushing down on the accelerator won't do anything until after the engine starts.
Maybe your fuel is gelling?
If you have a clear fuel line (section of) going to your IP look to see if you're getting any significant amount of air in the lines.
My hunch is fuel gelling. Cross your fingers that that's it, otherwise your IP might be the culprit.
When was the last time the fuel filter was changed?
Old December 29th, 2017, 10:18   #3
OlyTDI
TDI(s): '04 Golf
2 deg above zero? Got to be gelled fuel.
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old December 29th, 2017, 10:46   #4
matt.m
TDI(s): 2003 NB
Last fuel filter replaced 10k ago. It's due for a draining. I don't have clear lines. Fuel *could* be gelling, but when I started the engine this morning for the first time, it started normally. It ran normally when driving. My fuel source adds kerosene usually around November, unless...they didn't. Filled up the tank yesterday. I had a new IP installed because the original failed about 50K ago. I've been pretty good about making sure the fuel filter gets changed when needed. Yes, I hope it's fuel.
Old December 29th, 2017, 11:42   #5
maxmoo
Your sending unit/fuel pick-up, that is in your fuel tank, has a very small orifice that can and often will bridge/plug with debris, ice, and/or gelled fuel.
When this happens the vacuum greated by the inj pump trying to suck fuel will cause air to be sucked into the fuel system at the weakest link, usualy the thermo T at the filter. This all happens more easily in cold temps.
See....
https://www.youtube.com/watch?v=yRMTEAKsScE
maxmoo is offline   Reply With Quote
Old December 29th, 2017, 11:55   #6
UhOh
UhOh's Avatar
No clear line... Why oh why did VW ever decide to not do that on some cars? (daughter's wagon is that way and I've been cursing this for some time now- I think I may have one on a spare IP I have)
Blockages in the tank's fuel pick-up would, as maxmoo notes, result in sucking in air and that would be visible in the clear section of the fuel line to the IP. Disconnecting the fuel line from the filter and pulling vacuum (vacuum pump/tester is essential tool) can help identify if this is the source of the problem (clogging).
Also check that the fuel return lines aren't leaking, as this will also result in air in the fuel lines (air goes into the filter, if you have the stock filter setup [which uses the thermo-tee]).
Old December 29th, 2017, 18:55   #7
matt.m
TDI(s): 2003 NB
Huge thanks for the suggestions. I'll have to diagnose when I return from FL; I'm fleeing the frozen north for a while. 9F for the high today. Eesh.
Hard starting when warm!!! PLEASE PLEASE HELP!! twong TDI 101 21 March 25th, 2006 09:13
Still Hard Starting with Warm Engine. New Battery & Starter spine911 VW MKIV-A4 TDIs (VE and PD) 14 January 15th, 2006 18:29
Hard starting when WARM! Cosmic Green VW MKIV-A4 TDIs (VE and PD) 6 October 15th, 2002 19:12
warm weather warm TDI engine hard starting wpeets TDI 101 23 February 2nd, 2002 20:54
hard starting when warm Sevet VW MKIV-A4 TDIs (VE and PD) 2 July 25th, 2000 15:53
Page generated in 0.14283 seconds with 10 queries
[Output: 78.95 Kb. compressed to 68.58 Kb. by saving 10.37 Kb. (13.13%)]
