Old December 28th, 2017, 18:17   #1
Gothmolly
TDI(s): 2002 Golf
Default install thermo-tee fitting w/o leaks
My thermo-tee fitting on the fuel filter is ... wiggly, and it seems as if air could get in where the hose slides over the tee, despite the clamp.
Dabbing some grease on that junction, the air bubbles all but go away.
How do you ensure a good mating surface/seal?
!Vent, !DRL, 5 brake light mod, 11mm pump, RC3, Bosio Sprint 520s, VR6/G60 clutch, missing belly pan, leaky CCV, leaky valve cover, leaking door seals, broken glovebox, broken horn, rusted fender, dead rear windowwasher, frozen axle bushings
Dead radio? Pull fuse 42, wait 60 seconds.
Gothmolly is offline   Reply With Quote
Old December 28th, 2017, 18:27   #2
If you have a good quality tee and filter you shouldn't have any leaks.
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old December 28th, 2017, 18:33   #3
jettawreck
jettawreck's Avatar
I have a CAT filter conversion and have always had to use a heavy grease on the T fitting to keep the air bubbles minimized.
2004 Cadillac SLS (wife's)
Old December 28th, 2017, 18:40   #4
Gothmolly
TDI(s): 2002 Golf
The leaks are more around the tee going into the lines, not the filter itself. It's like the lines aren't tight enough. Maybe someone previously installed a crap tee?
Old December 28th, 2017, 18:42   #5
Mongler98
Nictane fuel filter uber kit
Nictane.com
or search for ditzel mod.
Old December 28th, 2017, 18:45   #6
Or they're getting tired. With OE clamps they should be fine.
Old December 30th, 2017, 08:54   #7
AndyBees
AndyBees's Avatar
I wrap the nipples on the T with Teflon pipe tape. I know it is not fully compatible with diesel fuel, but once you force the hose on and clap it down, it will last until the next filter change...
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old December 30th, 2017, 09:13   #8
UhOh
UhOh's Avatar
I suspect that after 15 years hoses are starting to get a little less pliant. Should have seen the hose that I pulled from my diesel generator- it was B1 hose and at the ends it was like hardened, caramelized taffy, with some thin metal added!
Old December 30th, 2017, 11:54   #9
Gothmolly
TDI(s): 2002 Golf
It's always been a bear to remove the hoses from the fuel filter, maybe last time I beat them up? I'm seeing a constant stream of tiny bubbles coming into the clear line.
Old December 30th, 2017, 12:17   #10
JB05
Fuel Economy: 43/41/40
I try to work around the T when changing the filter. Silicone spray will soften rubber hoses.
JB05 is offline   Reply With Quote
Old December 30th, 2017, 13:22   #11
Just replaced the fuel filter on a new to a co-worker '03 Jetta. I find the hoses get "stuck" on the filter and need to be gently twisted to free them up before pulling off. But the filter tee went in fine (OE filter made by UFI), and no bubbles or leaks.
Old January 4th, 2018, 11:26   #12
Gothmolly
TDI(s): 2002 Golf
I might pick up a new T next time I make a idparts order. For those of you who grease things to keep them airtight, are you greasing the T before inserting it into the hoses & clamping, or are you putting the hoses back on it, then covering the joint with grease?
Old January 4th, 2018, 11:33   #13
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Just a light coat on the O-rings. Grease won't stop any leaks, it just keeps the rubber soft.
Sometimes the tee will hairline crack.
Old January 4th, 2018, 12:00   #14
Gothmolly
TDI(s): 2002 Golf
So your experience is that air is sucking in around where the T fits into the filter housing, not the hoses themselves?
I've always found the T fitting into the housing to be somewhat 'loose' even with that mouse-ears wire clamp thing holding it in. Is it supposed to have any play?
Old January 4th, 2018, 15:39   #15
jettawreck
jettawreck's Avatar
Yes, I've never had the hoses leak that I've noticed. There always seems to be some "play" in the T fitting and o-ring connection. Some heavy grease has been the solution for mine. Yours and others results may vary, as they say.
Need tee fitting a4 jetta fuel filter. Toledo oh Griz419 Mid-west USA 5 January 5th, 2012 12:08
Bio and Thermo Tee O Rings aespTDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 2 August 6th, 2010 15:28
WTB less expensive option for a thermo tee bypass kooyajerms Private TDI Items for Sale/Wanted 12 May 13th, 2009 00:25
Tricks to get fuel line off thermo tee? bf1967 TDI 101 4 April 7th, 2008 04:57
FS: Jetta Fuel filter Tee fitting outthere Private TDI Items for Sale/Wanted 0 January 1st, 2006 10:59
Page generated in 0.14775 seconds with 10 queries
[Output: 128.13 Kb. compressed to 106.93 Kb. by saving 21.20 Kb. (16.55%)]
