Old December 28th, 2017, 21:49   #1
NevadaVandal
Default Timing Belt
Is there a timing belt replacement requirement for the 2001 Golf TDI at a particular interval?
NevadaVandal is offline   Reply With Quote
Old December 28th, 2017, 22:20   #2
STDOUBT
STDOUBT's Avatar
If my car was a 2001, and it recommends 105k, I'd probably do it at 90-ish.
I'm pretty paranoid about the TB.
Tell us about your golf dude.
http://www.vaglinks.com/Docs/VW/Main...e_Schedule.pdf
2003 Jetta TDI 1.9L 5-speed
"all-stock"
STDOUBT is offline   Reply With Quote
Old December 29th, 2017, 07:01   #3
jettawreck
jettawreck's Avatar
I believe the original 2001 TB interval was 80k miles (up from 60k miles in 2000 for a manual transmission, 40k miles for the automatic).
If it's changed on schedule and using the newer belt and large roller the interval has been extended to 100k miles. Most belt makers also have a time limit although none is mentioned in the service schedule in the owner's manual.
I still adhere to an 80k mile interval myself. I don't put a lot of miles on juggling between the two TDIs and the other vehicles. Also the shorter interval will probably only add one extra change in the expected life of my cars.
2004 Cadillac SLS (wife's)
Old December 29th, 2017, 07:19   #4
jokila
jokila's Avatar
Fuel Economy: 52/45/40
The 1.8T engine timing belt interval was 105K miles (at least on the Passats). Many, many of them failed before then, but with the 100K engine warranty they were covered unless the car was in the 100-105K twilight zone. The TDIs were not ever that long of an interval until 2003 (100K).
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is online now   Reply With Quote
Old December 29th, 2017, 11:37   #5
UhOh
UhOh's Avatar
Yes, do it before it breaks!
Since no one can really predict the future with sufficient enough accuracy one can only go by the intervals given by VAG and the component manufacturers. A problem is is that the intervals have changed (because the components have changed), and it's hard to say what is currently in the car. Lowest common denominator would be the safest guideline to go by, and that is that the interval for the 2001 cars was 80k miles: my 2000's TB was changed during previous ownership and the dealer installed an older belt, one spec'd for the then lower mileage belt (I am pretty sure that at the time of the job the 100k mile belts were also available).
Keep in mind that there's also an age factor. Rollers and such aren't really affected by age BUT the belt IS. This is a bit less exact, but industry standards tend to suggest somewhere between 5 and 7 years.
If in doubt CHANGE it ("them" - belt and components AND water pump). Replacement after failure becomes a LOT more expensive.
Timing belt failure - could this be a reputable timing belt? Rodrigues VW MKV-A5 Golf/Jettas 31 November 9th, 2015 17:39
LF: Serpentine Belt and V-Belt and Timing Belt velvetassassin96 Ontario 5 October 3rd, 2011 19:10
A5 JETTA TDI TIMING BELT KIT BRM $175 and Timing Belt+ alternater pulleyTools $65 kstef Private TDI Items for Sale/Wanted 1 August 29th, 2010 06:05
Golf TDI TIMING BELT CHANGE / TIMING BELT PINS POSITION grahammarkwoods Golf TDI Picture Gallery 3 October 9th, 2007 09:56
Timing Belt & Water Pump or just Timing Belt Flashman2 VW MKIV-A4 TDIs (VE and PD) 13 June 28th, 2001 10:31
Page generated in 0.14821 seconds with 10 queries
[Output: 72.88 Kb. compressed to 64.63 Kb. by saving 8.25 Kb. (11.32%)]
