Old December 27th, 2017, 12:15   #1
fbio
Unhappy Gelling issues in extreme cold
I've been driving bio for years, but just moved to Illinois and have been hit with the Polar Vortex. I was driving 50% bio with anti-gel additives when the temperature dropped to the low teens and I was parked outside. Car started but died in about a mile, I assume from crystals clogging the filter. I have an unheated garage, and of course, sometimes the car will be parked outside if I'm traveling or visiting friends. I'm also worried, with temperatures as low as -2, of gelling while I'm driving. I will probably go to 100% diesel as soon as I can, maybe even siphoning the fuel I have now.
What is the best solution? I've been looking at filter heater pads. I see that I can get a tank heater and filter heater that plug in, but I'm wondering, for safety, if I should have a 12V filter heater pad that can be running while the car is running. It is fairly easy to wire in to the wiring system of the car?
Thanks!
fbio is offline   Reply With Quote
Old December 27th, 2017, 12:47   #2
jmodge
We have been running regular pump diesel in ours with no heaters, parked outside. Have not had any issues, fired up this morn at 18 below. (knock on wood) I did drill the check valve out of the sending/pick up unit in the tank. I heard that was quite the issue back in the early days of mk4 tdi's
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old December 27th, 2017, 14:58   #3
turbobrick240
turbobrick240's Avatar
If you can dilute the bio-blend with about 50% kerosene, you can probably get by without siphoning/pumping any of the mix from the tank. A tank heater would help, but it might be easier to try a leaner blend- like b25 during the coldest weather.
Old December 27th, 2017, 15:27   #4
MichaelB
If you are now living in Illinois almost all of the pump fuel is b11, might be as high as b20 but I doubt it. With this cold snap, we are experiencing your b50 blend is most likely candlewax by now unless the car is in a heated garage. Turbobrick's kerosene suggestion is your only hope as I doubt you could even drain the tank of b50 if the car is outside. You will most likely need to replace the fuel filter too.
MichaelB is offline   Reply With Quote
Old December 27th, 2017, 15:48   #5
jmodge
You could pull your sending unit out and see what you have. I remember a potatoe hauler from down south jelled up and cut the top off a beer can, filled it with stanadyne and dropped it in his fuel tank. It went to the bottom and he ended up getting his truck fired. Not likely bio fuel though. Come to think of it, Ask a farmer, they can usually solve anything.
Old December 27th, 2017, 16:34   #6
maxmoo
With the milage these cars get and the relatively cheap cost of diesel, I don't think it's worth putting anything else in the tank....too many potential headaches.
But that's just my opinion.
maxmoo is offline   Reply With Quote
Old December 27th, 2017, 16:47   #7
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
Ding ding
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old December 27th, 2017, 16:54   #8
MichaelB
Originally Posted by JDSwan87 View Post
Ding ding
Well,
I don't feel that helps the OP with his current fuel gelling issue. Ding, Ding doesn't help! Offer up immediate solutions or pass on by. How would you feel if you asked for help and got Ding, Ding?
Old December 27th, 2017, 17:10   #9
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Thanks!
I do not know the solution. Best you can get the fuel out ASAP -- Then fill with 100 % diesel -- Good luck
2015vwgolfdiesel is offline   Reply With Quote
Old December 27th, 2017, 17:11   #10
UhOh
UhOh's Avatar
Need to narrow down where the blockage is and what is causing it. We can "assume" it's the fuel, but you've really got to prove it: it might be just the check valve in the pick-up (and perhaps not related to fuel), but we really cant' say for certain, in which case try the easiest diagnostic things first.
If fuel pulls fine from the tank then it'll most likely be an issue with your fuel filter. Of course, one could swap out the filter to determine, but I think pulling fuel from the tank is quicker.
Stick with D2.
Old December 27th, 2017, 17:21   #11
2015vwgolfdiesel
D2
Remember your beloved ride is on in years (and maybe miles too)
Old December 27th, 2017, 17:23   #12
MichaelB
Originally Posted by UhOh View Post
Stick with D2.
Great advice but D2 is almost vaporware in Illinois. Better advice is to stick with pump fuel and not sweat the details. Illinois and Minnesota all have b something blends year round We need someone from Illinois to chime in here.
Old December 27th, 2017, 17:24   #13
scooperhsd
Start with PowerService 911 / Powerservice white. STOP USING BIO (except what you get from the pump) until spring after you empty this tank. I'd continue to using the Powerservice white for the rest of the winter.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old December 27th, 2017, 17:25   #14
MichaelB
Originally Posted by scooperhsd View Post
Start with PowerService 911 / Powerservice white. STOP USING BIO (except what you get from the pump) until spring after you empty this tank. I'd continue to use the Powerservice white for the rest of the winter.
Now we are getting somewhere
Old December 27th, 2017, 17:32   #15
pdq import repair
Fuel Economy: 38.5
If it is gelling, the best possible scenario is to put it inside and warm it up. They will usually fire right up after a that, if that is the problem. Once the fuel is liquid again, drain it out and refrain from non weatherized fuel till spring.
I have seen in cases where the vehicle can't be put inside, usually large trucks, where a small controlled fire is built under it to thaw it out. (old farmer trick)
pdq import repair is offline   Reply With Quote
Fuel Gelling Issues ctxj90 VW MKIII-A3/B4 TDIs 11 February 18th, 2016 11:20
MKIV fuel gelling in current midwest extreme cold Phil Lewandowski TDI 101 20 January 14th, 2014 15:43
Extreme Cold Operation gvan VW MKIV-A4 TDIs (VE and PD) 19 January 30th, 2011 20:40
WSJ: ULSD to blame for gelling issues jbrone Fuels & Lubricants 21 February 12th, 2007 10:50
Driving in extreme cold? DaveO VW MKIV-A4 TDIs (VE and PD) 32 November 19th, 2000 01:43
Page generated in 0.09785 seconds with 10 queries
[Output: 127.94 Kb. compressed to 107.05 Kb. by saving 20.89 Kb. (16.33%)]
